120,000 mile sevice on a Gen 1
Discussion in 'Technical Chat' started by doc1911, Aug 31, 2011.
  1. Aug 31, 2011 at 5:51 PM
    doc1911
    doc1911 [OP] Well-Known Member
    NC
    2018 Pro
    Hey!
    I have a 2004 V-6 TRD 4x4 and it is due for it's 120,000 mile service. I just got back from having a local place take a look at tell me what they thought. They are saying I need to change the timing belt and water pump (should have been done at 90K but I just got the truck 8K miles ago), a major tune-up and the A/C compressor.
    While it would be nice to say I can do that work, I cannot. Here are my questions.
    It will be expensive: $450 for the tune-up, $750 for the timing belt, and $1200 for the AC.
    If I cannot do it all at once, what order should I go........basically, what is the biggest issue?
    The truck runs fine and gets 19 mpg. What is the best way to go about this?
    Thanks
  2. Aug 31, 2011 at 5:53 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    timing belt and water pump... and put in new spark plugs and check and make sure all hoses and air filter are good.
    then go from there
  3. Aug 31, 2011 at 5:56 PM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    ^ ^ This. I would add the tensioners to that list, since there is no reason not to do them while you are getting the other work done.
    Why the A/C compressor? Is your A/C working? What are the signs/symptoms that prompted them to recommend replacing it?
    Fink
  4. Sep 1, 2011 at 6:37 PM
    doc1911
    NC
    2018 Pro
    Thanks for the help. Aside from a possible belt squeeking when I turn on the AC it has been okay. The shop said that when they got it on the lift and ran the engine they could see the pulley attached the AC (????) sease up. They said a small amount of smoke was seena s well. They shut it down and freed the pulley.
  5. Sep 1, 2011 at 6:45 PM
    JML50
    JML50 Well-Known Member
    I agree with nelson...at 100k on my old 02 i had a coolant leak from a rotted hose that shorted out some speed sensor or something. I went ahead and replaced timing belt, water pump, thermo, and all new gaskets and seals. Cost close to a grand but ran like a champ for another 40k until i sold it. If the AC is blowing cold, i wouldn't do anything.
  6. Sep 2, 2011 at 6:15 AM
    Fink
    Orlando, FL
    ^ ^ Bingo.
    If anything, have them replace the belt and see if that helps the "seizing".
    Fink
