12v ingnition ON Source
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jp_flynavy, May 5, 2017.
  1. Jun 12, 2019 at 3:01 AM
    r_to_the_k
    r_to_the_k Well-Known Member
    RK
    HI
    2018 Cement Tacoma TRD SS (Super Stock)
    100% LED Lighting Conversion Fog Lights: - Morimoto XB LED High Performance Projector Fog Lights (H11/5500K) Headlights: - Sampino H11 5500K - Morimoto XB’s Pre-Ordered Front Turn Signals: - Alla Lighting 39-SMD 7443 Amber Yellow LED - TUINCYN 50W 8 ohm 7440 - 7443 LED Load Resistors N-FAB EPYX Side Steps AJT DESIGN Injection Fob Case Lockable Truck Bed Compartments Tailgate Removal Deterrent (Ideal Turn-Key Clamp 5Y020V 3/4"-1 3/4") Additional D-Ring Tie Down Points HitchSafe HS7000 Key Vault Redline Tuning QuickLIFT Hood Struts (PLUS) PowerTrays (Blue Sea 12 Circuit PowerTray) Yakima - Overhaul HD, Truck Bed Rack (55" Load Bars + SB Side Bar) USR Revi Turn Signal Switchbacks w/ DRL Operational Anytime Backup Camera (Full Kit) Spidertrax WHS007 Blue Wheel Spacer Kit (x4) Dashtop Multi-Mount (DMM) Spare Tire Lock ************************************************ MESO Customs Mods: Gashole Ultimate Map Lights Headlight Trim Plates Coin Tray Ultimate Turn Signals Ultimate 3rd Brake Light (BD4-CAM) Extended Fuse Cover Total Tail Stage 2 Minimalist Key Fob Puddle Pods
    Can any one of the smart people watching this thread draw up a wiring schematic for this? I’m not the sharpest pencil in the box, lol. The relay is what is confusing me... I mean, I know I need it, I just don’t know how to wire it up...
    Any help is greatly appreciated!
  2. Jun 12, 2019 at 3:44 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 300+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    I am on my phone so I will do my best to draw a mental picture for you. Take your left hand and make a peace sign. Now turn it horizontal and take your right index finger put it between the two fingers on your left hand and touch your index finger which I assume will be the top finger of your left hand. Your left index finger is terminal 87A the middle finger is terminal 87. The index finger on your right hand is terminal 30. Moving your right index finger between your left index and middle fingers represents the relay turning on and off.. When turned off, terminals 30 and 87A connected. These 3 are the power terminals that carry the load of whatever you're adding. Terminals 85 and 86 are the coil. One of these will be grounded the other will be connected to a fused, switched source like an add a fuse.
    Connect your fused 12v feed to terminal 87 and whatever it is you are wanting to control to terminal 30.
    Keep the wire feeding the fuse to the relay as short as practical as it is unprotected by said fuse.
    Jimmyh and r_to_the_k like this.
  3. Jun 12, 2019 at 12:18 PM
    r_to_the_k
    RK
    HI
    Should I be using a relay for each "addition" I'm using? Camera, USB Step Down Converter, Front Facing Camera, etc...?
  4. Jun 12, 2019 at 5:34 PM
    Larzzzz
    Larry
    MA
    If they're small loads, then sure, why not.
    In that case I'd fuse the feed to the relay, then make a pigtail and use scotch locks to feed a fuse for each thing you want to connect.
    Use a piece of 14 awg wire and a 15 amp Fuse to feed the relay and a piece of the same wire for the scotch locks. Put an insulated butt splice on the end in case you need to extend it. 18 awg with a 1 amp fuse will be fine for the coil power.
    r_to_the_k likes this.
  5. Jun 13, 2019 at 2:33 AM
    r_to_the_k
    RK
    HI
    Coil Power = Battery Power?
  6. Jun 13, 2019 at 3:01 AM
    Larzzzz
    Larry
    MA
    Coil power is what turns the relay on. Terminals 85 and 86. The battery feed for your accessories goes to terminal number 87 and the pigtail goes to terminal number 30.
  7. Jun 13, 2019 at 5:27 PM
    r_to_the_k
    RK
    HI
    Found this on YT...
    https://www.youtube.com/watch?v=uUSxo-CCLR8
    Legit?
  8. Jun 14, 2019 at 2:23 AM
    Larzzzz
    Larry
    MA
    Seems to be.
    Edit:
    @r_to_the_k I mis-read your post. I was describing using one relay to control several things that you want to turn on with the key. The relays are generally rated 20 amps or more.
    Things like lights get their own relay.
