09 Always-On Rear View Camera
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aalders, Jun 28, 2009.
  1. Jan 8, 2019 at 7:36 PM
    #261
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Not with truck now but when I flip the switch in the ‘always on’ position the trans indicator shows R when I am in Drive.
  2. Jan 8, 2019 at 9:49 PM
    #262
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    If Im not mistaken the red wire you cut the wire coming out of connector to mirror , goes to com terminal of switch . Other wire going to EDIT ( harness going back to truck harness under headliner ) goes to one of other outside terminal. Looks like you got it reversed . If I got time I can double check mine but been under the weather the last few days . :sick:
    EDITED about wire going back to headliner side
  3. Jan 9, 2019 at 7:23 AM
    #263
    HBMurphy
    Paul
    So California Coast
    None
    That would make sense why it wouldn't work. Let me know what you find. Thanks!!!
    Edit: Noticed this in the first post: "the lead that goes to the clip is soldered to post 2 (because that goes directly to the mirror)"
    THANK YOU!
    hemitruk[QUOTED] likes this.
  4. Jan 9, 2019 at 10:41 AM
    #264
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Yea just swap the 2 wires around and should be good :fingerscrossed:
    HBMurphy likes this.
  5. Jan 9, 2019 at 2:17 PM
    #265
    HBMurphy
    Paul
    So California Coast
    None
    I will update when I do.
  6. Feb 18, 2019 at 5:27 PM
    #266
    86250rrippin
    86250rrippin Well-Known Member
    Leechburg ,PA
    2009 Base Access Cab 4.0
    3 inch lift , 32's , updated grille , seat mod , camera mod ,cap w/ led inside lighting, stainless step bars, 32" light bar recessed ,ultra guage mx 1.3 ,mesa cutoms dome and maps , tw custom cupholder, OG husky liners. Need seat covers and bed rug and she is done !
    I did this mod the other day and it works perfect . If you choose the middle position ,the mirror view will stay off . I also tapped the 3 wires in the kick panel to tie to my aftermarket HU video input . Its a lil grainy at times ,will try a few chokes on it to see if they help at all. great mod !
  7. Oct 5, 2019 at 4:53 PM
    #267
    robfox
    robfox Well-Known Member
  8. Oct 5, 2019 at 4:57 PM
    #268
    13tacosport
    13tacosport Well-Known Member
    Arbi
    818
    13 Trd Sport
    I have a 2013 that displays the rear camera in the rear view mirror, I want it to display on the lcd screen head unit when I put the truck in reverse, all I will need is this wiring harness? Or a switch to press to activate camera when I want to reverse?
  9. Oct 5, 2019 at 5:02 PM
    #269
    robfox
    You'll need to do more than just get this part. I used this in conjunction with a switch to display the backup camera anytime to the LCD, but my camera was already routed to the screen.
  10. Oct 5, 2019 at 5:05 PM
    #270
    13tacosport
    Arbi
    818
    13 Trd Sport
    I was just speaking parts wise, I understand there are some cutting or re wiring etc,
  11. Oct 7, 2019 at 1:56 PM
    #271
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    Great little mod did mine also 2010 but bought a push button switch and installed it in one of the blanksDF79D44A-DD5D-4675-92EA-EE85E2B16078.jpg124AD216-230A-4E85-A83A-68321CA92789.jpg
  12. Aug 24, 2020 at 1:18 PM
    #272
    indaclear
    indaclear Active Member
    Yoshi
    WInston Salem NC
    2021 SR5 DCSB v6 4x4 auto
    Mostly stock but TRD pro wheels and 265/70/r16 tires and bed cap
    If you have a newer model rear view mirror, with the temperature and compass display, will it still cut off after 5 minutes and enter screen saver mode when the switch is engaged?
  13. Oct 30, 2020 at 8:41 AM
    #273
    rosqeaux
    rosqeaux Badjes?
    I'd like to do this mod but have an aftermarket camera I installed in the bumper since I removed the tailgate (with camera) to carry a camper shell. I now have two sets of guidelines superimposed on the image. The new camera instructions tell you to cut a wire to eliminate the lines for their camera, but I want to eliminate the ones from the OEM camera since they're now in the wrong place as the new camera is mounted at a different location and angle. Is there a way to get rid of the guidelines while doing this mod as well?
  14. Oct 31, 2020 at 5:16 PM
    #274
    xguntherc
    xguntherc Taco Time
    Cory
    East Dallas
    11 TRD Off Road - Black
    Icon Stage 5, Nexen Roadian MTX, Fuel KB43 Block wheels, Baja Design XL 80s, Baja Squad Pro WC fogs, TacoVinyl grill, "dudebro" lights, Prinsu rack, trail rash pinstripes, BAMF hybrid bumper, sliders, and LCA skids, and a few other things I can't think of.
    Can anyone tell me which wires are the power and ground. I have a 2011 with the JBL system and the backup camera in the mirror...
    It looks like the lime green is power but then on the backside facing the windshield there is three black wires.. are those ground?
    I'm thinking the white and black wire next to the green is ground
  15. Apr 29, 2021 at 2:02 PM
    #275
    Cosmo58
    Cosmo58 New Member
    Black 2007 Tacoma
    That is awesome. Not sure I'm smart enough to do this. I'll have to watch the video about 15 more times
  16. Jun 11, 2021 at 6:47 PM
    #276
    2kool4skool
    2kool4skool New Member
    William
    2009 Tacoma 4dr TRD 4x4
    Light bar, full skids, Snugtop
    I followed your directions on my 2009 Tacoma and it worked great. I can monitor my trailer occasionally during towing with a full bed of stuff. Thanks for the post.
  17. Sep 4, 2021 at 3:42 PM
    #277
    Spencer97TJ
    Spencer97TJ Well-Known Member
    Spence
    CT
    stock
    I had a new windshield put in, and my mod got messed up. I got it working again, but where does that red wire go to? Oddly enough the Mod is working fine without it.
