07 Tacoma Hitch
Discussion in 'Towing' started by cormchar, Oct 24, 2009.
  1. Oct 24, 2009 at 4:03 AM
    cormchar
    cormchar [OP] Member
    I am planning on purchasing an 07 Tacoma Double Cab V6, and it doesn't have a hitch on it and I currently have one on my Ford Ranger. I want to take this one off and put it on the Taco, the hitch that I have is a Class III.
    This will fit right?
    The Taco will use the Class III correct?
    Thanks
  2. Oct 24, 2009 at 4:33 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    Yes class 3, but I doubt it will bolt up correctly...I don't believe they are the same :notsure:.
  3. Oct 24, 2009 at 5:03 AM
    Rtrn2taco
    Rtrn2taco Nostalgia...
    Philadelphia
    08 DC PreRunner (silver)
    definetly a different hitch. It wont fit without heavy modification, I would recommend for your safety and others to purchase the correct hitch for the Tacoma.
  4. Oct 24, 2009 at 5:18 AM
    FoxySandChick
    Kristin
    Henderson, NV
    If you have a Uhaul nearby check to see if they sell hitches at the location. Mine was only $120, it sits nicely up under the body so it isn't really noticable from the rear. It was pretty easy to install at home with air tools and a helper.
  5. Oct 24, 2009 at 7:13 AM
    cormchar
    well this wasn't a hitch from Ford it was an universal one that I had bought after and installed.
    It might fit since it's ajustable for the length anyways.
