06 double cab axle issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yotawv, Dec 27, 2017.
  1. Dec 27, 2017 at 9:09 AM
    Yotawv
    Yotawv [OP] Well-Known Member
    WV
    06 silver DCSB
    A lot of shit
    Anyone have issues with their stock e-locker rear axles?
    Christmas Day, I went to back out of my driveway after just driving the truck the night before and it wouldn’t budge.. (so before when it was cold and wet outside I had the ebrake freeze up on me and once I got the truck wheels to roll it freed up of course) well Iassumed same issue, put the truck in 4 wheel backed up and crack, driver side rear wheel locked up, bunch of grinding and popping. Worst sound you never wanted to hear. Needless to say something gear or axle related happened in a bad way. Got the truck turned around in 4wd dragging that wheel then it would free up and drag again. Felt like the whole rear end was coming out. Anyway tearing into it tonight or tomorrow but not sure what to expect.... maybe someone else had same issue or insight on what I may be looking at fixing?..
    Thanks
  2. Dec 27, 2017 at 9:11 AM
    Clearwater Bill
    Billy
    Largo Florida
    Please post pictures of what you find..........
  3. Dec 27, 2017 at 9:14 AM
    Red Baron
    Red Baron Let's call it livabetes, no more die
    Aaron
    Lost on a roundabout
    07 Radiant Red DCSB
    Things with metal, dog hair, more metal and lights
    @NYCO what was the issue you had last year at the mall crawl (recovery event)
  4. Dec 27, 2017 at 9:24 AM
    M192
    M192 Well-Known Member
    Dan
    Cambria county PA
    06 Tacoma trd sport, 88 4runner
    Alot
    My one rear tire would lock every so often found out it was the little spring on the bottom of the shoes. It fell off and the shoe would catch the drum and lock up. Must've ground the spring away because the spring was gone. I'm not saying that's your problem but Its worth a look.
    TACORIDER likes this.
  5. Dec 27, 2017 at 9:46 AM
    Yotawv
    WV
    06 silver DCSB
    A lot of shit
    I’m pretty sure I’m past the issue of a spring by the cracking sound the rear end made. Something was spinning inside the axle housing and it sounded pretty bad. This is the first time I’ve had an issue like this with an axle, so I’m curious as to what I find... we’ll see. I just didn’t know if anyone else has ever blown a ring and pinion or their spiders gears, or hell maybe I’m the first on these 2nd gens
  6. Dec 27, 2017 at 11:34 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    yup first ever to break a R&P :D been through a few myself
    my first thought is a seized drum...i had that happen when out in VT a few times. had to jack up the rear and do some convincing to get things to move again. ended up rebuilding the rear drums with new pads and springs. i was always worried about breaking a u-joint or shredding my gears, so i never tried to unseize them by force of the truck. on cold days i actually took a torch to the drums to free them up.
    @Red Baron is referencing a situation where my e-locker did not disengage the sleeve. i had to lift the ass up to get the wheels off, remove the e-locker motor and slide the locker sleeve over manually. haven't had that happen since.
    typically if you kill your R&P, the truck will still move, but will cause some deathly grinding and noises. you'll feel a badly damaged R&P. i've had it where it would catch the teeth just right and almost lock up my rear end.
    my understanding is most spider gear failures will leave you stuck and spin the broken side. you'll have to lock up the rear end to get the side unbroken to move the truck.
    Red Baron likes this.
  7. Dec 27, 2017 at 12:41 PM
    Yotawv
    WV
    06 silver DCSB
    A lot of shit
    @NYCO yeah I had to lock in the elocker after I already did the damage just to get the truck to move. It was almost like the wheels were chalked up. It wanted to move but wouldn’t, so I locked in the locker and once I broke free I took it out, put the truck in drive and reverse a couple times (my own stupidity) the wheel freed up enough to roll about 8-10 feet then lock up again, then roll and lock again. Every time it locked it felt like rear end was coming out of the truck. It was pretty disgusting.. so anyhow I’m pulling the third member tonight to see the damage I reckon...
  8. Dec 27, 2017 at 1:50 PM
    M192
    Dan
    Cambria county PA
    Alot
    Oooo yeah. That sounds bad. Subbed for what you find. Take pics!
  9. Dec 27, 2017 at 2:03 PM
    Muddinfun
    Muddinfun Well-Known Member
    Pull the drain plug and see if metal chunks fall out.
    You're going to have to pull the axles to get the 3rd member out, so you'll be into the brakes before you get that far. Maybe you'll see something in the brakes.
  10. Dec 27, 2017 at 2:21 PM
    Pigpen
    Dan
    Northwest Montana
  11. Dec 27, 2017 at 2:41 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    axles can come out without breaking apart the drums... four bolts behind the drum
  12. Dec 27, 2017 at 2:41 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
  13. Dec 27, 2017 at 5:11 PM
    Yotawv
    WV
    06 silver DCSB
    A lot of shit
    So you can see the damage....
  14. Dec 27, 2017 at 5:15 PM
    Pigpen
    Dan
    Northwest Montana
    :eek:
  15. Dec 27, 2017 at 5:15 PM
    Muddinfun
    DAMN!!!!!!!
  16. Dec 27, 2017 at 5:17 PM
    Whitebutler
    Whitebutler No need to compensate!
    From up in dem woods
    06 black sand Perl access cab. 99 T4R
    33s and stryker440 10 meter conversion to 11 radio
    Looks normal for how it acted and the sounds. I've done a fewteen in my day.
  17. Dec 27, 2017 at 5:25 PM
    Yotawv
    WV
    06 silver DCSB
    A lot of shit
    Next question is where to find a complete elocker 3rd member...
  18. Dec 27, 2017 at 5:27 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    yea i think that might cause an issue! :bananadead:
    are those OEM gears or aftermarket?
  19. Dec 27, 2017 at 5:27 PM
    Yotawv
    WV
    06 silver DCSB
    A lot of shit
    How difficult is it to change the front R&P on these trucks? May regear for the 35s that are on it while I’m here and get my power back
  20. Dec 27, 2017 at 5:28 PM
    Yotawv
    WV
    06 silver DCSB
    A lot of shit
    @NYCO OEM gears that I broke
