110v/400w AC power in bed--What do you do with it?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Joe Taco, Jan 3, 2010.
  1. Mar 22, 2010 at 9:02 PM
    Timber
    Timber Crankey Old Yacht Jockey
    Tim
    San Pedro Bay Ports
    just a couple comfort items.
    I have used it for a soldering gun, drill motor, charging camera battery ,cellphone and a rechargeable spotlight, dremel tool, running a laptop, air mattress pump And I think a few other small things that I cant remember.
    Kopasz likes this.
  2. Mar 22, 2010 at 9:50 PM
    TACOBOLTZ619
    TACOBOLTZ619 Active Member
    does the car engine have to be on when the outlet is used??
  3. Mar 22, 2010 at 9:54 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    tacoboltz, No. Just the ignition must be set to "ON" engine does not have to be running.
  4. Mar 22, 2010 at 10:02 PM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I just read the manual on this a couple days ago...finally used the bed power outlet (filled up a inflatable pontoon boat with a elec pump.) The max watts is 115 while driving, 400 if parked. The way I understand it after reading the manual is truck needs to be running for the outlet to operate.
  5. Mar 22, 2010 at 10:06 PM
    Plinkerton
    Plinkerton Well-Known Member
    NorCal
    2013 DCLB 4x4 SR5
    It doesn't seem to have to be running as I've charged my cell phone with it once, and didn't start my truck.
    I kinda thought that it was 400W while idling, and 115W while running as it says on the cover over the outlet.
    It didn't much sense to me, so I took "running" to mean while it was "on", not the truck, but the inverter.
  6. Mar 22, 2010 at 10:21 PM
    Crom
    Nick
    San Diego, CA
    Millions
    Close.
    It's 100W Max when shifter is in any position other than drive for automatic or when clutch is depressed for manual transmission.
    400W with Ignition on and in park or neutral.
    The manual is wrong.
    Yes ignition on, it will work. It's 100W or 400W, not 115W, its 115 Volts AC.
    Did you guys know that many of us, myself included have modified our inverters to run at 400W anytime? It's extremely simple.
    Go here to read about the free easy mod: http://www.tacomaworld.com/forum/2nd-gen-tacomas/25944-110v-factory-inverter-always-400w.html
  7. Mar 22, 2010 at 10:29 PM
    Bullzi511Tacoma06
    Bullzi511Tacoma06 KCCO
    Southeast Louisiana
    2016 MGM Doublecab SR5
    I used it to power my drill while changing out my tail lights. I also used it two summers ago after Hurricane Gustav to run the blender. It's been used here and there for other small projects and to run my laptop as well.
  8. Mar 22, 2010 at 10:33 PM
    BigIslandWahine
    BigIslandWahine aita peapea
    Pualilia
    Island of Hawai'i, Northern Tip
    '07 TRD Sport DC Longbed 4x4
    all stock except sounds. tint, Wet Okoles, Campershell w/Racks
    I didn't use mine to power a skilsaw, tried but it didn't work:( would've been nice if it did so I could build stuff where there's no electricity...
  9. Mar 23, 2010 at 4:46 AM
    MStef66
    MStef66 Well-Known Member
    CT
    06 Tacoma D-Cab 4X4
    Stock
    I found 400 watts to be pretty useless in the bed of the truck so I tapped into the AC line going to the bed and added an outlet in the cab. This way I can power a laptop or charger in the cab.
    What did Toyota have in mind with the 100/400 watt switch? Why limit the power while driving? Anybody know?
  10. Mar 23, 2010 at 4:54 AM
    Breadbox
    Breadbox Well-Known Member
    Northern VA
    TRD Sport, MT, 4X4, SR5
    4" lift; ION and Camburg, custom progressive rear springs no overload; ION Bumps; Roadmaster Active suspension, quick disconnect sways front and rear, Nitro 4.10s, Detroit TrueTrac, ECGS bushing, Aluminess Rear bumper w/swing outs and flood lights, 285/70/17 on ProComp Steelies, Kenwood NAV, URD Short Shifter, CB, front rally bar with LED flows and fogs, RockSliders, FWC.
