07 Prerunner pic
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ahub7768, Oct 20, 2007.
  1. Oct 20, 2007 at 11:17 AM
    ahub7768
    ahub7768 [OP] Member
    Oklahoma
    07 Prerunner SR5
    2" lift kit, 18" Boss rims w/ Nitto Terra Grappler tires, dumped Magna Flow exhaust
  2. Oct 20, 2007 at 11:31 AM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Looks good man like the lift and rims
  3. Oct 20, 2007 at 11:45 AM
    909tacoma
    909tacoma Well-Known Member
    07' Prerunner SR5 TRD
    Here this should work...
  4. Oct 20, 2007 at 1:29 PM
    AUDITECH
    AUDITECH Carolina Alliance: LAZY DIVISION
    charlotte nc
    07 double cab prerunner
    none
  5. Oct 20, 2007 at 5:24 PM
    rick
    rick `
    looks good. maybe a bit more rubber
  6. Oct 20, 2007 at 5:50 PM
    gegundez
    gegundez Well-Known Member
    Miami, FL
    07 TRD Prerunner Dcab
    Overpriced stereo and alarm. MBRP Dual Exhaust.
    I went with a little more rubber by getting the 65 series (285/65/18) BFGs. Rubbed a little so I ordered the 3" body lift blocks. Your ride looks good but it is truly looks unfiinished. The tires look low profile due to the larger wheel diameter, so the 2" lift doesn't make any sense. If anything I would have expected a 2" drop...:confused:
    I understand you probably did this to keep the same wheel diameter to factory specs. I thought about that too, then after checking how it would look at the tire dealer, ended up changing my mind.:cool:
  7. Oct 20, 2007 at 6:47 PM
    ahub7768
    Oklahoma
    07 Prerunner SR5
    So you think I should get the 65 series and keep the 2" lift? I wasn't sure how big of a lift to get due to the fact that the truck is only 2 wheel drive.
  8. Oct 20, 2007 at 6:50 PM
    ahub7768
    Oklahoma
    07 Prerunner SR5
    Also, the truck is still a work in progress... Not quite finished. I plan on putting on running boards and a bull bar.
  9. Oct 21, 2007 at 7:58 AM
    allrsdup
    allrsdup Well-Known Member
    Sahuarita AZ.
    2018 dcsb trd offroad 4x4 Inferno
    i think it looks very nice. leave the running boards off takes away from the look of ground clearance i think.
