09 Tacoma - Vibration when slowly accelerating
Discussion in '4 Cylinder' started by cj30241, Apr 12, 2009.
  1. Apr 12, 2009 at 11:56 AM
    cj30241
    cj30241 [OP] Member
    Georgia
    2014 Tacoma-Auto 4-Cyl
    09 Tacoma 4-Cyl Auto Access Cab.
    No modifications.
    Apx 7,000 miles.
    Vibration when slowly accelerating, usually between 28-30 MPH and again 38-40 mph.
    Noticed it a few times when decelerating.
    Reminds me of going over those 'slow down' strips in the road.
    Any idea what this is?
  2. Apr 13, 2009 at 9:51 AM
    blacktacodude
    blacktacodude New Member
    08 Tacoma
    I have the same problem on my 08 Automatic. I would call it more of a shudder inbetween shifts. But it doesnt do it all the time.
    I took it in, they said it was the Torque converter and replaced it. Seemed to help for a little while but it is doing it again.
    Hopefully we get a solution to this.
  3. Apr 13, 2009 at 11:08 AM
    SLOsurfer
    SLOsurfer Member
    San Luis Obispo, CA
    05 5spd 2.7L Reg Cab
    something similar happened to me. i ended up doing all kinds of maintenance: spark plugs, oil change, air filter, checked for loose bolts, etc. ended up fixing it, but it's too late to pinpoint it.
  4. Apr 13, 2009 at 7:13 PM
    wawireguy
    wawireguy Well-Known Member
    It's under warranty. Something isn't right. Make em fix it!
  5. Apr 14, 2009 at 7:33 AM
    06dak
    06dak Well-Known Member
    Central Ohio
    05 PreRunner SR5 4cyl
    Undercover hard tonneau, Husky front liners
    I have a similar thing... almost remided me of an old Ranger I had when the heat shield and U joint went out on it. Mine does it at low RPMs in low gears (it's a manual).
    Let us know if you get it fixed what it was...
  6. Apr 18, 2009 at 10:16 AM
    cj30241
    cj30241 [OP] Member
    Georgia
    Taking it in to the shop next weekend. I'll post the results.
  7. Apr 18, 2009 at 10:55 AM
    Who Dat Popcorn
    Who Dat Popcorn Dafuq
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    Mine use to do it a lot when I first got it. Now, at 14,000 miles, it doesn't do it as often.
  8. Apr 22, 2009 at 4:47 PM
    ldmarcht931
    ldmarcht931 Member
    Arizona
    09 TRD Sport
    bedliner, camper shell
    Please let me know what they do to resolve the problem. I'm having a similar issue.
    thanks
    LM
  9. Apr 22, 2009 at 4:51 PM
    EBruddah
    EBruddah Well-Known Member
    626 - SGV / RakiRaki, Fiji
    05 TRD Off Road 4X4 - OME Built to Wheel!
    2005 Tacoma V6 SR5 - 4WD AC TRD Off Road - 6 Speed M/T Full OME Lift w/886 Coils & Dakars,, Optima Yellow Top, Cobra NightWatch 29 WX NW ST - CB Peaked/Tuned + talkback/confirmation tone - PA Horn, Lil Will CB Antenna, Downey Off Road Extreme Duty CV Boots, 255/85/R16 BFG Mud-Terrain T/A KM, All-Pro Sliders, Drop in K&N FilterCharger, Flowmaster 40 Series, 62” Hi-Lift Extreme Mounted in Bed w/all Hi-Lift Accessories. Custom Skid Plate by Defined Engineering, 10 lb. PowerTank with HPX Regulator
    Check your U-Joints on your driveshaft....
  10. Apr 23, 2009 at 8:35 AM
    ldmarcht931
    ldmarcht931 Member
    Arizona
    09 TRD Sport
    Thanks for advice. the dealer loosened the front and back u joint, gave the whole assemblage a vigorous shaking and tightened every thing back down, which seemed to lessen the symptoms by about 50%.....
    I'll keep posting as new things happen.
    LM
  11. Apr 26, 2009 at 8:09 AM
    cj30241
    cj30241 [OP] Member
    Georgia
    2009 Tacoma-Auto 4-cyl
    I received a tip that a Service Bulletin is posted on this exact issue. I took the truck to the dealership and told them in great detail what it was doing. At Slow steady acceleration I would feel something reminded me of going over a mild set of those 'slow down' strips in the road. Would happed between 28-30 mph and again @ 38-40. Related to shifting. It's Automatic.
    They did my 10,000 service, and were supposed to check this out. Tech came out saing all looks good...that will 54.95 for the service. No mention of the problem!! :mad:
    I found another tech Manager, went over the whole things with him and told him to look up T-SB 0096-09.
    He found the SB, re-checked the truck, couldn't make it replicate the shuddering but wrote it up anyway as if he did so it would be covered under warranty, recalibrated the ECM -engine control module.
    I've driven it for 2 days and it seems fine now. :)
  12. Jul 23, 2009 at 5:28 PM
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
  13. Jul 24, 2009 at 9:56 AM
    The Shape
    The Shape Well-Known Member
    Forrest City, AR
    '09 Access Cab A/T 4banger
    Never noticed this on my '09 acces cab, but now I will be paranoidly checking for it! LOL :D
  14. Jul 24, 2009 at 5:02 PM
    Pbucks
    Pbucks Well-Known Member
    Montgomery County, Md
    09 SR5 Access (sold)
    None yet
    I have the same truck and have not experienced any vibration at all. As matter of fact I'm constantly amazed it is a 4-banger I'm driving because it is so responsive and smooth.
    Pete
  15. Feb 21, 2014 at 7:42 AM
    Major8865
    Major8865 Member
    Floyd
    Nh
    08 Tacoma 4wd
    None
    Did recalibrating the ECM help?
    Toyota wants me to fork over 4000.00 for a new transmission
    Yah right
    Frank
  16. Feb 26, 2014 at 4:42 PM
    cj30241
    cj30241 [OP] Member
    Georgia
    Yep, fixed it. Crazy thing is, I now have a new 2014 and a couple of times I think I've felt the same thing but much milder than the '09 & couldn't remember what it was "ECM" until you msg'd me! Since I was able to find a SB on it for the '09 and it was only a few months old at the time, and got a friendly service rep I was able to get it done under warranty. He couldn't replicate the issue, but since I was so convincing that I knew what I was talking about ((due to extensive research)) he wrote up the ticket as if he did experience himself and it didn't cost me anything.
