1.5" AAL + shim = ubolt length?
Discussion in 'Suspension' started by RRDave, Jan 31, 2011.
  1. Jan 31, 2011 at 10:13 AM
    RRDave
    RRDave [OP] Well-Known Member
    Halifax, NS
    08 Black TRD
    CAI, AT2525XL, 2.5" spacer, 1.5" AAL, DNX6140 HU c/w rearview cam, Fog Light Mod, Custom rear dog seat,
    Hey everyone,
    I'm about to install a 1.5" AAL on my truck and I suspect I will need longer u bolts than what's currently there. I think the typical length for a block lift in the back is 8.5" however a local shop has 8" ones in stock. Would these work? Otherwise I can get the to make me a set of any length. Any input would be greatly appreciated.
    Also, can anyone confirm the size of the current u bolts? From what I understand they are 9/16" diameter, 2.5" wide and 8.5" long (for the block kit anyway).
  2. Feb 7, 2011 at 1:43 PM
    MartyMcfly
    MartyMcfly Time Traveler
    Rob
    Pahrump Nevada
    15' 4runner Limited 4wd
    see Build page for details.
    I don't think Ubolts will be a problem. My Toytec 3" AAL didn't come with Ubolts, and I didn't need them either. The kit re-uses the stock Ubolts. It's when your'e adding blocks instead of a leaf that you'll need longer U bolts. However, you may need a new/longer centering bolt.
  3. Feb 7, 2011 at 1:45 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I bought the 2" AAL from Toytec and got the 7 1/2" U-Bolts just in case. I wanted to replace them anyway....Worked out perfect
  4. Feb 7, 2011 at 11:08 PM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    I have the 1.5" add a leaf and re-used the stock u bolts. The longer u bolts hung down so low it looked stupid IMO
  5. Feb 9, 2011 at 5:36 AM
    RRDave
    Halifax, NS
    08 Black TRD
    So I have the 1.5" AAL installed with 3 degree shims. Before hand I had a local spring shop make me some 8.5" ubolts which I used during the install to avoid the off chance the stock u bolts weren't long enough. I retrospect 8.5" was probably a bit long but everything worked out ok. If anything, if you're replacing the u bolts and they don't come with the lift kit, I would say just go ahead and get a u bolt flip kit...but hindsight's 20/20.
