07 Base right front Turn socket plug
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Brandoaz, Aug 7, 2018.
  1. Aug 7, 2018 at 4:33 PM
    Brandoaz
    Brandoaz [OP] Active Member
    I need to find the part number and or a replacements for the plugs that are attached to the loom of the truck that plug INTO the light bulb socket/holder for the turn signals in the headlight housing. The plug that plus IN TO this:
    I cant find anything anywhere.
    Thanks for the direction
  2. Aug 7, 2018 at 5:18 PM
    caribe makaira
    Caribbean, Puerto Rico
  3. Aug 7, 2018 at 6:14 PM
    caribe makaira
  4. Aug 8, 2018 at 11:47 AM
    Brandoaz
    Thank you !
  5. Aug 8, 2018 at 12:14 PM
    Brandoaz
    ive found those locally ..the housing is 7.50 which is fine, but each of the wired is 7.80 each, any sources online that you are aware of?
    anything aftermarket that woud work is fine as well.
  6. Aug 8, 2018 at 12:27 PM
    Brandoaz
