10" Coilover Total Chaos +3.5. Will it work?
Discussion in 'Long Travel Suspension' started by JDawg562, Apr 26, 2021.
  1. Apr 26, 2021 at 4:49 PM
    JDawg562
    JDawg562 [OP] Derp.
    Justin
    Long Beach, CA
    2007,TRD Off-Road, Access Cab
    I have a Total Chaos +3.5 standard long travel kit with 8" coilovers. I'm only rear wheel drive too. I came across some 10" coilovers and was wondering how they would work on my long travel kit.
  2. Apr 26, 2021 at 4:50 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Not without cutting out the coil bucket and doing a tube upper mount.
    desertjunkie760 likes this.
  3. Apr 26, 2021 at 5:31 PM
    JDawg562
    JDawg562 [OP] Derp.
    Justin
    Long Beach, CA
    Hummm lol. I just thought of the ride height while I was typing this. I have my 8" set up for 50/50 up/down. The 10 roughly 2" taller collapsed I could work with, but being lifted another 3" to keep my 50/50 ratio wouldn't be good or keep it at the same height, but only have like 2" of compression would be terrible. Ride height. I forgot about ride height! :facepalm:
  4. Apr 26, 2021 at 5:35 PM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    This
    Whats the point? There are other limitations in the suspension that you’ll experience before you get anything else out of that kit by using a different shock.
    whatstcp likes this.
  5. Apr 26, 2021 at 5:58 PM
    JDawg562
    JDawg562 [OP] Derp.
    Justin
    Long Beach, CA
    Yeah I know the kit right now is limited by the coilover. When I take the coilover/straps/bumps out it can move more than the extended and collapsed of the 8" coilover. I was thinking I could get more out of it. The company had 10" ones on the shelf for $900 with compression adjusters the 8" would take them 6 weeks to build.
  6. Apr 26, 2021 at 9:51 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I'd wait until you're going to at least build an engine cage or cross over bar to upgrade to 10" co's - and build bypass mounts if you can just get some to get your hands on for mock up if you can't buy them at the time.
  7. Apr 26, 2021 at 10:00 PM
    JDawg562
    JDawg562 [OP] Derp.
    Justin
    Long Beach, CA
    lol I've been straddling the fence about doing a full cage for years... I've been doing to many vehicle projects...
  8. Apr 28, 2021 at 8:00 PM
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    The kit is limited by the uniballs on the uca when it comes to droop travel. I’m not sure what the limiting factor is as far as bump travel. The kits come with 8” shocks, but don’t use the full 8” of shock travel.
  9. Apr 30, 2021 at 12:11 PM
    orbot
    orbot Well-Known Member
    Is it 4wd?? A full drop with 10” coilovers will destroy your cvs unless you have the super nice pricy ones
  10. Apr 30, 2021 at 1:07 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    2wd - yeah I only imagine he might gain a little up travel but hard to say if it's more than just clearancing the inner fender would for 8" co's without knowing if the inner fender, shock, or something else limits up travel without the inner fender there.
  11. Apr 30, 2021 at 2:44 PM
    glorifiedwelder
    jason
    Santa Clarita, ca
    I’ll post this one more time. Cv’s bind is not the limiting factor on total chaos 2nd and 3rd gen lt kits. That’s from personal experience and directly from Rob and Pats mouths at TC. The majority of the time you can have the misalignments seated against the uca uniball cup and the cv’s still won’t be binding. Their install instructions have you set kit based on uca uniballs unlike other kits which set straps just before cv bind
    whatstcp and Dalandser like this.
  12. Apr 30, 2021 at 3:38 PM
    orbot
    Remember thees kits are meant to be fully eficiente with 8” shocks, the only benefit i could imagine if theres any is running a shock with more oil capacity
