oil change makes huge mess
Discussion in 'Technical Chat' started by daggertats, Dec 20, 2010.
  1. Dec 20, 2010 at 2:23 AM
    daggertats
    daggertats [OP] Well-Known Member
    arden nc
    2010 tacoma 4x4 reg cab
    undercover tonneau ,bug deflector, removal of all tacoma emblems added a set of component speakers behind the rear seat egr in channel window visors
    i have a 2010 reg cab 4x4 with a 4 cyl. yesterday i did my first oil change. the filter is located in an awful spot above a skid plate so when you take it off oil drips all over the top pf the skid plate. have any of you come up with a less messy way to remove the filter?
  2. Dec 20, 2010 at 2:43 AM
    Tckwarrior
    Tckwarrior Well-Known Member
    Aaron
    Damascus OR
    08 RegCab Superwhite
    3 inch revtek lift,American Eagle 197 Black Wheels 17x9 Boltpattern 6x5.5 , 285/70/17's with BFG km2s U-haul class 3 tow hitch, Better built toolbox. Trail-gear 58 inch Rock-sliders
    Most people, including toyota technicians remove the oil pan to prevent this. It comes off with 4 easy bolts.
  3. Dec 20, 2010 at 2:50 AM
    84Hilux
    84Hilux Well-Known Member
    Gary
    Vancouver, Canada
    09 SR5 Access Cab V6 4X4
    Stock Fog Lights, Camera Mirror, Arrow Canopy, Lighted 4x4switch, Weathertech Mats (Black), Wet Okoles- Black/Charcoal, Alpine CDA117 Headunit/ Alpine PDX4150 Amp/Alpine PDX M6 Amp/ Hybrid Legatia SE Components/ JL 10W6V2 Subwoofer/ Prototype MR Marv Sub Enclosure
    Get a piece of 5/16 vinyl tubing from the hardware store and stick it on the barb fitting on the bottom of the oil filter mount housing. No need to spill a drop.
  4. Dec 20, 2010 at 3:31 AM
    TacoMal
    TacoMal Well-Known Member
    California
    09 TRD Off Road Dbl cab
    Wet Okole's, Relentless Sliders, Plasti Dipped badges and wheels
    You can also put an empty water bottle right underneath the fitting and all the excess oil will drip into it. Just did it a few weeks ago and I would say it was the easiest oil change I have done. Not a drop spilled.
    Look or feel under where the filter screws in for the barbed fitting. There should be a rubber plug. Pull the plug, insert tube or bottle, then take filter off. The oil will flow out of the barb. No mess!:cool:
  5. Dec 20, 2010 at 4:28 AM
    05 TRD Sport
    05 TRD Sport She's Fat, I'm Drunk, It's On.
    30 minutes south of Atlanta
    2016 SR5
  6. Dec 20, 2010 at 5:18 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Funny, I have an 05 4cyl 2.7l and have both the oem and TRD skids. The oil filter is behind both of them and drips into pan on floor when removing the filter. It doesn't even get on the side of the motor. How do you make it drip on the top of the skids? I have a prerunner, are the skids longer for 4wd? Nevermind, I guess the little drain thingy is what drips on the skid? I don't use that, I just unscrew the filter enough for the little bit of oil that comes out to run off the filter into the pan on the ground. Then when it's done dripping, I remove the filter and dump rest of oil in it into pan. Wipe hand, wipe filter area & screw on new filter filled with new oil. Less mess and time spent fiddling with an extra hose and that drain thing.
  7. Dec 20, 2010 at 5:33 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    Seems Toyota screwed up when they engineered the oil filter location, my 3.4 is a pain and rather than change the orientation of the filter they put in a catch basin with another drain plug. What would have been wrong with a small extension housing that holds the filter upright like the one on an old small block chevy engine, easy to change and you can fill the filter up with oil before you install it. Someone builds an adapter that does that and I will buy it.
  8. Dec 20, 2010 at 5:57 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
  9. Dec 20, 2010 at 2:46 PM
    daggertats
    arden nc
    i think i can get a small pan of some kind on top of the skid plate ...once the weather warms up some ill give it a longer look. the 6 cyl ones look alot easier......maybe ill trade....lol thanks for all your ideas and thoughts
  10. Dec 20, 2010 at 2:50 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    He's got the 4 cylinder not the V6, oil filter isn't located on top and in the front like the V6.
  11. Dec 21, 2010 at 2:28 PM
    Tckwarrior
    Aaron
    Damascus OR
    Props for paying attention
  12. Dec 21, 2010 at 2:29 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I think the filter location on the 2.7 is great...very easy to change.
  13. Dec 30, 2010 at 10:31 AM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    It does not work very well but it's better then nothing - using a plastic bag around the filter when you unscrew it helps a bit. Push the bag up higher around the filter mount as you unscrew. The oil makes this tougher as you go but it should get there. Roll up the sleeves and expect some to run down the arm.
  14. Dec 30, 2010 at 10:43 AM
    jassco
    NH
    2023 TRD Offroad
    Already have that but this does not solve the issue of the filter spilling everywhere for us 4 bangers.
    Time to over think/engineer this:
    I'm thinking of making something simple like a 2 liter bottle cut in half and a rubber band across diameter that pinches and grabs filter after you loosen it. It would be nice as it could catch all the oil and just open the cap on bottom to drain the rest into a container. I don't care much about getting dirty its getting it all over the driveway and truck that pisses me off.
    I suppose you could do even less and just hold a large milk jug or 2 liter cut in half under it as you unscrew it. It may be too tight to make it work without a band holding and turning the filter. Oil change is coming up so I will give this a shot.
  15. Dec 30, 2010 at 11:05 AM
    jassco
    NH
    2023 TRD Offroad
    Yes that would be easier, just have to find a tapered container of proper size for filter. I should get pretty interesting looks at supermarket with a tape measure.......
  16. Dec 30, 2010 at 11:43 AM
    jassco
    NH
    2023 TRD Offroad
    Not really prepared for an answer so thanks for the prep.
  17. Jan 9, 2011 at 8:55 AM
    crashnrondo
    crashnrondo Well-Known Member
    Ron
    Wisconsin
    2021 DCSB Limited
    On my 4cyl I just use a 2 liter soda bottle or 1/2 gallon milk jug, cut the top off and put it around the filter. Break the filter loose and put the jug around the filter and let the filter and oil all fall into the jug. Just hold it there for a minute or so after you drop the filter and wipe up what little oil drips afterward.
  18. Apr 19, 2022 at 7:27 PM
    gusto11071
    gusto11071 Well-Known Member
    Juan E.
    Brewster, NY
    2003 Tacoma Ext Cab DLX 2.7L 4X4
    Rear FJ Cruiser Disc Brakes, Front Tundra Brakes, Heated 4Runner Mirrors, 2018 Tacoma OEM 18" Wheels
    You would not happen to know the size of the oil pan bolts M6 M8 ? also, how long are they? I know it's suppose to be 18 of them.
  19. Apr 23, 2022 at 9:39 AM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    believe they remove the skid plate, not the oil pan. Dunno for sure as don’t have a 4 banger 2nd gen.
  20. Apr 23, 2022 at 9:41 AM
    Bishop84
    Bishop84 Well-Known Member
    Crack it, let it drip slowly into one spot, then remove filter carefully. Clean up.
