100k miles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma2468, Feb 20, 2020.
  1. Feb 21, 2020 at 6:39 PM
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    Just drop by the dealer, they’ll get you what you need, they are around $4 each(or they were the last time I purchased them). Spark plugs are recommended every 30k on the V6, they use copper plugs. I believe the 2.7 uses iridium plugs and the recommended interval is 100k.
    Skyway likes this.
  2. Feb 21, 2020 at 6:40 PM
    Greenedmc
    Greenedmc Well-Known Member
    Daniel
    Elizabethton TN
    2014 Silver Tacoma Trd Off Road Access cab
    Denso is a brand. The v6s come from the factory with 3 denso plugs in one head and 3 ngk in the other. When you go to the dealer and get replacements you get 6 Denso brand plugs.
    Or atleast my dealer.
    07 sport 4x4 likes this.
  3. Feb 21, 2020 at 6:41 PM
    Bishop84
    Bishop84 Well-Known Member
    Denso and NGK are basically the same, its easier just to look for NGK plugs, as thats what even the dealers sell.
  4. Feb 21, 2020 at 6:51 PM
    Muldoon
    Muldoon Well-Known Member
    Robert
    Northeast Ohio
    2009 4x4 ACLB TRD-OR 4.0, Green
    5100s, Wheelers AAL, Leer 100R
    If you suspect an oil issue and you have an 06 a compression test is still a good idea because of the head gasket issues...
    07 sport 4x4, Skyway and Greenedmc like this.
  5. Feb 21, 2020 at 6:55 PM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    head gasket issues... :cheers: There goes your tax return.
    07 sport 4x4 and Muldoon like this.
  6. Feb 21, 2020 at 7:07 PM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    why not run something like chevron delo instead of rotella?
    at least delo is CK-4/SN, so in theory it should be easier on your cats.
  7. Feb 21, 2020 at 7:18 PM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
  8. Feb 21, 2020 at 7:33 PM
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    Here's a 30k checklist I puked out a while back:
    https://www.tacomaworld.com/threads...al-transmission-30k-service-checklist.368542/
    It'll cover part numbers for gasket / crush washers and oil amounts.
    FWIW I recently hit 120k and to date:
    Cabin and Air Filters: 2x a year or as needed.
    Every 5k: Mobil 1 5w-30 w/ OEM Filter. Grease drive line. Rotate tires.
    Every 30K: Plugs, Transfer Case, Diff Oil in both boxes, MT gear oil.
    70k: Front and Rear Shocks & Leaf Springs - 3'rd Gen OEM TRD OR. New front brake pads.
    90k: Coolant flush.
    115k: Rear U-Joints.
    120k: Serpentine belt.
    Planned:
    Power Steering Fluid, Rotor's & Pads at 150k.
    Coolant every 70k or 10 years after the initial flush at 90k: 160k-230k etc.
    Serpentine belt, idlers / Pulleys, Clutch and associated accouterments at 250k *IF THE TOB MAKES IT*!
    That's it. Don't over think it.
    EDIT: Welcome to TW OP!
  9. Feb 21, 2020 at 7:36 PM
    ThaiChillyTaco
    ThaiChillyTaco David aka Chilly aka Booty Freak
    David
    Goose Creek - South Carolina
    2021 Cement Grey TRD Off-road 4x4 Longbed
    Rough Country 3.5 Lift SCS BR6 wheels rolling in 285/70/17 Falken Wildpeaks
    I have always changed my oil on all my Tacoma's around the 7000 mile mark :anonymous:
    Hooligans likes this.
  10. Feb 21, 2020 at 7:52 PM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    I think you’re alright.
  11. Feb 21, 2020 at 8:41 PM
    Greenedmc
    Daniel
    Elizabethton TN
    Honestly the rotella was cheap and easy to find. Also, a large number of subaru owners run it. Especially in turbo applications. So I never really looked at the delo. Rotella does make a t6 multi vehicle now. But I’ve not known anyone that’s used it.
  12. Feb 22, 2020 at 8:15 AM
    Tacoma2468
    Tacoma2468 [OP] Member
    Hey guys just an update. I checked my oil this morning and it was close to the bottom dash on the normal oil level. So its burning oil. It still has golden color in it. What I will do today then is buy 2 quarts of the mobile 1 synthetic oil that I'm currently using and top off the oil. I will change the oil filter and the air filter. And I'll go get those NGK spark plugs and I'm taking it to the mechanic next week to do a compression/leakdown test. What do you guys think?
  13. Feb 22, 2020 at 9:57 AM
    Tacoma2468
    Do you guys know what plugs exactly the second gen v6 engines use?
  14. Feb 22, 2020 at 10:00 AM
    Green Jeans
    Oregone
    '13 TRD Off-Road
    6 Denso Spark Plugs #K20HR-U11 Part No: #
    90919-01235 Spark Plug
    90919-01235
    OP there is a search function in the upper right corner of the forum, it looks like a tiny magnifying glass. If you can’t find your answers here for Tacoma stuff then something is amiss.
    Skyway likes this.
  15. Feb 22, 2020 at 10:07 AM
    #35
    Tacoma2468
    Thanks
  16. Feb 22, 2020 at 10:21 AM
    #36
    Greenedmc
    Daniel
    Elizabethton TN
    Sounds like a good plan!
  17. Feb 22, 2020 at 12:57 PM
    #37
    Skyway
    Ande'
    St.Pete
    Definitely :drunk:
  18. Feb 22, 2020 at 6:56 PM
    #38
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Some likely causes of oil loss includes worn/torn valve stem guide(s); worn rings; oil leak; and bad PCV valve.
    If due to worn rings or worn stem guides, it may help going to thicker oil. It helped some on daughters 06 I4 Camry with worn out stem guides. OEM calls for 5/30; went with 10/30 for two years, and am now trying 5/40. Car burns about half a quart every 3K. Not too bad, but hope to reduce it further with 5/40.
    Greenedmc and 07 sport 4x4 like this.
