09 5 spd auto trans observation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by emmitt, Oct 31, 2009.
  1. Oct 31, 2009 at 7:53 PM
    emmitt
    emmitt [OP] Active Member
    Calgary Alberta
    2012 TRD OR AC
    Was just reading the manual on something urelated and just happened to read the page noting shifting patterns and I had no idea that in drive, shifter to the left is 4th and shifter to the right is the correct "drive" postion. There is a notation that says for optimum gas milege and "less noise" use the shifter position to the right. I can't believe I'm the only one that missed this. We're talking about 3/8" difference between 4th and drive. Any potential damage from driving all the time in 4th?:confused:
  2. Oct 31, 2009 at 7:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    No damage. Dont worry about it, the only thing that happened is you may have lost a few mpg by driving in 4th..
  3. Oct 31, 2009 at 7:57 PM
    emmitt
    Calgary Alberta
    2012 TRD OR AC
    Thanks Chris. nest time try and get that reply a bit quicker..........lol
  4. Oct 31, 2009 at 7:58 PM
    jandrews
    '09 FourDubDee TRD OR
    Not really.
    Driving in 4 just limits the trans to 4th gear as the top end gear, effectively removing the 5th ratio. This'll kill your mileage if you get to higher speeds (above 40mph or so), and maybe put a little more wear on the engine from higher sustained RPM, but nothing that'll make your truck blow up right then and there. The extra wear might mean the difference between 350,000 mi and 349,850 mi...:p
    Around town you likely never hit 5th gear anyway, so there's no real difference. Just make sure you're in "D" on the highway or you'll be getting Tundra mileage.
  5. Oct 31, 2009 at 7:59 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Did that myself when I first got the truck.
    50,000kms later and no issues.
    Unless you count me draining my tranny...
    and attempting to refill it via the radiator...
