09 Always-On Rear View Camera
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aalders, Jun 28, 2009.
  1. Jul 27, 2015 at 4:47 PM
    #221
    Timbo
    Timbo Member
    Tim
    Fork sc
    2013 tacoma trd dcsb
    hey everyone new to forum just finished mod on 2013 tacoma switch actually turns camera off i have three red wires tied in like original post Any help is appreciated
  2. Jul 28, 2015 at 5:13 AM
    #222
    Timbo
    Timbo Member
    Tim
    Fork sc
    I think I have it figured out just needed to walk away for a min. Thanks
    Crom likes this.
  3. Jul 29, 2015 at 10:14 AM
    #223
    maxbear
    maxbear New Member
    2013 prerunner
    Timbo,
    If you haven’t figured it out yet, I can upload you the details I’ve what I did on my 2013 Tacoma TRD Sport. Let me know and I will send it along. Maxbear
  4. Jul 29, 2015 at 10:26 AM
    #224
    Dj Suisav
    Dj Suisav Well-Known Member
    Saul
    San Antonio, TX
    2011 MGM DCSB Trd Sport
    RIP 2009 Super White DCSB Trd Sport
    sub'd!! great simple and direct write up!
  5. Jul 29, 2015 at 1:38 PM
    #225
    Timbo
    Timbo Member
    Tim
    Fork sc
    thanks splice wasn't making good connection. Just needed to back away for a few min. and rethink it
  6. Oct 3, 2015 at 7:39 PM
    #226
    Jcollins
    Jcollins Well-Known Member
    Justin
    Browns summit north carolina
    2013 grey tacoma trd
    Light bar and pods with strobe back up camera any time mod 886 backup lights and a Detroit true track posi
    just completed mod. ran into the problem of it turning check engine light on but figured out the problem and cleared the code. but i decided that i wanted to put the switch on the pillar. hears a picture.
    Mightyniceunit and Spencer97TJ like this.
  7. Oct 7, 2015 at 9:01 PM
    #227
    nbiba
    nbiba New Member
    Nehat
    2007 Navy Tacoma
    not sure if you told us already but I'm really interested into putting a backup camera in, I'm just not sure on which brand or where to get a great camera from?
  8. Oct 9, 2015 at 6:10 PM
    #228
    Mightyniceunit
    Mightyniceunit Chevron
    Chevy
    Manitoba
    4X4 Tacoma SR5
    Trailer brake control, ARB Compressor, Mirror riser bracket, Relocated 7 pin, Map light mod, Selectable Rear view Camera, Bed Light, Power locking tailgate.
    nbiba, I think you are looking for the forum in the 2nd gen discussions, "2015 back up cameras". There is a lot of info on aftermarket kits. Good luck.
  9. Oct 9, 2015 at 6:58 PM
    #229
    Mightyniceunit
    Chevy
    Manitoba
    4X4 Tacoma SR5
    This mod is awesome if you are alone and have to line up with your trailer. Thanks to Aalders for all the leg work. I wanted a stock look so I changed it up a bit and installed a slider switch in the rear view mirror itself. Once the mirror is removed from it's housing, there is a surprising amount of space back there (the mirror and display are only about 5/8" thick)
    Fear and common sense aside, the mirror face came off with a lot of care and a flat tip screw driver. I found it easier to start opening the side first, then the top and ending with the bottom.
    I made my connections below the connecter that Aalders used. The colour coding of the wiring changed (of course). The green wire changed to a black and the red was red on both sides of the connecter. This photo was taken when I was testing it out -I covered all of the exposed wiring before installation.
    In the last picture its hard to see the switch, but I guess that was the idea. If I could do it again, I would put the switch on the bottom right hand side of the mirror to make it a little more intuitive.
    theolee, bremt3, J Red and 1 other person like this.
  10. Oct 13, 2015 at 9:23 AM
    #230
    Spencer97TJ
    Spencer97TJ Well-Known Member
    Spence
    CT
    stock
    Nice! I think I want to do it this way. It's frustrating when the image goes away when pulling forward an inch or two during line up. Drives me nuts.
  11. Nov 1, 2015 at 8:02 PM
    #231
    TacoDan723
    TacoDan723 Well-Known Member
    Dan
    Pacific Northwest
    2015 MGM Tacoma Limited
    Any chance this same idea could work with the B/U camera on the Entunes screen?
  12. Nov 14, 2015 at 10:09 PM
    #232
    Mightyniceunit
    Chevy
    Manitoba
    4X4 Tacoma SR5
    Hey Dan, it could be used for the Entunes screen mod... it uses the same type of switch it would just require some creative wire routing. So if your back up camera already displays on the head unit and you just want a selectable B/U camera its super easy. If you are trying to move the display from the mirror to the head unit... That's above my paid grade -I have no idea.
  13. Mar 10, 2016 at 5:25 AM
    #233
    leSoigneur
    leSoigneur New Member
    Craig
    '13 Tacoma trd
    Hey Guys,
    Super excited to do this mod this weekend. What gauge wire do I need?
    Cheers
  14. Mar 12, 2016 at 8:31 AM
    #234
    Mightyniceunit
    Chevy
    Manitoba
    4X4 Tacoma SR5
    I used 22 gauge wiring I had from a previous project. Once you see the size of the wire you are tapping into the 22 gauge will look huge. Good luck with your project!
  15. May 1, 2016 at 5:05 AM
    #235
    Sailorboy92
    Sailorboy92 Member
    Michael
    Michigan
    '15 Tacoma TRD Sport DBL Cab
    none so far
    This is a great mod and would love to have thid done ...... unfortunately my back-up camera on my '15 Tacoma TRD Sport is on the radio unlike my previous '13 Tacoma TRD Sport where it was on the rearview mirror
  16. May 1, 2016 at 9:45 AM
    #236
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    2010 Tacoma, sold...
    Although a switch still activates it when you shift into reverse. It is possible.
  17. May 1, 2016 at 11:51 AM
    #237
    Berniebikes
    Berniebikes Well-Known Member
    Bernie
    Williamsburg, VA
    2015 White TRD OR Double Cab
  18. Jul 21, 2016 at 8:28 PM
    #238
    duvinclunk
    duvinclunk Well-Known Member
    Davin
    Salt Lake City, UT
    2016 DCSB|OR|QS
    Does anyone have the part number for this cover? I took mine off to drill it for a switch and then it turns out the switch I bought didn't work and I'd have to buy another that uses a small hole.
  19. Jul 24, 2016 at 3:38 PM
    #239
    BLaPointe
    BLaPointe Well-Known Member
    Brandon
    Fairbanks, AK
    15 TRD Off-Road, White
    @Hunter.V.White, you could run a three way switch to run to a front, rear or off maybe for that rock cam conversation we had yesterday.
  20. Aug 26, 2016 at 5:46 PM
    #240
    Sly Dvl
    Sly Dvl New Guy with an Old Hat
    Kevin
    Fergus, ON, Canada
    '13 TRD
    I had raised the r/view mirror in my '13 TRD, so mounting the switch in the stem cover wasn't an option. I mounted a SPDT rocker switch on the side of the overhead console. Looks clean and I'm the only one who sees it.
    bremt3 and Mightyniceunit like this.
