1/4" Wheel Spacers
Discussion in 'Wheels & Tires' started by 90YotaPU, Sep 18, 2011.
  1. Sep 18, 2011 at 1:59 PM
    90YotaPU
    90YotaPU [OP] The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    Has anyone ever used these 1/4" wheel spacers they have at Pep Boys? I bought a set of used Eagle rims and with my Spidertrax spacers on, they rub like crazy. Without the Spidertrax, I'm just barely scraping the outside edge of the caliper. Looking at replacing the front studs with slightly longer ones and then putting on a 1/4" spacer. I see Wheeler's has one on their website too for this purpose.
  2. Sep 18, 2011 at 2:02 PM
    kite
    kite Well-Known Member
    Squamish, BC
    Red Truck
    They should work fine. Just make sure the center bore matches and you buy extended studs.
  3. Sep 18, 2011 at 2:33 PM
    Priddle
    Priddle And now for something completely different....
    St. John's, NL Canada
    2014 Tacoma 4x4 TRD Sport DCSB
    Current: Pelfreybilt front and rear bumpers, winch, icon front coils/shocks, Icon rear shocks, Dakar leafs, Camberg UCAs, Pumpkin Android stereo, custom sub box w/ 2x10" RF subs and Kicker amp, short shifter kit, Fuel Beast 18" wheels w/ 1mm offset, BFG AT2 285/65/18
    Can you post a link to those spacers? The search on their site comes up with nothing.
  4. Sep 18, 2011 at 4:35 PM
    90YotaPU
    Union County, NJ
  5. Sep 18, 2011 at 5:00 PM
    Priddle
    I just found that a minute ago. On the 95-04 page, they have the extended lug nuts, and in black. I have the spline drive nuts for my XD wheels. I figure I could get the 1/4" spacers for all fours and the ext lugs. I doubt the 95-04 factory ext lugs would work on a 05+ stock wheel?
    Dom't mean to hijack the thread, but it may help the OP too.
  6. Sep 18, 2011 at 5:06 PM
    kite
    Squamish, BC
    Red Truck
    You don't need extended lugs, you need extended studs.
    When you throw a spacer on, the amount of threads in contact decreases. You might still have enough holding but would need to figure that out for your self.
  7. Sep 18, 2011 at 6:16 PM
    Priddle
    I guess one would have to see how far the lug screws on now. Of there is a 1/4" gap already, the spacer and ext threads would work. If there is no gap to the wheel mount, then the extended studs would be needed.
  8. Sep 18, 2011 at 6:18 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Extended thread lug nuts are also an option
  9. Sep 19, 2011 at 2:35 PM
    Priddle
    I got to clarify...if with the current setup I have 1/4" of bare stud thread inside the wheel, then once I put on the spacer, an extended lug nut that is 1/4" longer than stock will get back that lost 1/4" from the spacer by using that unused thread inside the wheel.
    I just need to test that hypothesis. :cool:
  10. Sep 19, 2011 at 2:41 PM
    KPT
    09 Prerunner
    An extended lug that has a 1/4" shank will gain it back.
    The overall length of the lug nut doesn't matter, it's the shank depth.
    For reference, the "shank" is the portion measuring 0.30" in the top row of the diagram below, stolen from gorilla's website.
  11. Sep 19, 2011 at 5:24 PM
    Priddle
    Thanks for that!
