10% Scrublade wipers
Discussion in 'Sierra Expeditions' started by FlyingWil, Jan 24, 2011.
  1. Jan 24, 2011 at 2:52 PM
    FlyingWil
    FlyingWil [OP] Well-Known Member Vendor
    Wil
    Sonoran Desert
    01 DC Expedition Ready
    Shrockworks Front Bumper, LightForce 240's, PIAA 510's,T-Max 9000 competition winch with Outback (longer drum) and modified brake wireless controller and Masterpull line with Viking safety thimble, Rugged Ridge Hawse, Daystar Winch isolator, SAW Racerunner 2.5 coilovers, Safari Snorkel, IBS dual battery system with RBM, Scangauge II, Total Vision self spotting kit and monitor with aux output and remote, Low Tek Gauge pod with Cyberdyne gauges for fridge and battery, Yeasu FT-7800 head unit mounted in ceiling linner and speaker Larson Hood mount, Uniden Pro 520XL CB radio in the ash tray location,'lil Wil Mag mount antenna, Odessey 1200 MJT & Die Hard Plat. dual batteries, Can-Back with extra mounts, Blue Sea 12 st Fuse Box, 100 Amp 100 Amp Relay, Extremeaire & 5 Gal air tank w/ 145 psi switch, Custom bed drawer system, Engel Mt-45 with TwoZone, protective covers, and Engel Slide Eezi-Awn 1600 RTT w/ Ikea LED light mod, and sheet set, CBI offroad Expedition rear bumper, jerry can tir
    Sierra Expeditions is clearing out our stock on Scrublade wipers.
    To get 10% enter coupon code scrub in the coupon code box when viewing your cart.
    Scrublade offers a solution for smeared bugs, dirt and grime from impairing your vision when driving. Advanced, state-of-the art technology removes bugs, road grime and dirt from your windshield giving you a clear, safe view of the road.
    Robby Gordon used the Scrublade in the 6,000-mile off-road 2009 Dakar Rally! The Scrublade worked so good for Gordon and his team that he is now endorsing the Scrublade on the National commercial campaign this year.
    Scrublade’s patented, advanced dual-blade “scrubber” technology works like no other wiper blades. Typical wiper blades just smear bugs and grime across your windshield, but Scrublade utilizes not one, but two blades, to give you a clean, bug-free view of the road ahead.
    Scrublade doesn’t use two standard blades, however. The secret behind Scrublade’s patented, advanced dual-scrubbing technology is the hundreds of tiny triangular “scrubbers” on the leading edge of the two outer blades. The tip of each triangle pierces the debris and, as it passes through and widens to the base, the triangle breaks it apart, literally “scrubbing” your windshield clean. The second “smooth blade” squeegees away any remaining debris or water left behind. Scrublade does its work on each and every pass, leaving a clear, clean bug and grime-free windshield.
    “When we were designing Scrublade we tested hundreds of shapes and sizes looking for the one that cleaned the most effectively and efficiently”, said Billy Westbrook, CEO and creator of Scrublade. “We finally settled on the triangle. Then, we use the best rubber compound available.”
    The Scrublade line covers all applications from 11” thru 28”, and have been proven to be one of the best wipers for rounded and flat glassed vehicles.
    This close view of the triangular scrubbers is what gives the Scrublade it's advantages over the other wipers on the market today.
    Another angle to show the smooth edge of the Scrublade on the inside, and the triangular scrubbers on the outside. Inside for water removal, and the outside for bug and road debris removal.
    Scrublade took into consideration not just the functionality of the Scrublade, but also the looks of the Scrublade. You can put the Scrublade on a heavy-duty truck or on a higher end vehicle, without compromising the looks of the vehicle.
  2. Jan 24, 2011 at 2:57 PM
    shocker01
    shocker01 Well-Known Member
    Gordon
    Ky
    01 Tacoma 4x4 TRD
    5100 Billies, drop-in k&n, deck plate, gray wire, Dynomax exhaust.
    I'm actually needing some wipers. Are theese legit? Noticably better than say bosch, because I don't have much complaint with good quality "regular" blades.
  3. Jan 24, 2011 at 3:00 PM
    rob1
    rob1 Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
    Scrubscibed....:D
  4. Jan 24, 2011 at 3:01 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    Dam I just bought some wipers yesterday.
  5. Jan 24, 2011 at 3:02 PM
    FlyingWil
    Wil
    Sonoran Desert
    They are good, however, we have had some quality issues and are discontinuing the line. We've ran them on the Jeep for over a year, and no issues.
  6. Jan 24, 2011 at 3:10 PM
    Timicha
    Timicha Timicha
    TIM
    Tillamook / Portland , Oregon
    04 White Tacoma
    Fabtech 4 inch lift, tinted windows, diff drop, 33 inch MTZ tires on Raceline Raptor wheels, ELITE OFF-ROAD bumpers and sliders
    i was expecting these to be damn expensive but not bad at all, i'll get some after the wipers i have now ware out for that price
  7. Jan 24, 2011 at 3:50 PM
    shocker01
    Gordon
    Ky
    01 Tacoma 4x4 TRD
    Thanks, I'll consider picking up a set next purchase.
  8. Jan 24, 2011 at 4:35 PM
    FlyingWil
    Wil
    Sonoran Desert
    Offer stands pending stock, (Once they are gone, these are gone).
  9. Jan 24, 2011 at 4:45 PM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SP... CaL
    11 TRD sPort
    5100's@1.75 Horns (Andres) Satoshi TRD cat back BHLM
    What size do the tacos use
  10. Jan 24, 2011 at 5:47 PM
    FlyingWil
    Wil
    Sonoran Desert
    Gen 1: 17" (x2)
    Gen 2: 21" (Passenger) and 22" (Driver)
  11. Jan 24, 2011 at 6:19 PM
    Timicha
    Timicha Timicha
    TIM
    04 White Tacoma
    how come you guys are discontinuing these
  12. Jan 25, 2011 at 7:46 AM
    FlyingWil
    Wil
    Sonoran Desert
    See post #5, Basically we are having some quality issues (bad clips, our inventory has been checked and is good), and compatibility issues with Land Rovers.
  13. Mar 8, 2011 at 7:49 AM
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    Coupon code doesn't work? :notsure:
