120k mi on original transmission fluid - what now?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by slyguy47, Dec 21, 2024.
  1. Dec 21, 2024 at 9:36 AM
    slyguy47
    slyguy47 [OP] Nerd
    Jacksonville, FL
    15 AC TRD OR V6 4WD 5AT
    Bought my 15 Tacoma 4WD Automatic at 50k mi. Now sitting at 121k mi with a 1.5k mi road trip coming up on Monday. I'm the second owner, and the transmission fluid has never been changed to my knowledge. I did add some Lubegaurd Platinum at 90k mi because I think I started to notice some differences in shifts, but by now I've grown accustomed to it, and I definitely wouldn't say my transmission is having any "major issues" (no hard shifts or slips that I can feel, still idles forwards).
    All that being said, what should I do, if anything, regarding the 120k mi transmission fluid? I think a full flush is definitely out of question, but should I even attempt a drain and fill at this point, or just leave it alone entirely.
    If I leave it alone entirely - do you just wait for the transmission to fail entirely and hope it takes many many years before it does?
    UPDATE for new readers: I ended up doing a pan drop drain and fill and replaced the transmission filter with a new one for good measure. Ended up putting in about 5 quarts of Valvoline MaxLife ATF - only that much because I refilled improperly twice (accidently drained from the drain plug the first time, and didn't have the truck running when checking the overflow the second time). See my update posts in this thread for more details.
  2. Dec 21, 2024 at 9:42 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    You speak with knowledge, you know what to do grasshopper? Just do it!
    Black97v6MT, slyguy47[OP] and Mully like this.
  3. Dec 21, 2024 at 10:08 AM
    wmb67
    wmb67 Well-Known Member
    Boston
    09 Dbl Cab Off Road MGM
    I replaced fluid @ 80,000 and am glad I did. Preventive maintenance. If that was my truck, I would definitely do a couple drain and fills. Frankly, I would drop the pan, clean magnets, replace filter & gasket and add all new fluid.
  4. Dec 21, 2024 at 10:23 AM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Watch this video.
    https://www.youtube.com/watch?v=o690DovjDAc
    I changed mine at 120k for the first time as well, and of course drop the pan and clean magnets.... 0 problems, There is absolutely no reason to wait for your transmission to fail
  5. Dec 21, 2024 at 12:09 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I've never seen any evidence that changing it prolongs transmission life. I've been driving 50 years and have never changed the ATF on any vehicle I've ever owned. That's several million trouble free miles. Currently at almost 700,000 combined miles sitting on the driveway including 253,000 on my Tacoma. All with the factory fluid in them.
    In fact, I don't know anyone who has ever changed their ATF. Certainly no one in my family, nor on my wife's side. None of us have ever had any issues.
    The guys at the local transmission shop tell me the same. They claim that if you start at 30,000 miles and change it every 30,000 miles, you'll see MARGINALLY longer transmission life. You might get an extra 30,000 miles out of it, but you'll spend more having it serviced than it will cost you to have it rebuilt.
    Some transmissions are good for 150,000 miles, some 300,000-400,000 and changing the fluid at any interval doesn't significantly change that. The Tacoma transmission is typically good for 300,000-400,000.
  6. Dec 21, 2024 at 12:30 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Yes definitely don’t change it, just run that tranny until it fails. Same with all the other fluids, just run em til they fail. You’ll save lots of $$$ and time. Great idea, don’t know why I never thought of it.
  7. Dec 21, 2024 at 1:11 PM
    slyguy47
    slyguy47 [OP] Nerd
    Jacksonville, FL
    Jokes on you, I save thousands every year by never replacing my blinker fluid! :D
  8. Dec 21, 2024 at 2:01 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Mine got a drain/fill/clean magnet and replace filter etc at about 135K. No issues before, just figured cheap insurance. Still moving right along at 145K
    ridefreak and steelcity2 like this.
  9. Dec 21, 2024 at 2:04 PM
    Sprig
    Ken
    As long as you are using synthetic blinker fluid you are good indefinitely.:)
  10. Dec 21, 2024 at 2:05 PM
    ABA180
    East Bridgewater MA
    If you never use your blinkers, you never need to add fluid.
    There. That's a thing you know now.
  11. Dec 21, 2024 at 2:10 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Different vehicle, but I was moving my daughter's 2014 Corolla with the CVT and 230,000 miles the other day, and thought it felt like it took a second longer than it should have to engage and move.
    I watched some youtube videos and dropped the pan, cleaned the magnets, replaced the filter and gasket and added back the appropriate fluid. It doesn't have a dipstick so the recommendation is to capture what drains out, add that amount plus a half quart, start the car, run it through 'the gears' at idle a few times, wait for it to get to about 104F (infrared pyrometer on the pan and surrounding housing), then remove the plug and let the excess drain out, while running.
