1056 miles...BOOM
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wawuzit, Feb 20, 2019.
  1. Feb 20, 2019 at 2:45 PM
    wawuzit
    wawuzit [OP] Well-Known Member
    steve
    Clinton, Tennessee
    2019 gray 4dr Tacoma TRD
    none
    .google.com/maps/dir/Clinton,+Tennessee+37716/36.097275,-84.134515/@36.0960823,-84.135275,72m/data=!3m1!1e3!4m8!4m7!1m5!1m1!1s0x885c10ab66f205fb:0x2fa0c5c0f0fecfd0!2m2!1d-84.1318632!2d36.1034126!1m0
  2. Feb 20, 2019 at 2:57 PM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Sounds like every CPS failure thread I ever read. Not saying it is.. but
    Flash1034 likes this.
  3. Feb 20, 2019 at 3:35 PM
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    Sounds like a bad trans fluid temp sensor to me. Computer was told trans fluid was about to boil and went into failsafe to prevent damage. Had a Mazda do that once and dealer said it was normal. What wasn't normal was that the sensor was inaccurate by about 13-15 degrees and told the computer the fluid was hotter than it was.
  4. Feb 20, 2019 at 3:58 PM
    Shellshock
    Iowa
    ^ this. Dealer likely didn’t check it as part of PDI because none of them do
    shakerhood likes this.
  5. Feb 20, 2019 at 4:01 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Well I should have said, “in addition” the fluid may be low. The OP had warning lights and they’re pulling codes, maybe bad crank sensor.
  6. Feb 20, 2019 at 4:57 PM
    charles.headlee
    charles.headlee Well-Known Member
    East TN
    When you said Anderson I could only think of that stoplight.
    Hopefully this is a bad crank sensor, but I'm concerned about moisture getting into electronics. Finding a bad connector takes longer.
  7. Feb 20, 2019 at 5:19 PM
    wawuzit
    steve
    Clinton, Tennessee
    none
    The dealer felt bad about it. They did everything they could to help, I'm sure they'll find the bad part.
    PvilleJohn and shakerhood like this.
  8. Feb 20, 2019 at 5:37 PM
    Tacoma3rdGen
    Tacoma3rdGen Well-Known Member
    New Mexico
    2018 Tacoma Limited
    Let’s hope it’s just a bad sensor... if your transmission temp gets hot enough to trip the warning light, then damage has been done, even if it’s not apparent for a few thousand more miles. Ask to see the transmission fluid, if it smells like burning rubber or looks brownish, then make sure the event is documented by the dealer. You may need a new transmission down the road... again, hoping for a failed sensor.
    PvilleJohn likes this.
  9. Feb 20, 2019 at 6:15 PM
    wawuzit
    steve
    Clinton, Tennessee
    none
    Question..This is the loaner Tacoma they gave me. Is this hood decal a Toyota part number or is it something else?
    [​IMG][​IMG]
  10. Feb 20, 2019 at 6:28 PM
    Tacoma2020
    Tacoma2020 Well-Known Member
    Aftermarket. Adds 25 hp. :)
  11. Feb 20, 2019 at 6:32 PM
    wawuzit
    steve
    Clinton, Tennessee
    none
    Thanks
  12. Feb 20, 2019 at 6:38 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Transmission fluid levels are a notorious issue with Tacomas. And the 3rd Gens have a short history (2016-2018) of transmission issues as it is.
  13. Feb 20, 2019 at 6:39 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Fricking gnawing, hungry rats. The sewer was flooding and they got up to street level and saw a Taco to chew on. Have you seen all those little colored wires all over the engine bay and underneath your truck? Happens all the time. :rant:
    Well, perhaps not that, but maybe the sensor plugs under your truck got wet or loose?
    Good luck with that, how frustrating!
    tcjacado likes this.
  14. Feb 20, 2019 at 6:48 PM
    wawuzit
    steve
    Clinton, Tennessee
    none
    I can't believe how fast Fox Toyota jumped all over this. The only reason I bought a Toyota was the fact everyone I knew bragged about the service at Fox Toyota. I'm a believer.
  15. Feb 20, 2019 at 6:59 PM
    #35
    chriscamilo
    chriscamilo Well-Known Member
    2018 Tacoma DCSB Sport
  16. Feb 20, 2019 at 7:05 PM
    #36
    OnHartung'sRoad
    I love mine- just keep the engine bay dusted in cayenne pepper while camping. Hope the 2019’s have worse tasting wire insulation than mine.
  17. Feb 20, 2019 at 7:23 PM
    #37
    Tacoma3rdGen
    New Mexico
    2018 Tacoma Limited
    Won’t work if camping in lower Louisiana, the Nutria rats love them some cayenne...
  18. Feb 20, 2019 at 7:32 PM
    #38
    Tehkoema
    Tehkoema Well-Known Member
    Ottawa, ON
    2024 TRD Sport 6MT
    let's hope it was all sensors and safety systems that disabled the transmission and not any actual damage. I get pissed when I hear about BS like this any 2-3 year old car, much less a Toyota truck.
    Black64 likes this.
  19. Feb 20, 2019 at 7:37 PM
    #39
    mike2810
    mike2810 Well-Known Member
    Arizona - Rim Country
    had 06 Sport 4x4 , now 2016 Nissan Pro 4x
  20. Feb 20, 2019 at 7:44 PM
    #40
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    I’m in the camp it’s a bad crank position sensor. Good luck op... we’ve all had a hiccup or two.
    shakerhood, Black64 and bulalo like this.
