$10 DIY Power Lock Tailgate
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MESO, Mar 26, 2016.
  1. Mar 23, 2018 at 6:03 PM
    #81
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Just give yourself a solid hour or 2 and a clean floor you can crawl around on under the truck. It went smooth once you have a plan in your mind.
  2. Mar 24, 2018 at 8:45 AM
    #82
    destin_meeks
    Destin
    Tuscaloosa, AL
    The biggest thing was seeing that the actuator cannot be mounted directly to the sheet metal. It needs to be about an inch and a half lower. I found that mounting the actuator to a piece of 2x4 and then mounting the 2x4 to the sheet metal put it in the perfect spot.
    29542630_10160202976760646_7786351597633_ac85863fdf07661073fbd0d7996b5b74f8ed24fc.jpg
    It looks like the actuator is against the metal, but it's quite a bit lower to be even with thew lock mechanism.
    I also took a pic showing how to get new wire loom through the plastic plate on the tailgate and bumper. Pop the piece out, undo the little snap holding it closed, then drill a new hole next to the existing hole. This fits 1/4" wire loom perfectly.
    29497763_10160202976915646_5439248598274_b2d1139205e9a8b588f526c92ecb4e8bc4c782d0.jpg
    Now you can have a factory look (I late rotated the zip ties so you don't see the heads)
    29511278_10160202976850646_5982120024053_f0d38e2fc8582e0d938f0d10cb118ba91e4f1817.jpg
    I personally chose to splice into the front passenger door instead of the rear, simply because it was easier to get to for me. And there is already a wire bundle going into the cab there. Route your loomed wire (please put loom over your wire and zip tie it to existing factory wire every few feet) along to this junction under the passenger door
    29542203_10160202977050646_7221067567629_db5f318268f437b4c6eac6aba22b2eb948bba124.jpg
    And your wire comes out neatly under the passenger seat.
    29497875_10160202976955646_1807595626592_17da9c4f90af7695cba7524ef56ae8c069e72140.jpg
    29511392_10160202977020646_1591671475938_52aff535d624eed9165bec1850098f2bbe41bacb.jpg
    Ignore the bowl of muffins (or don't, you'll just make yourself hungry)
    I routed my wire up to the passenger kick panel to this upper-right connector and spliced into the red and green wires.
    The blue is the path I routed my wire. Up the floorboard and around the top of that wire junction, to follow factory runs.
    28947538_10160203059360646_4823081727899_fde86b86a30023b901bf9ad452564df0bab90d99.jpg
    All in all, this was such an easy mod, and an extremely cheap mod. No need to pay the $100+ for the pop-n-lock brand.
  3. Mar 24, 2018 at 10:13 AM
    #83
    snapspinner
    snapspinner Well-Known Member
    Shawn
    2023 TRD OD DCSB Electric Lime
    Of course I see this after I installed a pop a lock kit. I think the generic actuator installed like this moving a better part of the linkage when compared to the pop a lock. If my actuator ever fails I'm going to refit it with an actuator like this. Thanks for posting this up!!
  4. Mar 24, 2018 at 11:05 AM
    #84
    venezian
    venezian Well-Known Member
    Los Angeles
    2022 7545E
    Do you have pics of this? Not sure I'm picturing it correctly.. you got a small enough piece of 2x4, mount the actuator to that and then onto the sheet metal?
  5. Mar 24, 2018 at 11:18 AM
    #85
    Tunngavik
    Tunngavik Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    Maybe a dumb question, but any confirmation this will work with an access cab?
    I've only seen guys posting with double cabs.
  6. Mar 24, 2018 at 11:21 AM
    #86
    destin_meeks
    Destin
    Tuscaloosa, AL
    The wiring I went to (in the passenger kick panel) goes to the front passenger door so all models will have it
    tcjacado and Tunngavik[QUOTED] like this.
  7. Mar 24, 2018 at 11:39 AM
    #87
    destin_meeks
    Destin
    Tuscaloosa, AL
    I can snap a pic on Monday when I’m back in the shop.
    I took a 2x4 I have laying around, cut off a small piece (maybe 2 inches long) and screwed the actuator onto that.
    So now you have an actuator attached to a piece of wood. Now stick that on the underside of the sheet metal and put 3 or 4 screws through the sheet metal into the wood.
