09 access cab problems 6spd
Discussion in '2nd Gen. Tacomas (2005-2015)' started by white91formula, Feb 8, 2009.
  1. Feb 8, 2009 at 1:14 PM
    white91formula
    white91formula [OP] Well-Known Member
    Boston, MA
    05 6speed TRD OR
    Havnt brought it to the dealer yet but im seeing if anyone has had this issue also.
    when i let the clutch out in first get the truck jumps on me, no matter how slow i do it. its almost like wheel hop, but im not burning out or anything. it seems to be worse when im taking off to go around a corner.
    kind of feels like i have a locked rear diff, but the truck doesnt have a locker in it.
    i only notice it when im getting going in first. and it seems to be worse if there is any weight in the bed.
    truck has 800 miles on it, and its bothering me. its just a sr5 not the trd or the sport
  2. Feb 8, 2009 at 7:55 PM
    white91formula
    Boston, MA
    05 6speed TRD OR
    anyone else ?
  3. Feb 9, 2009 at 5:40 AM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    First gear is low, and if you pop the clutch it can be jumpy, but a normal clutch let out there shouldnt be any 'jump'. I'd go see the dealer.
  4. Feb 9, 2009 at 10:18 AM
    robast
    robast Member
    Bainbridge Island, WA
    09 V6 Manual Access Off Road
    I agree, first gear is geared quite low (I'll often start in second unless I'm pointed uphill) but there shouldn't be any noticeable hop or jump.
  5. Feb 9, 2009 at 1:52 PM
    rachunter
    rachunter Well-Known Member
    West Virginia
    08 TRD Off-Road
    XM Radio,Access Lorado Tonneau, Ventshades, Tinted Windows, Destination A/T's , Moto Metal wheels and lots of Liquid Glass
    Keep in mind that when you are cornering you are taking weight off of the inside rear tire and that will make it much easier to spin, if the road is wet or loose dirt or gravel it will be even easier for the truck to spin the tires.
  6. Feb 9, 2009 at 2:03 PM
    white91formula
    Boston, MA
    05 6speed TRD OR
    i realize this, but its excessive
    its like driving a car with a locker on the street with slicks.... but its a truck with out a locker and street tires
  7. Feb 9, 2009 at 2:34 PM
    Caddmannq
    Caddmannq MotoNerd
    California
    2012 PreRunner TRD Sport DC LB
    Undercover toneau
    Mine is an auto, so I gotta ask: is this clutch hydraulic or cable operated?
    If cable I'd suspect the cable is just not adjusted properly, or it's a kinked or defective cable.
    On cable or hydraulic there could be a loose bolt at any of the brackets.
    A too-high idle might also cause this, but you'd see that from the tach right away.
  8. Feb 9, 2009 at 3:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    hydraulic clutch.
  9. Feb 10, 2009 at 4:10 AM
    rachunter
    West Virginia
    08 TRD Off-Road
    white91formula,
    That was my best guess, I do not have a clue what would cause that but I think a trip to the dealer is in order. Please let us know when you find out what is wrong.
    Have a good day.
