1 y.o. Sweating/Leaking Rear Diff.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacos4Runnin, Oct 28, 2022.
  1. Oct 28, 2022 at 4:02 PM
    Tacos4Runnin
    Tacos4Runnin [OP] Well-Known Member
    Okanagan…eh
    2021 TRD-Sport AG/MT
    BDAAA357-4775-46C2-8AF5-A52EA426B23E.jpg Noticed this about 2 weeks after bringing my truck to Toyota for a 13 km service. Mechanic friend of mine whose opinion I trust says that the gasket is failing but Toyota likely wont do anything as it is not considered ‘fully leaking’
    Anyone have a similar experience with there one year old truck?
  2. Oct 28, 2022 at 4:03 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Common. Mine does it as well. Can run a search of other threads.
    Tacos4Runnin[OP] likes this.
  3. Oct 28, 2022 at 4:16 PM
    Bishop84
    Bishop84 Well-Known Member
    No drop no leak. It's just sweating. I'd just check on it now and then. It's 5 years 60k miles on that for warranty so you have time.
    Chew likes this.
  4. Oct 28, 2022 at 4:17 PM
    Tacos4Runnin
    Okanagan…eh
    Started reading other threads
    1. Whats a differential breather
    2. What are people replacing the stock gasket with to improve/fix this potentially growing issue?
  5. Oct 28, 2022 at 4:19 PM
    Clearwater Bill
    Billy
    Largo Florida
    Yes, early on there was a recall for same/worse situations.
    You might give an ugga dugga on those mounting bolts, just to make sure none are loose. IF they are, then clean the diff and monitor.
    Otherwise, just monitor. As @Bishop84 says, that's minimal and you have lots of time.
  6. Oct 28, 2022 at 4:24 PM
    Clearwater Bill
    Billy
    Largo Florida
    Yea, link is for a 2nd gen, but it's same ole same ole.
    Not a bad idea to do if you off road deep water. But Izzy says unlikely to be your root cause here.
    The good news is if you live in salt country those spots are protected. And if you do live in salt country, it looks like the rest of your frame could use some treatment.
  7. Oct 28, 2022 at 4:27 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Diff breather allows the oil and gases in the Diff to expand and contract. Releases pressure on seals etc. Pic of my “Diff breather relocate” behind the taillight.
  8. Oct 28, 2022 at 4:27 PM
    Tacos4Runnin
    Okanagan…eh
    Thanks for the info about the diff
    Was waiting for a comment about my frame lol
    Just ordered a pack of these bad boys for the frame
    Hooper89 likes this.
  9. Oct 28, 2022 at 4:28 PM
    Tacos4Runnin
    Okanagan…eh
    This is interesting
    Thanks for the photos
  10. Oct 28, 2022 at 8:36 PM
    alwaysHI
    alwaysHI Well-Known Member
    2017 MGM DCSB
    Pro Comp 6", full length 5100's with OME 888 w/ taco lean spacer, 5160s w/ Alcan custom pack, HS extended brake lines, Summit offroad Dakar 17x9, 315/70/17 Falken Wildpeak MT, Nitro 4.88 regear
    My 2017 was an actual leak.
    First it was sweating like yours, got the TSB in the mail, took it in for a retighten and then it went from sweating to leaking…
    Took it back - my local dealer said since the TSB was performed, I’m SOL.
    I yanked my 3rd member and got rid of the POS paper gasket and RTV’d it how it should’ve been done to begin with.
    Also - careful if you do the retighten route. There’s two different torque spec figures floating around. I see you have a 2021 so I’m gonna “assume” yours is the higher torque rating.
    From what I’ve read in the past, Toyota was swapping the 3rd member hardware out to stronger strength bolts for a higher torque rating if your diff was leaking (not sweating) while under the TSB.
    Like I said, I have a 2017 and they did not do that, they just retightened to the smaller grade spec.
    Smacky2020 likes this.
  11. Oct 28, 2022 at 8:40 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Rust protection
    na8rboy likes this.
  12. Oct 28, 2022 at 9:02 PM
    Tacos4Runnin
    Okanagan…eh
    Thanks for the info. Where can I get my hands on the RVT gasket you are referring to. Why wasnt this something Toyota installed from the factory if it fixes this problem?
  13. Oct 28, 2022 at 9:07 PM
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    RTV is liquid gasket maker. It's like gluing it together.
  14. Oct 28, 2022 at 9:07 PM
    JoeCOVA
    Joe
    Colorado Springs
    RTV can be found in any auto parts store but to use it properly you need to pull the 3rd and basically create a gasket.
  15. Oct 28, 2022 at 9:09 PM
    baltimorebirds2
    baltimorebirds2 tacomama
    Brooks
    Maryland, United States
    2018 MGM Tacoma TRD Sport DCSB 4x4
    TRD Pro 17” Wheels, Toyo Open Country AT3 33s” (255/80/R17), Hooke Road Offroad Roof Rack, LEDs (Low Beams, High Beams, Fog Lights, Interior Lights, Reverse Lights, License Plate Lights), Diode Dynamics SS3 Sport Fog Lights (Yellow), Sequential Turn Signals, OME Nitrocharger Plus, OME 4004's & HS 0.5 Spacer for 3" Lift, JBA UCA, Icon RXT Option 2 Leaf Springs 2.25" Lift, Yukon Clamshell Bushing, Alpine ILX W-650 Stereo, Infinity Primus 6004a Amplifier (140w*2), Sound Ordnance M75-4 Amplifier (75w*4), Infinity Kappa 693C Component 6x9 Speakers, Infinity Kappa 63XF 6.5 Speakers, TRD Shift Knob, Black Emblem Overlays, TRD Grille Badge, OEM Door Sill Protectors, Driver’s Seat Jackers, Pop and Lock Power Tailgate Lock, AJT Designs start button and trim, 4x4 knob, shifter trim, and cupholder trim, MESO Customs Vent Rings and Door Handle Covers, Gasshole, Drop Stops, AC Drain Mod, Bed Lights, Rough Country Roll Up Tonneau Cover, Window Tint, KDMAX Tune
    Wasn't there a recall or more likely a TSB for leaking rear diffs on 3rd gens?
  16. Oct 28, 2022 at 9:11 PM
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    You can run a bead of RTV around it and give it 12-24hrs to cure
    baltimorebirds2 likes this.
  17. Oct 29, 2022 at 12:55 AM
    alwaysHI
    2017 MGM DCSB
    read above
  18. Oct 29, 2022 at 12:56 AM
    alwaysHI
    2017 MGM DCSB
    paper is cheaper
  19. Oct 29, 2022 at 4:37 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Check out post #2014 for the original TSB (with pictures).
    https://www.tacomaworld.com/threads...le-loss-of-control-of-vehicle.488536/page-101
    I had the above TSB done when my truck was 1 year old and the weeping has not returned. My weeping looked like your pictures. Print out the original TSB and take it to the dealer. Try to have the dealer address the issue since you are under warranty. When out of warranty, then I would deal with it on my own.
  20. Oct 29, 2022 at 5:49 AM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    Mine did the same around 5k and went away. If it's not a leak, dealer won't touch it but you may want to make an appointment to document. 20210617_175058.jpg 20210914_140518.jpg
