08 TRD Lug Nut size...?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 45longcolt, May 10, 2015.
  1. Jun 15, 2015 at 5:48 AM
    WeberSarge
    WeberSarge Well-Known Member
    Kevin
    Ohio, Illinois
    '08 SR5 TRD 4X4 Quad Cab , '77 FJ40
    Stock for now...
    I'd just get a set of McGard's nickle based nuts and replace those oem swollen nuts . Saves on ice and they never rust or change size , well worth the price .
    Sarge
  2. Jun 15, 2015 at 6:47 PM
    45longcolt
    45longcolt [OP] Well-Known Member
    DFW Area
    2020 Off Road
    Ah hah! I am not the only one with swollen nuts around here, it does happen.
  3. May 25, 2016 at 3:07 PM
    TRD50
    TRD50 Well-Known Member
    Des Moines
    08 TRD Sport
    Dang....I have been researching for a few days now...my oem nuts are swollen!!!
  4. May 25, 2016 at 3:10 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    OEM lug nuts suck if one rotates the tires on a regular basis since the covers fall off fast. Bought some solid ones years ago and they have held up fine.
    TRD50 likes this.
  5. May 25, 2016 at 3:13 PM
    TRD50
    Des Moines
    08 TRD Sport
    What did you do to remove the swollen nuts?
  6. May 25, 2016 at 4:40 PM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Try a vet - he took care of my dog. Only problem is dog doesn't trust me anymore.
    TRD50[QUOTED] likes this.
  7. May 25, 2016 at 4:46 PM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    go to Rock Auto, they have the Dorman brand lug nuts cheap by the box of ten. Get three boxes so you will have half a dozen spares.
    and once you have the new lug nuts, just use the larger socket and throw away the old lugs nuts. I like the six point impact style. I tend to buy the Williams brand from McMaster-Carr, www.mcmaster.com. They are the snap-on industrial brand, inexpensive and tough. I have yet to wear one out, and just bought a set of six point 3/4 drive impact, 7/8 to 2" for heavy equipment work.
    Howard
    TRD50 likes this.
  8. May 25, 2016 at 7:38 PM
    TRD50
    Des Moines
    08 TRD Sport
    That's hilarious!
    Thanks for the info I'll check them out.
  9. May 26, 2016 at 2:24 PM
    08TacoTrD
    08 TRD Offroad
    Ice and a few NSAID's.
  10. Mar 17, 2018 at 3:25 PM
    Wavewalker
    Wavewalker New Member
    2008 Tacoma Crew cab Long bed 4x4
    45longcolt:
    “I have since ordered myself in a dual flip sided 21/21.5mm socket designed to remove chrome capped lug nuts like these. I will report how it fits when it comes in.”
    Newbie here ... have popped on and off since I got my 2008 ... still going 10 years now.
    I’ve have the exact situation you had ... swollen nuts, I guess. I’ve changed/rotated tires before and none of my usual tools work. Had been using 13/16 w/ breaker bar just fine. Now nothing. Went out bought the 21mm ... same. Nothing. Before I drive out (again) and get a 22mm
    ... so what did you do? What worked?
    (All this to fix the parking brake that's locking up my rear end ... at least that’s the hunch. Why do things always take 5x longer than expected )
  11. Mar 17, 2018 at 6:35 PM
    08TacoTrD
    08 TRD Offroad
    Ha! Must have missed this gem. I banged a 21mm socket onto the swollen nut like it owed me money and put the solid nutz on.
  12. Mar 21, 2020 at 2:41 PM
    CaeTzar
    CaeTzar New Member
    06 double cab 4l standard
    You are not crazy. Digital calipers on supplied emergency wheel wrench reads 21.3mm. 13/16 would fit if I hammered it on, it reads 20.94mm. Also have old chrome stock nuts. Do they get more swollen the older they get you think? Or do they just swell up more early on when it's new and exciting? Like you are driving her out in the bush every weekend, out for dinner after work on a weekday, to the movies... and then wither with age when you are just going back and forth to the ski hill and grocery store? Wondering if i should order one of those special swoll-nut sockets or just wait it out?