    There's a small level tube in there that sets the level.
    It's noticeably smoother now and I only replaced about 3 quarts. I was also happy to see that the magnets weren't too smudged up and overall the fluid didn't look too bad.
    It wasn't a bad job and gave me some peace of mind.
    I think it's also think it's a good way to verify your fluid level.
    My Taco is a manual so I've never had that concern with my truck.
  12. Dec 21, 2024 at 4:23 PM
    Coopsdaddy
    Coopsdaddy Well-Known Member
    Quinton
    2012 dclb tacoma
    6112/5160 Deaver stage 1 Are topper Steelies,255/80/17
    I agree some do live,some live a long time but just like your motor oil.Why not change it.
    It’s cheap and that’s really horrible advise.
    Sharpish, blnewt, ridefreak and 2 others like this.
  13. Dec 21, 2024 at 4:37 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Just drive it and replace when it goes out. I bet you get another 300K out of it, if the frame last that long. I had 325K on the 4Runner when it was sold to a business as a delivery vehicle. Good luck with your truck.
  14. Dec 21, 2024 at 5:35 PM
    TacoTuesday1
    FL
    well shit. Working as a dealer tech all 30 of us in the shop do trans fluid at 40k as it’s called for by the engineers/manufacturer. To easily and cheaply change out old fluid that suspends debris, discolors, and burns. on a transmission that by design is serviceable given the presence of a dipstick, plugs, filter, pan, gasket, and magnets to clean.
    I guess we’re all wrong.
  15. Dec 22, 2024 at 2:04 AM
    kwanjangnihm
    kwanjangnihm Timeout Terminator
    Jeff
    Central Florida
    13 DCLB TRD SP PR OTT
    "If it ain't a longbed it ain't shit! :)
  16. Dec 22, 2024 at 8:46 AM
    MR5X5
    MR5X5 Well-Known Member
    Transmission fluid degrades with temperature. The hotter it gets the shorter the eventual life. For rough numbers, infinite life is below 170F, imminent failure is above 300F. Not exact science, but I'm sure you get the idea. So the question comes down to how many miles has your transmission operated at what temperatures? Pretty impossible to answer accurately. If you monitor your T/C temp you will routinely see it around 200F or more if lugging hills and such. So being above 170F is typical fact of life, hence the fluid is degrading at some rate. Just where it is unknown without running an analysis of your fluid. At 120K miles you should either be changing your fluid, or getting an analysis to prove you don't have to. Dumbing down the road is probably not what you want to do. If you decide to change fluid, search for threads on Valvoline ATF by Gearcruncher to understand why one of our resident tranny experts very much prefers it over the OEM ATF.
  17. Dec 22, 2024 at 9:45 AM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Granted I have a manual, but I replace my gear oil every 50k miles.
    O'DubhGhaill and Flori-duh Taco like this.
  18. Dec 22, 2024 at 10:08 AM
    spitdog
    I originally did a pan dump at 19k and glad I did. I was 3/4 qt. low and in cold weather the tranny would have a slight slipping before it warmed up. This has been reported a number of times on here and it’s due to if you had a tranny cooler or not. The tranny cooler takes an extra qt. Factory filling confusion? Probably!
    Flori-duh Taco likes this.
  19. Dec 22, 2024 at 1:32 PM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    I flushed the fluid at 89,000 miles. I first dropped the pan, checked the magnets and then filled it up then did the flush through the tranny cooler fluid lines. I switched over from the WS Fluid to MaxLife. It has been outstanding, I’ve done a pan drop added fluids (MaxLife and Lubeguard platinum) and all is well. I say start with a pan drop, check the magnets see how much metal is on them, if not much, do a flush after the pan drop. I also say switch to MaxLife. You can also get the strainer/filter off of rock auto and the kit has a rubber pan gasket, https://www.rockauto.com/en/moreinfo.php?pk=4768797&cc=3310144&pt=8600&jsn=837
  20. Mar 8, 2025 at 3:34 PM
    slyguy47
    slyguy47 [OP] Nerd
    Jacksonville, FL
    Dropped and cleaned the pan, and replaced the filter using NAPA kit p/n ATP 17061. There was a small amount of sludge on the magnets but nothing that looked excessive, especially considering this might have been the first pan drop since leaving the factory. Currently at 126k miles. The fluid has the consistency of water, but I read online that might just be normal for ATF? Will be filling her back up with Valvoline MaxLife and report back on results!
    Flori-duh Taco and kwanjangnihm like this.
