12' clutch
Discussion in '4 Cylinder' started by alwaysat8k, Sep 12, 2012.
  1. Dec 5, 2012 at 11:25 AM
    BamaToy1997
    Bill
    Navarre, FL
    I still laugh whenever I see this post. It LOOKS like someone is asking about a 12 foot clutch. lmao
  2. Dec 6, 2012 at 4:21 AM
    alwaysat8k
    alwaysat8k [OP] My truck is slow
    Virginia
    2012 Access Cab SR5 4cyl 5spd 5lug
    Fat Bobs 2.75" spacer, 1.5" Long AAL in rear
    lol.. i definitely fubared the '12*
  3. May 23, 2013 at 12:28 AM
    Hawaii22tacoma
    Hawaii22tacoma New Member
    Nick
    Maui
    2012 tacoma 6spd. Double cab
    My clutch has been smoking in 4x4 hi and in reverse! It has been doing this since 5800 miles, documented at 8800 mi at dealer and at 12000, did a tear down and deemed it not under warranty... I'm looking for better than owm replacement since I have to pay for it anyway... Any ideas? Can't find one for 2012, seems too new?
  4. May 23, 2013 at 8:02 AM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    Wrong truck; this is the 4 cyl thread and the issues with it's clutch. There have been issues with the 6 speed as well, but usually making a noise when the clutch is out. Sounds like a defective clutch or you just smoked it too much. Try another dealer. Check out the 6 speed threads. Good luck.
  5. May 23, 2013 at 8:12 AM
    4banger09
    4banger09 Well-Known Member
    Alex
    Nb, Canada
    09 Tacoma Access cab 4cyl
    Leveled
    I find my whole truck shakes sometimes when I shift but I just figured it was because I shifted too early. Is this a clutch issue or did I just shift too early :s
  6. May 23, 2013 at 8:32 AM
    jassco
    NH
    2023 TRD Offroad
    When you accelerate and push the clutch in there is sort of a clunk or bang that is due to the drive-train being unloaded when you shift. It's the nature of design and the tension on the drive-shaft/carrier bearing. It shakes mine too sometimes going up hills.
    Go under you truck (e-brake in gear) and move the drive-shaft with your hand laterally. Also spin it by hand and you will hear clunks, knocks and probably a lot of movement. You are also pushing larger tires with a lift that probably exaggerates it a little.
  7. May 28, 2013 at 7:37 AM
    Speakerboy
    Speakerboy Well-Known Member
    Jim
    Center Valley, PA
    '02 Xtracab 5 lug manual
    Just to share my experience, I had my clutch replaced under warranty at 14K for slipping. Apparently it was the same issue as the '07-'11 had - leaky slave cylinder boot. It caused a little moisture to get in and not to completely release the clutch, and it smoked itself. I'm not a hard driver, and this is not my first manual vehicle.
