1" block with 2" AAL
Discussion in 'Suspension' started by EmoSlayer, Dec 17, 2009.
  1. Dec 17, 2009 at 3:02 PM
    EmoSlayer
    EmoSlayer [OP] METAL!
    Scott
    PA
    TRD Off-Road
    Bilstein 5100s all 4 corners, front set at 0.85 w/ eibach coils metalcast red, driver's side lean spacer, rear tsb leaf pack with tsb aal from toytec, 265/75/16 goodyear wrangler authority, MT Classic III 16x8 4.5bs, LR UCAs
    Anyone running 1" rear blocks along with the OME 2" AAL? I have the 2" AAL installed but it has settled about an inch since install so truck sits level, want a little bit of rake so plan on adding the 1" block from toytec, any issues with doing this?
  2. Dec 17, 2009 at 3:12 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I was wondering the same thing. I'm sure you can, just need to get longer U-bolts. We will see what people have to say.:D
  3. Dec 17, 2009 at 3:15 PM
    EmoSlayer
    Scott
    PA
    TRD Off-Road
    yea the ones from toytec come with longer u-bolts
  4. Dec 17, 2009 at 3:55 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    i had a 2" block w/ tsb springs on the 07 and as long as u have longer u-bolts thats the first step, but getting over 2" of lift in the back u'll need longer shocks to keep from topping them out...that or shock extenders
  5. Dec 17, 2009 at 3:58 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Oh yeah your right. I have 5100's so those are made for 0-2" of lift only. Hmmm? Glad you brought that up.:cool:
  6. Dec 17, 2009 at 4:04 PM
    jhodge83
    SC
    17 XLT Sport
    i wheeled w/ shock extenders....not the best, but it worked til i upgraded
  7. Dec 17, 2009 at 5:10 PM
    EmoSlayer
    Scott
    PA
    TRD Off-Road
    do you think the rear ome shocks could handle the 2" aal and the 1" block? as far as travel of the shock
  8. Dec 17, 2009 at 5:34 PM
    jhodge83
    SC
    17 XLT Sport
    if they will handle 2-3" of lift, then yes....i'm not sure what they are quoted to be capable of handling
  9. Dec 18, 2009 at 3:58 AM
    EmoSlayer
    Scott
    PA
    TRD Off-Road
    i've got the toytec 1" block with longer ubolts in the mail, i'll let you know how it goes and post up some pics ww firefighter
  10. Dec 18, 2009 at 1:32 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    if you combine the two for a 3" lift in rear, you may need 4.5" to 5" up front to level the truck out...
    unless you are trying to get the drag racer look...
    someone one here had an issue of combined lifts and his truck looks crazy...
  11. Dec 21, 2009 at 4:44 PM
    waltonhockey17
    waltonhockey17 Well-Known Member
    Alex
    georgia
    08 DC Red Taco
    4" camburg spindles, billys at 0", 16" xd hoss rims, 285/75/16 xtreme mud terrains
    post pics soon;)
  12. Dec 22, 2009 at 6:38 AM
    EmoSlayer
    Scott
    PA
    TRD Off-Road
    hopefully i'll be able to put them on thursday
