1/4" or 1/2" driver? (Impact driver)
Discussion in 'Technical Chat' started by SCFirefighter, Nov 24, 2011.
  1. Nov 24, 2011 at 11:56 AM
    SCFirefighter
    SCFirefighter [OP] on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    I'm in the market for a portable impact driver. I saw it in use on a trail last weekend. I never thought about owning one but it makes changing tires a breeze.
    Now all I have at home is a 1/4" hand tool with sockets etc.
    Is there a benefit to the 1/2" driver? If I get the 1/4" I can re-use my existing sockets - or is that a bad idea? Will I be ruining my sockets?
  2. Nov 24, 2011 at 12:01 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    1/4" will not have enough torque to do wheels.
    Get a 1/2" and a set of sockets to compliment it.
    As batterys wear down they will lose torque also making the need for more power important out in the bush.
  3. Nov 24, 2011 at 12:02 PM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    +1
  4. Nov 24, 2011 at 12:08 PM
    SCFirefighter
    Stephan
    Cary, NC
  5. Nov 24, 2011 at 12:17 PM
    OH-MAN
    Sunny Az.
    10 4X4 O.R. White
    That is a good one I have 2 one in each of my trucks.
    I rotate the battery packs 2 with the impact in the box and one in the charger in the garage.
    If i am going out on a trail trip I charge both before going to make sure I have them ready.
    I also use 18 volt DeWalt tools at home so I have the extra batterys going for them as well.
  6. Nov 24, 2011 at 12:25 PM
    SCFirefighter
    Stephan
    Cary, NC
  7. Nov 24, 2011 at 12:31 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    Dude, if you only have a 1/4" drive ratchet and sockets you don't have much.
    Tool up and go with a 1/2" drive "rattle gun" (impact driver).
    I'm in heavy construction and lately we've been using the impact sockets from Harbor Freight and they've been holding up.
    Bona fide impact sockets are almost always 6-point and of high carbon steel. They are usually black in color and expensive except for the Harbor Freight (China) sockets mentioned above.
    A rattle gun can destroy normal sockets especially if they are 12 point.
    Don't hurt yourself, firefighter :p
  8. Nov 24, 2011 at 12:34 PM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    I would like to get one, it's what made my lift so easy to install.
  9. Nov 24, 2011 at 2:53 PM
    SCFirefighter
    Stephan
    Cary, NC
    Yeah, I know. I installed my entire suspension kit (Toytec coilovers plus TSB AAL, 5100 x4) using a set of Taskmaster hand tools. It's time to upgrade :)
    Haven't gotten hurt yet!
  10. Nov 24, 2011 at 2:59 PM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    I doubt you could even get a 1/4 inch drive to loosen your lug nuts at all. Why not save yourself the money and hassle of batteries and buy something like this http://www.amazon.com/Wagan-EL2257-...NJQ6/ref=sr_1_4?ie=UTF8&qid=1322175482&sr=8-4
    You'll never have to worry about having a dead battery on the trail, or have to switch out batterys every month or so.
  11. Nov 24, 2011 at 3:05 PM
    Takeem029
    Takeem029 Well-Known Member
    I have a 1/4" and a 1/2" cordless impact. Go with the 1/2". The 1/4" works good for my wheeler's and snow machines. It sometimes has some problems with the lug nuts on the wheelers. 1/2"=no problems.
  12. Nov 25, 2011 at 6:54 AM
    saugus
    saugus Well-Known Member
    I wouldn't torque down with 1/4" on anything above 14mm. For lugs 1/2" cordless minimum.
    Also, I would not suggest torquing down the nuts with any portable driver. I would be too paranoid that the torque setting might be off.
  13. Nov 25, 2011 at 7:01 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Did you read the Amazon reviews on that 12v wrench you linked? That things a piece of junk!
  14. Nov 25, 2011 at 7:19 AM
    [eric]
    [eric] Well-Known Member
    Eric
    Bend, OR
    2005 Tacoma TRD OFF Road
    do impact drivers have a torque setting on them?
  15. Nov 25, 2011 at 7:24 AM
    OH-MAN
    Sunny Az.
    10 4X4 O.R. White
    Do not rely on a rattle gun for the torque setting.
    Run the nuts in wth them snug and use a real torque wrench to set the final load.
  16. Nov 25, 2011 at 7:25 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Some do, but they tend not to be real reliable and it's best to use a torque wrench to set the final torque, even if using power tools to spin a bolt or nut into place.
  17. Nov 25, 2011 at 9:19 AM
    saugus
    May be junk compared to $100+ tools, but sure comes in handy when you're tired and need to spin off lugs in a pinch with the front wheel off the ground and spinning freely.:cool: I have a harbor freight version that I payed $30 for. It does the job.
  18. Nov 25, 2011 at 10:25 AM
    jflan
    Vancouver, WA
    Agree.
    Never, ever rely on a rattle gun (impact driver) for final torque on a mission critical part.
    Whether it's a lug nut or a tilt-up brace, always use a torque wrench to dial in final torque.
    Big period on the end of that.
