09 Tacoma cranking, will not start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by misiunike, Dec 7, 2010.
  1. Dec 7, 2010 at 5:17 PM
    misiunike
    misiunike [OP] Member
    Bought this car as is without testing it, got it and big surprise - will crank but will not start. Checked almost everything fuel system - OK, ignition system - missing spark on 1, 5, 6. Changed spark plugs, checked ignition coils, all the related sensors - seems to be OK. Scoped ECM outputs, and sure enough no signals on IGT1, IGT5, IGT6. Tried to get used ECM to repalce it but it is hard to get. Everybody sends me 89661-04C70 whitch is for 08 and try to tell me they are compatible with 89661-04D40. Am I missing something, or will it be bad ECM.
    09 Tacoma, V6 4.0, 4x4
    Thanks for help
  2. Dec 7, 2010 at 5:21 PM
    98tacoma27
    Ben
    Not Beech Creek
    Do you have a transponder key?
  3. Dec 7, 2010 at 5:21 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    wait you just bought the truck and it wouldnt start when you got in it??
  4. Dec 7, 2010 at 5:52 PM
    kessler89
    kessler89 Well-Known Member
    OH
    12' Pro4x 6MT
    TBA
    Is it really cold where u are? Try some dry gas, just happened to my g/f last week, she had less than 1/4 tank and must have had alot of water built up, froze her lines
  5. Dec 7, 2010 at 6:29 PM
    trd09
    trd09 Well-Known Member
    Chuck
    NW Ark
    17 TRD Pro 6AT
    warranty?
  6. Dec 7, 2010 at 6:53 PM
    misiunike
    yes I have transponder key,
    No warranty, it has over 40K (warranty only up to 36k or 3 years whatever comes first),
  7. Dec 7, 2010 at 6:55 PM
    PB65stang
    PB65stang Well-Known Member
    Patrick
    Kansas City
    2016 F150 Lariat 4x4
    5100s (2.5" front), OEM Raptor wheels, 315/70/17 BFGs, Undercover, tint, Weathertechs.
    60K on powertrain. If it won't start I'd be tempted to say you have an argument that your issue is "powertrain" related.
  8. Dec 7, 2010 at 6:58 PM
    98tacoma27
    Ben
    Not Beech Creek
    And you have no codes?
  9. Dec 7, 2010 at 7:01 PM
    misiunike
    no codes, unless sb ereased them all before I got it
  10. Dec 7, 2010 at 7:11 PM
    98tacoma27
    Ben
    Not Beech Creek
    I find it odd that you are missing three signals to the ignition coils. Do you have the other three signals? Based on what you have said and posted, it appears to be ECM related (if you have the other three signals-IGT2,3, and 4)
  11. Dec 7, 2010 at 7:35 PM
    98tacoma27
    Ben
    Not Beech Creek
    The only other thing I can think of is an issue with the crank and/or cam shaft sensors. They should have thrown a code though.
  12. Dec 7, 2010 at 7:35 PM
    misiunike
    Yes, I have other 3. I was just wondering if maybe I'm missing smth. I'm still trying to get replacement ECM to test if mine is bad.
  13. Dec 7, 2010 at 7:37 PM
    misiunike
    I scoped the crank shaft/ cam shaft sensor input at ECM and it appears to be good. As far as the code I don't know if it is doing diagnostics right away after I turn Ignition switch, or when it is running ?
  14. Dec 7, 2010 at 7:40 PM
    98tacoma27
    Ben
    Not Beech Creek
    Does it even try to fire? or just crank like there is no gas too?
  15. Dec 7, 2010 at 7:51 PM
    misiunike
    It cranks and it is firing too. Sometimes it runs for 10 sec and it dies.
    It is getting the fuel, every single spark when removed is wet, missing spark is the problem, I think.
  16. Dec 7, 2010 at 7:52 PM
    98tacoma27
    Ben
    Not Beech Creek
    I am inclined to agree with your ECM diagnosis. Is there any aftermarket electrical equipment installed?
  17. Dec 7, 2010 at 8:08 PM
    TorenApart
    TorenApart Well-Known Member
    06 Double Cab SR5 TRD Sport
    Toytec Ultimate Lift Kit, OME Nitrocharger shocks and Dakar leafs, Total Chaos UCA's, 18'' Black XD Monster, 285/60R18 Cooper Zeon LTZ, Leer shell, OEM Skid Plate, Weather Tech Floor Mats, Lund Tonneau, Custom 2-tone gray leather, Aero Turbine 2525 muffler with AR25 resonator, Aero Turbine Exhaust Tip, Mr. Marv subwoofer enclosure w/ 2 JL 10W3v2's, AFE Pro Dry S, Eclipse AVN-6620, Pioneer PRS-D2100T, Hybrid Audio Clarus 6.5'' Front Components, Black Headlight Mod, Tinted tail lights, PL5300 with Eclipse BEC-109
    2 weeks ago my GF's car wouldn't start b/c the engine flooded (yes a modern fuel injected car can be flooded) Hold the gas down all the way and crank the key for about 10 seconds. This will burn of excess gas.
    Then try to start it.
    May seem dumb, but worth a try...
  18. Dec 7, 2010 at 8:09 PM
    98tacoma27
    Ben
    Not Beech Creek
    There's no spark on three cylinders from the ECM.
  19. Dec 7, 2010 at 8:09 PM
    misiunike
    No there is not. Guess I will try to find sb who can check ECM without whole car, so I wont have to drag it to the dealer.
  20. Dec 7, 2010 at 8:10 PM
    TorenApart
    Ok...what do I know:confused:
