08 Oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dave, Aug 18, 2008.
  1. Aug 18, 2008 at 4:26 PM
    Dave
    Dave [OP] Well-Known Member
    RI/Vt
    08 4x4 Xtra Cab
    Toyota recommends 5-20 for the 08 2.7.
    Never used this before.
    What are people using?
  2. Aug 18, 2008 at 5:46 PM
    Zebra
    Zebra Well-Known Member
    Millington, TN
    2008 Tacoma 2.7L 4x2 Reg. Cab 5-speed
    Volant ram air and CAI setup, Fumoto oil drain valve, Pioneer DEH-3900MP
    i use 0W-20 like the manual says
  3. Aug 18, 2008 at 5:52 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    5w20,or 0w20 will supposedly yield better mileage, but i think tis perfectly fine to use 5w30. use the 5w20 if you would like....per the manual, it wont hurt anything as thats what is called for.
  4. Aug 18, 2008 at 5:56 PM
    Dave
    RI/Vt
    08 4x4 Xtra Cab
    Thanks. What brand you using?
  5. Aug 18, 2008 at 6:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Stick with the 5w-20. Yes, its better for the fuel economy, but the engine needs a thinner oil. The Variable valve timing system on your motor is controled by oil pressure. Running a thicker oil, i.e. 5w-30 or whatever, could hinder its performance significantly. :)
  6. Aug 18, 2008 at 7:03 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i run 5w30 in my 3.4.......and i ran the same in my 06 with the 4.0.
  7. Aug 18, 2008 at 7:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The 4.0 and the 3.4 are fine with that weight, but I think sticking with the 5w-20 in the 2.7 is a better idea.
  8. Aug 18, 2008 at 7:22 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i failed to see that he had the 2.7:eek:.......and in that case, yep.....stay with the 5w20. we run 5w20 in my wifes accord....mobil1 too....good stuff.:)
  9. Aug 18, 2008 at 7:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Same here! Mobil 1 5w-20 in the Wifes Accord! :proposetoast:
  10. Aug 18, 2008 at 7:27 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    hell yeah bro!!! the car runs really smooth with it!!:)
  11. Aug 19, 2008 at 1:09 AM
    Zebra
    Millington, TN
    amsoil 0w-20
