06 just turns over.... no start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ramitdammit, Jul 25, 2008.
  1. Jul 25, 2008 at 9:40 AM
    ramitdammit
    ramitdammit [OP] Member
    Apple Valley CA
    06 4x4 dbl cab snugtop super sport
    My 06 4X4 will occasionally just turn over but will not start. When I turn the key off then try again all is ok. I can’t figure out any pattern IE cold start, hot start, full or empty tank of gas, parked up hill or down etc. Sounds to me like a spark problem. The dealer hadn't herd of this and said they would have to witness it before anything could be done. Well, the odds of the problem occurring under their watchful eye are slim to none. Any one have any Ideas???
  2. Jul 25, 2008 at 9:42 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    take it back to the dealer and get them to reflash the ecu.....there is actually a tsb out for it.....intermittent or extended cranking tsb or something to that effect. the 06 i had did it, got the reflash done, and it did the trick.
  3. Jul 25, 2008 at 4:59 PM
    NHinAK
    NHinAK Active Member
    Anchorage
    08 Tundra TRD
    -Debadged
    Yep, get them to do the intermittent no start re-flash. FWIW: It's a requirement before flashing the ECU for a supercharger install as well.
  4. Jul 25, 2008 at 10:22 PM
    06BLUEDBLSPORT
    06BLUEDBLSPORT Well-Known Member
    Colin
    Fort Wayne Indiana
    12 Tundra DC SR5 4x4 5.7L
    True Dual Flowmaster 40 Series exhaust, Volant CAI, HIDs, Raptor series Side Steps, Weathertech Floorliners, OME 613 Shocks and Coils with Diff Drop, Rear Bilstein 5100 Shocks, ToyTec AAL, Fearless Fabrication Front Bumper
    I had the same thing happen to me a couple of times, i would turn the key and when i hear the engine catch on it then just stop.
  5. Nov 22, 2014 at 7:34 AM
    Uncle
    Uncle Member
    mike
    marietta
    98 SR5 TRD
    same issue here. cranks fine, no run. sometimes works fine. once it runs it works fine...but probably once a day I will crank and crank and it will take like 5 tries before I can get it to run.
  6. Nov 22, 2014 at 8:43 AM
    xtyfighterx
    xtyfighterx Master Shredder
    Ty
    CDA Idaho/ Deadhorse Ak
    09 DC SW TRD OR/ 2015 tundra CM off road sr5
    3in lift, 5100s front and rear, OME 887 springs 2in aal, 285 75 16 Duratracs, mb 352 black wheels, white sport grill, derp'd lower valance, derp'd front toyota emblem white, tinted windows, tinted tail lights, trd shorty antenna, trd hitch cover, trd valve stem caps, trd neoprene covers, trd all weather floor mats, kenwood double din, stampede window visors, flyzeye interior leds, anytime fog light mod, flashlight mod, kool vue intake, LED dome light, Lund bug shield, TRD shift knob,front mud flaps removed, Debadged, truxedo roll up bed cover, led fog light bulbs, led parking light bulbs, led dtrls bulbs, led headlight bulbs, led back up light bulbs, led license plate bulbs, tinted license plate covers, 18" magnaflow muffler, 32in ebay, light bar, coverking neoprene resr seat cover, oem trd skid plate, trd decal on center caps, oem trd exhaust tip, blacked out pinch welds, color matched mirror covers.
    When's the last time the fuel filter was changed? Could also be a fuel pump issue lots of stuff to check
