1 ton floor jack enough for front suspension change?
Discussion in '1st Gen. Tacomas (1995-2004)' started by x2468, May 13, 2011.
  1. May 13, 2011 at 10:49 AM
    x2468
    x2468 [OP] Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    I want to put in my new struts this weekend but i dont have a floor jack. None of my friends have one at the moment either. I found a place that rents 1 ton jacks but i read that the curb weight of a 4x4 taco is around 3800. But since im only doing the front suspension, i only need to lift one front tire off the ground at a time. Would a 1 ton jack suffice?
  2. May 13, 2011 at 10:51 AM
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    what is wrong with your supplied jack? I dont see it being an issue though, since you only need to lift enough to get the wheel off. make sure you use a jack stand while working.
  3. May 13, 2011 at 10:53 AM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    x2
  4. May 13, 2011 at 10:54 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Your not jacking up the whole weight of the truck.
  5. May 13, 2011 at 10:55 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Sears sells a jack and jack stand combo for cheap. ALWAYS!!!!!! use jack stands. Don't trust a hydraulic jack to hold. If the seal blows while you're under the truck. Geuss who gets all effed up and will be lucky to get a ride to the hospital. If ya do anything, use jack stands regardless. Compared to what could happen to you, they are cheap.
  6. May 13, 2011 at 10:56 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Don't get under the truck while it's only supported by the jack. 1 ton is on the lower end of what you'd want but it'll probably work. x2 on just using the emergency jack until you get it up on a stand.
  7. May 13, 2011 at 10:59 AM
    x2468
    ya? I never thought about using an emergency jack and then transferring to a jack stand. I always just used hydrolic jacks when i had them. Maybe ill just try to find a jack stand and use my OEM jack....
  8. May 13, 2011 at 11:05 AM
    scocar
    scocar hypotenoper
    Yeah, your GVW is distributed to four wheels, but the front two are heavier. Still, no worries. One corner at a time. Well within limits. No different than chaning a flat.
    Instead of a jackstand, you could use big blocks of wood (like 4x4s or 4x6s) if you have enough to make it stable and lay them like bricks (alternating courses).
  9. May 13, 2011 at 3:39 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    On the trail i stick my spare tire under the truck, if i dont have jackstands.
