09-style backup camera on an 08 complete
Discussion in '2nd Gen. Tacomas (2005-2015)' started by camsbored, Dec 3, 2008.
  1. Apr 18, 2010 at 8:56 PM
    #61
    shredtacoma
    shredtacoma Well-Known Member
    Jace
    SOCAL
    07 Prerunner Debadged with snugtop
    Camburg lift, ProComp rims, Nitto Terragrappler tires, snugtop, Flowmaster exhaust and Airraid intake
    wut are the bolts for
  2. Apr 18, 2010 at 9:06 PM
    #62
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    This is too cool - I'm totally doing this! Nice write up :D
  3. Apr 19, 2011 at 11:51 AM
    #63
    EvilBetty
    EvilBetty Well-Known Member
    Kansas City, MO
    07 SR5 Access Cab
    Visor CD Holder
    How big is the opening on the tailgate handle?
    I'm looking at a couple camera options. One of them I like is a round 1 1/4" camera, but I'm not sure if it will fit.
    If that one won't work, many of these look like they may be able to fit almost perfectly.
    Toyota Rear-View Cameras on Amazon
  4. Apr 22, 2011 at 11:04 AM
    #64
    EvilBetty
    Kansas City, MO
    07 SR5 Access Cab
    Visor CD Holder
    Anyone? :(
  5. May 5, 2011 at 1:56 PM
    #65
    EvilBetty
    Kansas City, MO
    07 SR5 Access Cab
    Visor CD Holder
    :mad:
    Well I went ahead and bought one, measurements are 1.00 x 1.20 x 1.00" for the opening, and it points almost straight down. Maybe a 2-4 deg angle.
  6. Jun 2, 2011 at 10:55 AM
    #66
    EvilBetty
    Kansas City, MO
    07 SR5 Access Cab
    Visor CD Holder
    After a little modification to the opening I installed a IR camera from Amazon and a JVC Nav system. Pictures to follow.
    Thanks for the guide!
    Tips...
    Buy TWO screws when buying the tailgate handle. Part number is only for 1. These screws are used in the camera mounting holes.
    2. Drill into the tailgate with a regular twist drill bit, at a slow and steady rate. I ran out to Wal-Mart at 2:00 AM to find a 5/8's bit and ended up with a bullet bit. Then about 10 minutes later ended back at wal-mart for a small round file to clean up the mess of a hole that resulted in.
    3. When installing Double DIN in with the Scosche kit, you don't need the metal cage or factory bezel. Snap the side pieces onto the kit, install the Scosche bezel, and then slide in the radio only and install screws. Check alignment and tighten. Lets just say my bargain Scosche dash kit cost me double what it should have. :eek:
    4. Power the camera from the Red/White wire under the bed that goes to the taillight, and the reverse wire on the radio from the red/white wire behind the driver kicker panel. This will save wear on your camera and insure it cycles on and off properly. If you have some need to turn on the backup camera when not in reverse though, this won't work for you.
  7. Sep 6, 2011 at 8:22 PM
    #67
    mantry
    mantry Member
    Mark
    Salt Lake City
    06 Tacoma SR5 Sport Double LB
    Has anyone tried to pick up a 2009 handle from a salvage yard? Price?
    I'm interested in adding this to my 2006 DC.
    I will most likely use the Pioneer ND-BC4 that others have used.
    Seems to me that if you don't use a 2009+ Toyota handle that using the Pop and Lock PL 5300 handle will have a spot for the camera and you also get the locking ability also. Correct?
    Again, is it possibe to retrofit the Pioneer camera into EITHER the 2009+ handle or the PL5300?
    Thanks in advance!
  8. Sep 6, 2011 at 8:25 PM
    #68
    yotamikez
    yotamikez Street glide or die
    Valrico
    04 civic & 08 Street glide
  9. Sep 7, 2011 at 12:00 PM
    #69
    mantry
    mantry Member
    Mark
    Salt Lake City
    Ordered the PL 5300 and will see about mounting that in my 2006. I'll report back. Plan on then having them mount the PIoneer ND-BC4 camera into the camera spot on the handle.
