110v/400w AC power in bed--What do you do with it?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Joe Taco, Jan 3, 2010.
  1. Apr 7, 2010 at 5:25 PM
    #41
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
  2. Apr 7, 2010 at 5:56 PM
    #42
    mrobey442
    mrobey442 Well-Known Member
    Little Rock, AR
    09 Access Cab TRD 4x4
    smoked out tails, a few avs parts, and BHLM, Alpine Head unit, 2 12 Directed Comp subs, 1200 directed class D amp, Blackhand Cap, besttop
    I use mine for multiple things charging phones, powering tools, and its great for many things while camping.
  3. Apr 7, 2010 at 5:59 PM
    #43
    DANNO2
    DANNO2 Member
    Danno
    Hampton Roads VA
    05 2wd pre-runner, TRD Sport DBL cab long bed
    temp/comp fix, no flaps, tailgate anti theft, tonneau cover, 265x65x17
    It ran a blender just fine during tailgating at a recent NASCAR race...it is worth every penny :)
  4. Apr 7, 2010 at 6:05 PM
    #44
    littledvl
    littledvl ride BMX!
    Eric
    Saint Leonard MD
    08 taco dc 4x4 / 15 tundra dc 4x4
    Too many to list
    Charging my cell phone/camera, thats been about it..
  5. Apr 7, 2010 at 9:22 PM
    #45
    Bullzi511Tacoma06
    Bullzi511Tacoma06 KCCO
    Southeast Louisiana
    2016 MGM Doublecab SR5
    I was a bit disappointed on my camping trip when it didn't run the hairdryer. It did come in handy for the airmattress though.
  6. Apr 8, 2010 at 3:28 AM
    #46
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    ^^ yup...air mattress pumps
    also found out that it'll power my 3 gallon pancake air compressor. should be nice for those air ups after the trails
  7. Apr 8, 2010 at 11:48 AM
    #47
    Jotun
    Jotun Well-Known Member
    Fort Rucker, AL
    DBL cab LB TRD Sport PreRunner
    Can you upgrade the inverter?
    You have a 130 amp Alternator
    You draw 3.4 amps at 400W
    And a 1000w @ 115V + 8.6 amps
    Would that mean you could realistically put a 1000W inverter in there?
  8. Apr 8, 2010 at 12:21 PM
    #48
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
  9. Apr 8, 2010 at 1:01 PM
    #49
    bdwsrjoe
    bdwsrjoe Well-Known Member
    Joe
    Rio Hondo, TX
    08 Tacoma Double Cab TRD Offroad 4X4
    K&N Cold Air Intake, Magnaflow Catback Exhaust, 3" ToyTec Lift Kit, JVC InDash DVD Player with Backup Camera, 2 10" JL Audio Subs, 8K HID Headlights, 8K HID Foglights, N-Fab Nerf Steps, In-Channel Ventvisors, springfield xd40v10, mossberg 500 12ga.
    During a hurricane a few months back i used mine to charge cell phones and a portable dvd player. Last friday i used it on my power drill. I pre-drilled some holes on a 4 inch post to mount a gate for a fence, no problems what so ever....
  10. Apr 8, 2010 at 1:07 PM
    #50
    Redfox1
    Redfox1 'Stralia! Riding Roo's and wrangling koalas
    Conner
    Santa Paula, CA and SLO
    09 Prerunner Sport TRD
    Browning Floor Mats, 275/70/17 BFG All-Terrain T/A's, Procomp 7089 wheels,Rear Spring TSB, Bilstein 5100's, LED roof light, seatbelt chime disabled, CB, UWS Toolbox,
    I was kinda surprised to find that it ran my drill just fine. Which came in handy considering we didnt have a cordless drill and were no where near an outlet.
  11. Apr 8, 2010 at 1:18 PM
    #51
    kjf216
    kjf216 Fitz
    Kyle
    Ridley Park, PA
    2016 Jeep Wrangler Sahara
    Head unit, speakers, LEDs
    used it to run the shop vac a few times but it always ends up shutting off so i guess the shop vac can draw too much, and to charge rc truck batteries dont think i have found any other use yet.