    I'm going to use one of Stew's pics from the original post until I can take one
    29541478_10160203680830646_5443168613105_1a0ca9d78faa6dd0b1b645df7ed67d4a15b37834.jpg
    The blue is our actuator. The red is a piece of 2x4 (or any scrap wood about 1.5")
    This pic does a good job showing just how far below the metal the actuator needs to be.
    venezian[QUOTED] likes this.
  8. Mar 24, 2018 at 11:41 AM
    #88
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Correct. I forgot to mention that in the OP. The actuator needs to be offset from the metal tailgate in order o be level with the tailgate lever. That's another benefit of the enclosure I made as it holds the actuator further down(while still encasing it)
    destin_meeks[QUOTED] likes this.
  9. Mar 24, 2018 at 11:51 AM
    #89
    oldirtywalker
    oldirtywalker Well-Known Member
    2018 DCSB OR
    Which wires do you tap into up there?
  10. Mar 24, 2018 at 11:52 AM
    #90
    destin_meeks
    Destin
    Tuscaloosa, AL
    the ones circled in red
    red and green wires
  11. Mar 24, 2018 at 11:56 AM
    #91
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I just did a check. Locking the tailgate first then closing. It stays locked.
  12. Mar 24, 2018 at 12:17 PM
    #92
    oldirtywalker
    2018 DCSB OR
    Thank you.
  13. Mar 24, 2018 at 12:19 PM
    #93
    destin_meeks
    Destin
    Tuscaloosa, AL
    depending on your particular actuator wiring, colors to connect may vary. my particular actuator had green and blue wires, yours may be different. make sure when you press lock it locks and when you press unlock it unlocks before securing your wiring
    619HiluxLover likes this.
  14. Mar 24, 2018 at 7:32 PM
    #94
    dubstyle7
    dubstyle7 Well-Known Member
    Nic
    Dana Point, CA
    2016 Super White Tacoma TRD Sport 4X4 DCSB
    Hey @mesojdm or anybody else that may be able to lead me in the right direction I would appreciate it. Would 16-2 landscape wire be okay to run with this mod, or am I stupid? I'm going to tackle this tomorrow and curious if I should work with what I have or go buy some new wire from the hardware store. Thanks guys, and I just got done installing my meso ultimate turn signals, I love them, thanks Meso!
  15. Mar 24, 2018 at 7:38 PM
    #95
    MESO
    State of Jefferson
    Yes that's fine. Just make sure it's not solid copper and multi strand. I actually use home audio 16-2 (as you can see in the picture) because both wires are protected in a sheath.
    dubstyle7[QUOTED] likes this.
  16. Mar 24, 2018 at 7:58 PM
    #96
    dubstyle7
    Nic
    Dana Point, CA
    Cool, thanks @mesojdm ! It's multi strand so I'm ready to give it a go. Appreciate all your hard work, TW wouldn't be nearly the same without you.
  17. Mar 25, 2018 at 10:38 AM
    #97
    philthytaco
    philthytaco Well-Known Member
    Philip
    My pop and lock failed on me who knows when and I am look into replacing it . Is there a source of the actuators they use? I can tear off their fancy bracket and install on the new similar actuator.
  18. Mar 25, 2018 at 2:21 PM
    #98
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Don't tear off the bracket, just swap in an actuator from Amazon.
  19. Mar 25, 2018 at 2:24 PM
    #99
    Lateralus01
    Lateralus01 Well-Known Member
    2018 Cement Tacoma TRD OR DCSB 4x4
    Can someone share a pic of the pop and lock bracket. And mounted if possible. If not just the bracket will do. TIA.
  20. Mar 26, 2018 at 2:36 PM
    #100
    dubstyle7
    Nic
    Dana Point, CA
    Really enjoyed doing this install this past weekend. Ran me probly close to 20 bucks as I also needed wire loom cover and electrical t tap connectors and didn't have them lying around. Took me a little over a couple hours, learned a lot about my truck and had a good time with the install. Install looks factory and super clean. I would definitely recommend to anyone. And a big thanks to @mesojdm and @destin_meeks as I referred to their pics and instructions anytime I was unsure about something. That was a big help.
