1" Body Lift 04 tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by 757yotas, Oct 12, 2016.
  1. Oct 12, 2016 at 3:26 PM
    757yotas
    757yotas [OP] Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Does anyone have an videos or how to's on doing a body lift on a 01-04 tacoma? Also any good kits i should look at? I want a 1" kit.
  2. Oct 12, 2016 at 3:33 PM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Don't do it.
  3. Oct 12, 2016 at 4:00 PM
    757yotas
    Virginia
    2007 TRD Sport
  4. Oct 12, 2016 at 7:23 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    a 1" - 1.5" body lift is fine...
    more then that and doing so incorrectly can cause damage.
    The body to chassis additional spacing creates
    increased leverage/stress to the securing bolts.
    So I recommend using the grade 8 bolts.
    At least I did.
    don't listen to the "chicken little" claimers
    they know not what they say or never had one.
    I would only recommend the 4crawler (rogerbrown) body lifts.
    and not to exceed 2" lift... ever.
    I have the 4Crawler 1" BL
    and it has been installed since '04
    I've had no issues with it...
    even under extreme use/duty.
    There is a new maintenance involved tho'
    because if ya stretch/flex out the chassis off road often...
    You'll want to revisit and retorque those bolts.
    to ensure they are staying tight.
    Mine have stayed tight...
    and it's likely because the nylock nuts
    do their job and hold well.
    There are write up articles and "how to's" on google, youtube and TTORA
    possibly even here.
    If ya can't find one... I'll post up what I needed do
    Difficult maybe to first understand...
    but once read thru... a better understanding will be had.
    and the 4crawler link below is most helpful...
    basically every inquiry/email made to this proprietor...
    will be answered with a link.
    Reason being... the answers are all there and are covered.
    Just need to read.
    This vendor's products can only be ordered/purchased thru email I believe.
    Think I used PayPal as payment... but it's been awhile for me.
    These are the best bodylifts sold to fit the 1st gen Tacoma. period.
    http://www.4crawler.com/4x4/ForSale/Docs/BodyLift_HowTo.shtml
    elnip likes this.
  5. Oct 12, 2016 at 7:26 PM
    757yotas
    Virginia
    2007 TRD Sport
    Toytec has some nice kits. And they are a pretty reputable brand I believe? (Correct if wrong). Is it a task that i could do in the drive way with basic hand tools? Torque wrench, ratchet, sockets ect. ?
  6. Oct 12, 2016 at 9:09 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    I'm not a fan of Toytec... and feel they tend to cater to noobs.
    Good for them maybe... but not good enough for me.
    Yes this can be done in your driveway with basic hand tools
    and a floor jack that can lift the body high enough.
    I used some hardwood lumber to increase my body's lifting height.
    Tho' loosened... keep the opposing side bolts securing
    as you remove the bolts from the side you're working on.
    So basically... do one side at a time.
    I believe the fuel fill/neck height will need be increased slighly
    think I needed stack 4 washers to act as a spacer for that.
    Not sure what's required there for more then a 1" BL.
    But I know the fuel neck will stretch/fit when installing the 1" BL.
    Don't forget to remove the fuel door filler panel
    prior to lifing the bed.
    Remember... when you lift the body...
    the front and rear bumpers are mounted to the frame
    and so those will be lower to the body then when stock.
    They can be adjusted to compensate for the difference
    and 4crawler offers kits to do that.
    But after market bumpers may require more effort.
    As there is no compensation kit available for every mfgr.
    My All-Pro front bumper sits about 1" lower to the body...
    But I'm ok with that... and just ignore that remaining gap.
    Oh, you will also need find or make different engine side covers
    the flap material... I used Pond liner found at Home Depot.
    They need be made 1" longer to fit the new gap.
  7. Oct 12, 2016 at 9:20 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    95 extended cab sr5
    cxr turbo, fic6, methanol injection, king coilovers, jba uca, skyjacker leafs, rear 12" 5125s, no-slip rear locker, 35" grabber x3, magnaflow muffler, retrofit headlights, trans cooler, bed lined exterior, etc...
    I like this kit because its not just a puck but replaces the actual mount with a 1" higher version. Im personally planning on getting this one when i go 35s.
    http://www.4wheelparts.com/Suspensi...aspx?t_c=1&t_s=20&t_pt=3680&t_pn=daykt04506bk
  8. Oct 12, 2016 at 9:24 PM
    devinzz1
    devin
    95 extended cab sr5
    Its fairly straight forward. Jack up and do one side at a time. Dont forget to loosen steering column. Good idea to soak everything in pb blaster before hand.
  9. Oct 12, 2016 at 9:30 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    I not only added the 4crawler 1" BL pucks/bolts
    but also swapped the actual body mount during my install...
    this one shown is the Energy Suspension mounts.
    IMO the quality surpasses the Daystar products
    th_BMTS13_e45f5d19291f3fd35c834e5a0c7354d997b3f7b0.jpg th_BMTS09_e6bb3604f26b1bec3f55fc92acd9c3d2212108a8.jpg
  10. Oct 12, 2016 at 9:42 PM
    757yotas
    Virginia
    2007 TRD Sport
    That daystar kit looks pretty decent. I have installed 2 simple suspension lifts but alittle nervous on doing the body. Seems like there are alot of parts and things to loosen up...are there any good walk through type videos online anywhere showing what all to exactly do? Ik this might be a dumb question im just new to body lifts.
  11. Oct 12, 2016 at 9:51 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    You didn't read thru the 4crawler link that I posted previously... did you.
    I have not found that particular hand holding video you would like... yet
    But I know there's one out there if ya google and search that a little bit.
  12. Oct 12, 2016 at 9:58 PM
    757yotas
    Virginia
    2007 TRD Sport
    I did read through what you linked. It is helpful info, it says that headers and stearing extensions can be a problem due to clearence. Is that an issue you had?
  13. Oct 12, 2016 at 10:04 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    I had no issue because I also purchase the 4 crawler steering extension.
    Don't think it is a necessary purchase for the 1" BL...
    But using one will ensure the rag joint sits flat
    and that no steering bind can occur.
  14. Oct 12, 2016 at 10:07 PM
    757yotas
    Virginia
    2007 TRD Sport
    Ok sweet, thank you for your help
  15. Oct 12, 2016 at 10:08 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
  16. Oct 13, 2016 at 7:12 AM
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
    Everything @TacoDell said is right on the money. Same experience I had with my 4crawler set and have had it on since 01 with no problems.
  17. Oct 13, 2016 at 7:32 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SLC
    2000 ext cab, 2.7L, auto, 4x4
    I'm not sure at what height of body lift you may have to adjust the shift linkages. My 2000 came with a 3" body lift and I want to remove it or go down to 1" max. This 3 inch has a lowering bracket for the radiator as well. What pissed me off is the body mount closest to the hinged side of drivers door rusted through and so before I removed the mount and cleaned up the rusted sheet metal the mount rides on, I had an annoying squeak. Like recommended above, 1" is max I would go, if at all. I guess with the limited height of suspension lift, 1" body lift could have it's merits.
  18. Oct 13, 2016 at 7:33 AM
    cruiserguy
    Elijah
    SLC
    I've also never heard a single complaint from the Roger Brown kits, 4crawler. That'd be the only one I'd use as well.