  10. Sep 14, 2011 at 8:16 PM
    #70
    mantry
    mantry Member
    Mark
    Salt Lake City
    Received the PL 5300 tonight from Amazon and sure enough it has a spot for the factory camera. Whipped off the tailgate cover and 5 mins later, handle is installed on my 2006 DC and now it is ready to install a camera in. This will be much better than putting it down by the license plate somewhere. It will be out of the moisture, snow, rain, mud, etc, etc!!!!
    Thanks everyone!
    The handle was a direct bolt on, fits perfect, even though Pop and Lock says it is for 2009 and UP.
  11. Sep 19, 2011 at 12:03 AM
    #71
    ToyComa92
    ToyComa92 Write your love, Then your anger.
    Jon
    Conifer, Colorado
    2006 Tacoma TRD sport Debadged
    Heated katzskin leather, Black TRD sport wheels, Bilstein 5100s, Toytec 2" Springs, Deaver 2" AAL, Pioneer AVH4400BH, Ultragauge, Weathertechs front/rear,
    Probably a stupid question, But would it be easier to find a 2009+ full tailgate and just do a swap?
  12. Oct 4, 2011 at 5:04 PM
    #72
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    not a stupid question, I think it would be easier too, but it looks like tailgates with cameras can be much more expensive
  13. Oct 4, 2011 at 5:10 PM
    #73
    mantry
    mantry Member
    Mark
    Salt Lake City
    I did call a couple of salvage yards in the SLC area looking for a handle and did not find any.
  14. Oct 4, 2011 at 8:26 PM
    #74
    nammer
    Nam
    Bradenton, Florida
    you should try car-part.com, sometimes you can find good parts for decent prices
  15. Oct 20, 2011 at 6:43 AM
    #75
    1Falconer
    1Falconer New Member
    Ron
    Oregon
    '06 Extended Cab 4wd
    backlit 4wd selector, air bags, 2 1/2" lift, K&N intake, 120V by-pass and plugs in cab, tinted glass all around
    Thinking I may want to retro a back-up cam on my '06. What kind of cost am I looking at to do something like this. Would love to find a junked Taco with a stock cam and mirror and keep it stock per-say, unless of course there is a better way to go at it. Thanks in advance for any and all help.
  16. Mar 8, 2013 at 3:11 AM
    #76
    TRDsport253
    TRDsport253 Well-Known Member
    Edgewood, Wa
    2021 TRD sport 4x4
    TRD Wheels TRD Skid plate
    Op what brand is that indash install kit?
  17. Mar 8, 2013 at 4:35 AM
    #77
    camsbored
    camsbored [OP] Well-Known Member
    Raleigh, NC
    08 PreRunner DC/Sport/LB
    Kenwood DNX8120, Homelink mirror, Valentine One hardwire
    It's the Scosche kit - got it on eBay in May of 2008.
    #77
  18. Mar 8, 2013 at 12:26 PM
    #78
    EvilBetty
    Kansas City, MO
    07 SR5 Access Cab
    Visor CD Holder
    Anyone had any trouble with that kit banging in the dash when you're on rough roads?
    The OEM brackets are metal. It seems these being plastic is letting it flex and bag my DDIN unit around a bit. I don't like the sound of it either. :rolleyes:
  19. Nov 10, 2013 at 6:57 PM
    #79
    ryantaco
    ryantaco Well-Known Member
    SoCal
    06 DC Long Bed TRD Sport
    Has anybody tried putting the rear view mirror with the screen on the actual mirror part( i have seen it on the 2011+ 4Runners) into a tacoma??
  20. Nov 21, 2013 at 8:33 AM
    #80
    ppleasants
    ppleasants Well-Known Member
    virginia
    05 TRD Sport Doublecab Longbed
    5100's set at 2.5", toytec AAL, DIY AUX port, broken mirror fix, temp/compass fix (twice), rattle-can gunmetal sport rims, debadged doors, fog-light anytime mod, DTRL mod, rear differential breather mod, drop in K&N air filter
    Yes, look back in this thread.
    I did mine for about $60-80 because I found the parts in a salvage yard and used some 4 or 5-wire water-proof cable from Home Depot (I think for sprinkler systems). It's just a matter of splicing it into the existing wiring harness and running it with the stock wiring through a hole under the seat and then a long the frame to the tailgate. As long as you do the work yourself and you get lucky finding the parts at a salvage yard, the cost is really reasonable.
