$10 DIY Power Lock Tailgate
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MESO, Mar 26, 2016.
  1. Mar 26, 2018 at 3:06 PM
    #101
    oldirtywalker
    oldirtywalker Well-Known Member
    2018 DCSB OR
    Is anyone concerned about the actuator pulling on the handle too much?
    I didn't see a way to adjust the tension on the actuator. Pretty slick though, thanks again @mesojdm
    Tunngavik and Wedge like this.
  2. Mar 26, 2018 at 6:16 PM
    #102
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Anything I can do to make it easier for the rest! I can only hope to help the forum as much as Stew has!
    Mine pulls pretty tight too. I just decided to roll with it. Someone somewhere might sell an actuator with adjustable throw range, but I don't think mine pulls tight enough to cause issues (guess time will tell)
    TrdTaco171991 and MESO[OP] like this.
  3. Mar 26, 2018 at 6:47 PM
    #103
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    I've had this on for a year + and haven't had any problem with the actuator pulling the handle linkage too hard. I have not seen any adjustable actuators.
    The trick is to drill the hole, get the actuator linked up to he handle and then see how far it pulls/pushes. I like to see the max travel, then split the difference in half and mount the actuator there. Too close and it doesn't reach maximum push travel and will have too much pull travel. If that makes sense..
    C41n and 619HiluxLover like this.
  4. Mar 28, 2018 at 8:41 AM
    #104
    destin_meeks
    Destin
    Tuscaloosa, AL
    Pulled out another actuator to try and show this off better without taking the tailgate apart
    62312B95-94CD-4977-8762-F15570270D36.jpg 6B05A824-2AD7-486B-BED8-31E00703D34A.jpg ADC0110A-DA40-4A99-991A-0DD20791DAC3.jpg
    Cut the 2x4 to fit the actuator (marked with the black line) then attach the actuator to it.
    Mount this to the underside of the tailgates sheet metal (role played by my hand)
    This will provide enough spacing to have the actuator sit level to the lock mechanism
  5. Mar 28, 2018 at 8:44 AM
    #105
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I bet the wood mount keeps the noise down a bit also.
  6. Mar 28, 2018 at 11:28 AM
    #106
    quikrain
    quikrain Well-Known Member
    2017 Red Tacoma TRD SP DCLB
  7. Mar 28, 2018 at 3:29 PM
    #107
    jptheriot
    jptheriot Meso Investor #5
    Jp
    St. Louis
    3rd Gen TRD Sport DCSB 4x4 / previously owned 1st and 2nd Gen
    Step Bars / BakFlip FiberMax Tonneau Cover /5% Tint Rear 20% Front / Reverse Cam Anytime / Coin Holder / LED Interior and reverse lights / Katzkin Leather Interior / Hondo knobs / TRD Pro Wheels / Black badges / Pro grille / @mesojdm designed Ultimate LED side mirror turn signals, BTLM, BD 3rd Brake Light, GASSHOLE, Ultimate Dome Light, Ultimate Map Lights, Custom Fuse Cover, Custom OEMeso Headlights / In-dash Universal Mount with iOmount
    Do you have to shave the hair off of the tailgate to get a flush mount to the wood?
    Corneeeeelius and cshrum like this.
  8. Mar 28, 2018 at 4:52 PM
    #108
    destin_meeks
    Destin
    Tuscaloosa, AL
    Yes, that is a very important step!
  9. Apr 6, 2018 at 3:08 PM
    #109
    DaMaDo
    DaMaDo Well-Known Member
    Northern AL
    2018 White TRD Pro
    Do I measure the bend for the actuator rod when the actuator is in the neutral position? Or should I push it in for the unlocked position? I put my actuator on a scrap peice of hardwood with some 80mil sound damper and MLV b/c why not.
    tonered and destin_meeks like this.
  10. Apr 6, 2018 at 3:23 PM
    #110
    MESO
    State of Jefferson
    Pull actuator out to max position. Push tailgate lock down to full position.
    Measure then bend.
    What I would do is bend the rod, mount the actuator to the wood and have it all mocked up and wired. Then(while holding the actuator up in place) hit lock and unlock with the key fob. Then you can move the entire assembly back/forward until it hits the perfect spot of Lock/unlock. Then Bolt it down with screws through the tailgate into the wood.
  11. Apr 6, 2018 at 3:44 PM
    #111
    DaMaDo
    Northern AL
    2018 White TRD Pro
    Thanks, got it all installed and works great!
    dubstyle7 and destin_meeks like this.
  12. Apr 7, 2018 at 8:17 AM
    #112
    BearintheWoods
    BearintheWoods Well-Known Member
    Barry
    2018 Black Tacoma Off Road
    That is exactly how I did it and it works great. I predrilled the holes through the sheet metal near the center of where the block would end up and then once everything was positioned, it was easy enough to screw the spacer block down.
  13. Apr 7, 2018 at 7:12 PM
    #113
    djmr1972
    djmr1972 Well-Known Member
    N. Central Mass.
    18 Cement TRD Off Road Long Bed
    Visors, Roof rack, decals in and out, bug deflector, tonneau cover, bed extender
    Does anyone here know (as close as possible) the measurements of the 2x4 needed? Im ordering all the stuff needed this week but i have no lumber so a friend is going to cut me a piece on a job site and want to tell him a size. Thanks in advance all.
  14. Apr 7, 2018 at 7:14 PM
    #114
    dubstyle7
    dubstyle7 Well-Known Member
    Nic
    Dana Point, CA
    2016 Super White Tacoma TRD Sport 4X4 DCSB
    About a 6 inch piece should be fine. Nothing exact, just big enough to mount the actuator and small enough to fit in between the tailgate frame.
  15. Apr 7, 2018 at 8:11 PM
    #115
    djmr1972
    N. Central Mass.
    perfect. I just didnt want to tell him 4 inches and the block not be wide enough.
    thanks
  16. Apr 7, 2018 at 9:06 PM
    #116
    djmr1972
    N. Central Mass.
    so how did people mount the actuator to the block of wood? long screws through the whole thing or take the actuator box apart to screw to wood? Some of the actuators I have looked at only have screw holes on one side and some have all the way through.
  17. Apr 7, 2018 at 9:10 PM
    #117
    djmr1972
    N. Central Mass.
    are these screws even long enough to go all the way through the actuator to screw to a piece of wood?
  18. Apr 7, 2018 at 11:51 PM
    #118
    Acesfulll
    Acesfulll Member
    Marc
    2017 MGM Tacoma OR DCSB
    I used some PCB standoffs for the mounting offset. Worked great!
    beeip, shwokee, Steve_nm and 10 others like this.
  19. Apr 8, 2018 at 5:38 AM
    #119
    Harvo
    Harvo Hanging On !!!
    17' TRD Offroad DCSB
    SpiderTrax, RCI Sliders, Warn bumper, Smittybuilt winch, Ridge Grapplers...
    20 years from now when the 3rd or 4th owners are fixing up these Tacomas for their kids or their trail rigs, they will take the tailgate apart and wonder why in the world is there a chunk of 2x4 inside the tailgate LOL.
    Nice mod. Think I'll give it a shot.
    ll1l2l1l2lll, C41n, cshrum and 5 others like this.
  20. Apr 8, 2018 at 7:34 PM
    #120
    destin_meeks
    Destin
    Tuscaloosa, AL
    And that’s why I used a 2x4
    It will still be there 20 years from now
    ll1l2l1l2lll and Corneeeeelius like this.