    Charge computer, Charge Cordless drill. Actually ran a Corded Drill off it but when the drill bound up it did trip the overload and I had to reset the inverter. I've been wondering if there is a way to upgrade the 400w to something more using stock wiring but there is very little room where the inverter is installed? It's great for charging things on the way to a work site so that's what I use it for the most. (I have done the 400W hack so I can charge several things on a power strip as I drive).
    All in all not the greatest inverter but I do find I use it and it's handy.
  11. Mar 23, 2010 at 6:24 AM
    doodle_cakes
    doodle_cakes Well-Known Member
    Canada
    08 Taco SR5 5lugger
    cell phone, air mattress, or plug in a cooler!
  12. Mar 23, 2010 at 6:41 AM
    MachoTaco10
    MachoTaco10 Well-Known Member
    Nick
    New Hampshire
    2010 Tacoma TRD Sport
    love my outlet, use it all the time to charge my power tools on job sites, and vacuum my truck out with it
  13. Mar 23, 2010 at 8:36 AM
    Crom
    Nick
    San Diego, CA
    Millions
    I don't think the riddle has ever been fully answered. We do know that at max current draw (400W), it would pull 33 DC Amps from the electrical system. We also know that those that have the tow package have a 130-amp alternator.
    Some simple math suggests that if we were drawing 33 amps, that leaves ~97 amps for all the other systems that are running. It seems like a lot.
    I theorize that Toyota must have felt that the charging system would somehow be compromised if a continuous 33-amp load was put on the system while the truck was being driven.
  14. Mar 23, 2010 at 9:43 AM
    MStef66
    CT
    06 Tacoma D-Cab 4X4
    Stock
    That sounds acceptable. What draws power while driving vs parked? All lights for one. Is there any electronics pulling power while moving? I suppose the alt. under load will put more drag on the engine like the AC pump I suppose. (Thinking out loud, so to speak)
  15. Mar 23, 2010 at 9:50 AM
    #35
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    I used it to power a cut off wheel to chop my exhaust pipe last week. It wasn't running it at full power but it gave it enough to cut the exhaust pipe.
    I've used it to charge a lot of things.
    Couldn't power a full size vacuum with it. Couldn't power a 1.5HP air compressor with it either. That was annoying.
  16. Mar 23, 2010 at 9:53 AM
    #36
    Tillers_Rule
    Tillers_Rule ......................
    Jeff
    San Diego
    4x4 Sport, debadged
    Icon coil overs up front, Total Chaos UCA, Icon remote reservoir in the back with Deaver 11 pack leafs. Sunroof, Hella 500's behind grill.
    Only time I've ever used it was plugging my laptop in, would sit back there and study for school.
    Oh and filling up air mattresses when camping.
  17. Mar 23, 2010 at 10:15 AM
    #37
    Crom
    Nick
    San Diego, CA
    Millions
    Sorry to digress... But I think I was wrong. Don't we have a 140 amp alternator with the tow package? :confused:
  18. Mar 23, 2010 at 12:18 PM
    #38
    bmgreene
    bmgreene Well-Known Member
    Brian
    L.A. Westside
    2010 PreRunner V6 SR5/OR
    Alcan Leaf Packs, OME884 Coils, 5100 shocks, U.S. Offroad Winch Mount w/Winch, Trail Gear Rear H/C Bumper, Prinsu Cabrack, DIY custom in-bed storage/sleeping deck, Sway bar delete, hidden "snorkel" intake mod, In-dash CB, Bestop Supertop, Undercover Swingbox, hood lifters, assorted lights and front spotting camera
    I've run a dremel off it for cutting a hole in my dash to install a switch.
    For tailgating, you could run a small TV, portable stereo, blender or maybe a mini-fridge on 400W.
  19. Mar 23, 2010 at 12:21 PM
    #39
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    absolutely nothing, has never been used
    tsb likes this.
  20. Mar 23, 2010 at 6:26 PM
    #40
    sleepdr
    sleepdr Active Member
    ID
    09 DC TRD OR, Black Sand Pearl
    Had the truck for 6 months. First use today driving around town, second cell phone battery charging. My BlackBerry Storm 2 has turned into a battery hog.
