$10 DIY Power Lock Tailgate
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MESO, Mar 26, 2016.
  1. Feb 20, 2018 at 9:08 AM
    #41
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
  2. Feb 20, 2018 at 9:13 AM
    #42
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
  3. Feb 20, 2018 at 9:14 AM
    #43
    vuTron
    vuTron Well-Known Member
    SF Bay Area
    2016 Quicksand TRD O/R DCSB AT
    sooo.... I'm still a little confused... do you think your tailgate solution will also work for a truck cap?
    bosco76 likes this.
  4. Feb 20, 2018 at 4:55 PM
    #44
    woodshampoo
    woodshampoo Well-Known Member
    VA
    2018 DC OR 4x4
    Yep bolt isn't an issue just trying to make suggestions for folks who are nervous. Strong hook and loop I wouldn't worry about and the adhesive should tolerate the heat no problem..
  5. Feb 20, 2018 at 4:57 PM
    #45
    daohaus
    daohaus Well-Known Member
    Duan
    33.960892 -117.575824
    18 TRD Off Road Premium 4runner
    Rotiform SIX OR Toyo Open Country RT
    Does your call offer a perpo unlock option? If so I imagine it would be something similar to this but with different linkages
  6. Feb 20, 2018 at 9:07 PM
    #46
    jptheriot
    jptheriot Meso Investor #5
    Jp
    St. Louis
    3rd Gen TRD Sport DCSB 4x4 / previously owned 1st and 2nd Gen
    Step Bars / BakFlip FiberMax Tonneau Cover /5% Tint Rear 20% Front / Reverse Cam Anytime / Coin Holder / LED Interior and reverse lights / Katzkin Leather Interior / Hondo knobs / TRD Pro Wheels / Black badges / Pro grille / @mesojdm designed Ultimate LED side mirror turn signals, BTLM, BD 3rd Brake Light, GASSHOLE, Ultimate Dome Light, Ultimate Map Lights, Custom Fuse Cover, Custom OEMeso Headlights / In-dash Universal Mount with iOmount
    Truer words have never been posted on TW!
    paradox4286, MMoreno16 and MESO[OP] like this.
  7. Feb 21, 2018 at 4:37 PM
    #47
    woodshampoo
    VA
    2018 DC OR 4x4
    Ordered a couple of actuators on Amazon. Will probably get into this project this weekend. Might fab up a 3d mount instead of drilling into that piece. Although that seems to be easiest.
    ian2016 likes this.
  8. Feb 23, 2018 at 11:43 AM
    #48
    HawkNRoll55
    HawkNRoll55 Well-Known Member
    PNW
    16 Inferno 4x4 OR DCSB AT
    does is matter which wire from the actuator goes to which harness wire?
  9. Feb 23, 2018 at 12:18 PM
    #49
    MESO
    State of Jefferson
    No. If hooked up incorrect it will just be backwards(Locking on unlock command, vice versa) just swap the wires around until you find it working correctly.
  10. Feb 23, 2018 at 1:14 PM
    #50
    HawkNRoll55
    PNW
    :thumbsup:
  11. Feb 23, 2018 at 1:21 PM
    #51
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Well if someone doesn't buy the pop and lock off our wedding registry, looks like I'm gonna be doing this instead. If only I had a CNC mill, I'd just make my own pop and lock out of billet aluminum.
    Corneeeeelius likes this.
  12. Feb 23, 2018 at 1:33 PM
    #52
    HawkNRoll55
    PNW
    youd just need to machine the bracket, like Meso said, that's what youre payin for.
    Now the fact that he didn't 3D print some robot arm to lock and unlock his tailgate is another story.... or at least printed a perfect little box for the actuator, instead of that janky box :rofl:
    Slashaar likes this.
  13. Feb 23, 2018 at 2:13 PM
    #53
    MESO
    State of Jefferson
    Hey now...
    Take a look again at those plastic welds I did on that box. Stacking dimes. And to my defense, I did not have a super duper printer at my disposal at the time of the post.
    C41n and Slashaar like this.
  14. Feb 23, 2018 at 8:23 PM
    #54
    HawkNRoll55
    PNW
    Hahah your masterfulness is unquestioned and unequalled sir :bowdown:
  15. Feb 23, 2018 at 9:31 PM
    #55
    Pikestaco
    Pikestaco Newbie
    Los Angeles
    2017 Quicksand 4x4 TRD Sport DCLB
    need to learn more about this stuff
    If we don’t have ability to make a box have any ideas on a box we could buy?
  16. Feb 23, 2018 at 9:35 PM
    #56
    MESO
    State of Jefferson
    You don't need a box. You can mount the actuator right to the metal. I decided to enclose mine to cut down on the loud clunking sound it makes when operating. But to answer your question, look on Amazon/eBay there are a number of little plastic boxes usually labeled for "DIY electronics"
    #56
  17. Feb 23, 2018 at 10:06 PM
    #57
    Pikestaco
    Pikestaco Newbie
    Los Angeles
    #57
  18. Feb 24, 2018 at 8:17 AM
    #58
    HawkNRoll55
    PNW
    I bought the same actuator, different box. And some sound deadener. Should have it all by mon/tues. Then she goes in. Looking forward to it.
    Juggernaut and 619HiluxLover like this.
  19. Feb 24, 2018 at 10:50 AM
    #59
    steve1503
    steve1503 Well-Known Member
    New Hampshire
    2020 SR5
    The only problem with this I see is, no disconnect if you want/need to take the tail gate off. I'll be adding some connector at the camera location.
    wahoobie likes this.
  20. Mar 2, 2018 at 12:08 PM
    #60
    HawkNRoll55
    PNW
    What did you use to attach the box/actuator to your tailgate? I anticipated the actuator being threaded but the front two are just holes straight through and the back only about 1/2" deep or so. Did you use bolts to go straight through? Or oversized screws and self thread it in there?
    #60
