1/2 inch block or aal that lift only 1/2 inch
Discussion in 'Suspension' started by KaliTaco, Oct 7, 2008.
  1. Oct 7, 2008 at 10:51 PM
    KaliTaco
    KaliTaco [OP] Well-Known Member
    getting the tsb done and got billys on order. setting the front to 2.5 and with the rear tsb my measurements for my truck should be from what i read here is front 2.5 inch rear is 1 inch. maybe .75 after it settles. that makes my truck sit pretty level. maybe higher in front .25 inch. because the different is 1 1/2 inch from what i measure today when i dropped it off to get the tsb done. im thinking of putting 1/2 inch blocks or aal that will only go 1/2 inch. i see block and leaf that will do 1 inch. not 1/2 or 3/4. reason being is that it sits level but with a load it will sit high in the front. i dont want to buy new rear springs because im not offroading just street driving. so is there any brand that makes those size blocks or leaf springs?
  2. Oct 7, 2008 at 10:53 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    check with wheelersoffroad and toytec and see what they have to offer.
  3. Oct 7, 2008 at 10:55 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    i havent seen anything smaller than 1".
  4. Oct 7, 2008 at 11:08 PM
    KaliTaco
    i checked both and nothing. hmmmm....what can i do to get back to stock rake without breaking the bank.
  5. Oct 7, 2008 at 11:13 PM
    RelentlessFab
    Eric
    Sparks, NV
    only thing i can think of: disassemble the leaf pack, insert a 1/2" thick steel "spacer" that has been center drilled into the pack and then torque it in with a new longer centering bolt and held by some longer U-bolts. sort of like a flattened AAL thats just shorter...... probably not a good idea though:rolleyes::eek:. on second thought..... really not a great idea but i think i've seen some worse stuff. lol
  6. Oct 7, 2008 at 11:41 PM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    You could take out the load leaf & put in the aal from ToyTec.That would put you at 1.5 or 2" over stock height.
  7. Oct 7, 2008 at 11:58 PM
    KaliTaco
    i might just do the 1 inch blocks now since 1/2 block don't exists. i would do a new leaf pack but that cost alot more then want i wanted to spend. im looking for somewhere in the 100 bucks range for parts. so 1 inch block and the new rear tsb installed. will the stock shocks be at the max? would that damage my shocks? dont tell me i have to upgrade shocks now!
  8. Oct 8, 2008 at 12:22 AM
    Ridingontrd
    Richard
    Laughlin,N.V
    2" lift in the back is max on the stock shocks.At the bottom of the page link is a shock extender for $10.A block on top of the tsb will make for a stiff ride.
  9. Oct 8, 2008 at 12:33 AM
    KaliTaco
    so if i do the tsb and 1 inch block and get these shock extenders and that would work? but stiff ride? this is the first time i came across these extenders. sorry im new to these things. just reading as much as i can and when i get stuck i ask. thanks for helping!
  10. Oct 8, 2008 at 12:37 AM
    Ridingontrd
    Richard
    Laughlin,N.V
    Yes,They'll work.Gives back 1" of down travel.
  11. Oct 8, 2008 at 12:46 AM
    KaliTaco
    thanks i just did some reading on the shock extenders and everyone seems to like it and it works great. i will do that. why not its only 10 bucks! thanks for your help.
  12. Oct 8, 2008 at 1:07 AM
    Ridingontrd
    Richard
    Laughlin,N.V
    You're welcome.:)
  13. Oct 8, 2008 at 4:11 AM
    FloridaTaco
    FloridaTaco Well-Known Member
    Orange Park Florida
    2010 Doublecab Longbed TRD Sport
    Kalitaco, You don't need to waste your money on shock extenders on a 1" block:cool:. And a 1" block or 2" block far as that matters will NOT, let me repeat will not affect yor ride. Now if you plan on runnig the baja 1000 or rock crawling that may be a different story........
  14. Oct 8, 2008 at 8:44 AM
    RelentlessFab
    Eric
    Sparks, NV
    i've seen these before but does anyone know if they'll bolt on to a set of 5100's? my rear shock top out if i bomb down any logging roads or if one tire drops off of a rock too quickly. thanks
  15. Oct 8, 2008 at 11:36 AM
    KaliTaco
    im getting the tsb and 1 inch blocks for now. if my shocks start to bottom out then ill get some extenders. but my main goal was just to lift it with 1/2 inch blocks.
  16. Apr 5, 2017 at 9:39 AM
    Member1Zillion
    Member1Zillion Involuntary Kamikaze Co-Pilot
    Big Whiskey, WY
    '01 TRD, '17 Tundra, '07 FJ Cruiser, 94 PU, '18 T4R, '84 PU
    This, that, & the other thing
  17. Apr 5, 2017 at 11:12 AM
    LiquidDragon
    LiquidDragon Well-Known Member
    Michael
    Williamsburg, Va but now in the Philippines
    2021 Toyota Hilux Conquest 4x2
    none yet
    RelentlessFab likes this.
  18. Apr 5, 2017 at 11:14 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    He says while breathing life into said 9 year old thread with another post.
    You're going to have a heart attack if you're that high strung. Thread necro didn't bother me a'tall.
    ZebraScissors and Tomji like this.
  19. Apr 5, 2017 at 11:33 AM
    LiquidDragon
    Michael
    none yet
    it doesn't really bother me when someone revives a thread because they are looking for an answer to the same issue but when someone revives a thread to offer help for an issue that happened 9 years ago that is just................
    kryten and Member1Zillion like this.
  20. Apr 5, 2017 at 11:37 AM
    T4RFTMFW
    smitty99 likes this.