  12. Apr 8, 2010 at 7:29 PM
    #52
    joes06tacoma
    Joe
    Central Coast, CA
    They should have at least put an outlet in the cab like someone posted about. If you are in construction, it could work great for those cordless power tool chargers. Otherwise, if you don't have a camper shell it's kinda worthless. I'm not gonna leave my cell in the bed to charge while I am driving.
  13. Apr 8, 2010 at 8:01 PM
    #53
    Isthatahemi
    TRD OFF ROAD
  14. Apr 8, 2010 at 8:10 PM
    #54
    Isthatahemi
    TRD OFF ROAD
    At 400 watts the Inverter is drawing around 33 amps, not 3.4.
    It is putting out around 3.4 amps.
    A 1000w inverter would draw around 83 amps at full load. And yes the truck could power one, at least for a while. And most inverters will shut down if the supply drops below an acceptable voltage.
  15. Apr 8, 2010 at 8:12 PM
    #55
    Bullzi511Tacoma06
    Southeast Louisiana
    I'm not sure what setting my friend had it on, but it would not run it. Kept knocking off and I had to press the button in the truck again. After 3 tries, we realized it wasn't going to work.
  16. Apr 8, 2010 at 9:06 PM
    #56
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I little review on part of ohm's law: (Sorry for being so geeky)
    P=Power (Watts)
    I=Current (Amps)
    V=Voltage (Volts)
    Watts = Volts x Amps (P=VI)
    Amps = Watts / Volts (I=P/V)
    Volts = Watts / Amps (V=P/I)
    So on the output side you can have 3.48 amps running at 115 volts which will give you 400 watts.
    Not calculating the inverter overhead, it will require more input amperage because there is less voltage from the truck battery. To get 400 watts you will need 33 1/3 amps at 12 volts. (Actually it's more like 14.3 volts when truck is running in order to charge batteries.)
    Now think about why you need 220-240 Volt power to run an oven, Central A/C, and electric dryer in your house. You can get double the wattage with the same amperage. Of course your utility meter measures the wattage you use and you get billed for it.
    I'm also pretty sure that the 400 watt inverter can do a burst of 600 watts (5.2 amp draw) for a short time - maybe a second or 2. Electric motors nearly double the amperage draw they are rated for when they start up. Even a 3 amp rated motorized tool could trip the inverter breaker because it's pulling 6 amps to start up. Inverters and motors are typically rated on continuous watts/amps and not start up watts/amps.
    I'll shut up now.:anonymous:
    Brad68 likes this.
  17. Apr 8, 2010 at 9:28 PM
    #57
    05 X-Runner
    05 X-Runner Murdered X
    Brett
    Napa, Nor-Cal. Whine Country U.S.A
    BSP 05 X-Runner, 07 TRD Sport Super White
    HVM C/F X-Runner badge 1 of 6 made,P/C'ed black rims,Blacked out Billet Grill,BLHM,HID's,Tinted tail covers, Fog light mod,BFLM,C2C Black eyelids,,C2C 1.75" Front drop 2" rear,C2C Hoodstruts,URD Shortshifter,URD T-CAI.Custom Coupe shiftball, NST Manifold Spacer.. 07 TRD Sport Super White,De-badged,White headlight Mod,Fog light mod,White tail light mod,C2C white eyelids, C2C hood struts
    Ive used it to run a blender camping...
  18. Apr 8, 2010 at 9:36 PM
    #58
    thebigk
    thebigk 6 Double 5 3 2 1
    Ken....
    Odessa, TX
    I haven't used the bed one...but I added a 110 outlet in my console off the inverter. Charge my laptop, camera batteries, PSP
  19. Apr 9, 2010 at 6:52 AM
    #59
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    I just look at it and show it off. Never used it, cause it can't power much.
  20. Apr 9, 2010 at 7:34 AM
    #60
    Black Rock Taco
    Black Rock Taco Well-Known Member
    Winnemucca and Reno, NV, Oakland CA
    2011 DBL Cab Tundra
    None, yet
    I was able to make a small 4 cup pot of coffee. It seemed to operate a bit slower than usual, but worked. The bean grinder worked like a champ!!
