13 MPG??
Discussion in '4 Cylinder' started by raiderfan, Dec 10, 2011.
  1. Dec 10, 2011 at 7:42 AM
    raiderfan
    raiderfan [OP] Active Member
    Western MA
    2011 Access Cab SR5 Auto 4cyl 4x4
    Hey guys. I just bought my Tacoma (2011 Access Cab SR5, 4 cyl 4x4)) a few weeks ago (brand new). I traded in my '02 Dakota for it, which had a V8. I went with the 4 cyl because it was in my price range and really, I don't need anything more. I was also curious as to what I would save in fuel.
    I've checked my mpg 3 times, so far, and was surprised to see that I got 13, 13, and 12 mpg respectively. I only drive "stop and go", around town and live off a hill, but I would think that those things wouldn't make THAT MUCH of a difference (when reading what many of you guys get). I don't drive crazy and only put about 6,000mi per year on my vehicles.
    Truck is stock, with the exception that I replaced the stock tires with new General Grabber AT2's, but they are still the stock size (245/75R16's).
    I've read threads as to how to improve mpg, but I really just want to know how to get what I should be getting, or if something is wrong here. Thanks for any info on what my issue (if any) is.
  2. Dec 10, 2011 at 7:43 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Something is not right, I get a lot better than that in my 6 and my foot is heavy as hell.
  3. Dec 10, 2011 at 7:45 AM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Are you ever towing or carrying heavy loads? How are you figuring your MPG, is it a scan gauge? Is it a used or new Tacoma?
  4. Dec 10, 2011 at 7:47 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Air pressure in tires makes a differance. Different tires than stock may need more air than the recommended amounts by Toyota.
    Make sure you are not in 4WD, although steering on pavement is pretty hard if you are.
    I have a V-6, automatic 4WD double cab... 15-19 mpg is my range in 2WD city to highway. The I-4 engine should get you 21-26 mpg from what others have posted.
  5. Dec 10, 2011 at 7:48 AM
    raiderfan
    Western MA
    No towing or carrying anything.
    I would top the tank off, then set my trip meter to zero, and go from there. Would run the truck until around a 1/4 tank was used, and then filled up again to see how many gallons it took, compared to the mi driven.
    Drove anywhere from 90-92 miles and filled up just under 7 gallons of gas each time, with the exception of this time when i filled up just over 8 gallons.
  6. Dec 10, 2011 at 7:49 AM
    MQQSE
    MQQSE Afoot is the game
    Rob
    Palmer, AK
    Something is not right! Take it to a mechanic or dealer you trust (if there is such a thing).
    From what I've read on here, even the 6cyl folks do much better than that. My '07 Access Cab SR5 4cyl/4x4/5spd averages 20-21 MPG on Winter tires (Blizzaks) and 22-23 MPG on Summer tires. And I don't baby the gas pedal and use 4x4 quite a bit in winter (Alaska).
  7. Dec 10, 2011 at 7:51 AM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Like DavidK said, check your tires, but for them to drop you approx. 10 mpgs, something else is wrong. Have you checked your plugs and wires, something could be misfiring? Does it seem to run smooth? Is there a possibility that someone could be stealing your gas?
  8. Dec 10, 2011 at 7:52 AM
    raiderfan
    Western MA
    I guess i could take it to the dealer and see what they think. Its under its full warranty, but not sure that would cover anything, in this case. Just afraid they would say it was because of the tires that replaced the stock tires -- which i know would not be true after reading a ton of posts on this forum!!
  9. Dec 10, 2011 at 7:56 AM
    MQQSE
    Rob
    Palmer, AK
    Tires of the same stock size aren't going to make a 7-10 MPG drop.
  10. Dec 10, 2011 at 7:57 AM
    raiderfan
    Western MA
    Ha! No, nobody stealing my gas. Must be something else. I am coming up on my winter vacation soon, so I'll have time to stop at the dealer. Thanks guys! I belong to a ton of forums, but have never had as quick responses as this!!
  11. Dec 10, 2011 at 8:00 AM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Welcome aboard Tacoma World!
  12. Dec 10, 2011 at 8:07 AM
    David K
    Don't check your mileage at the 3/4 level... Do the full tank check when you are at the 1/4 tank line or the low fuel light comes on... The mileage does change the longer you drive. It is a 21 gallon tank and there is about 3 gallons reserve between the gauge and what you got really. In other words, when the gauge needle is on the E line, you will only get 18 gallons (approx.) in the tank to fill it. Put your mouse over my info. on the left for more gauge details.
  13. Dec 10, 2011 at 8:17 AM
    raiderfan
    Western MA
    Ok. Had that in the back of my mind, but wasn't sure or not if that would make a difference (checking it so soon). But since I just filled it up again, a couple of hours ago, I will do what you say, next -- run it until just about empty -- to see what I get.
    The truck is brand new (400 mi), so I am hoping and assuming that it is running how it should, as far as wires and plugs go. I mean it seems to run fine. Definitely more sluggish than my dodge, but attributed that to going from driving a V8 for 7 years to jumping into a 4 cyl.
    The tires were installed by a long time tire place in our town. All they do is tires and they have put many tire chains that have attempted to move into our town, out of business. When the business owner put the tires on, he explained to me what psi he was doing for the front and back and then explained why (better grip, more comfortable ride, etc.) Just can't remember what psi he said and haven't checked it, since they were just put on the day after I bought the truck.
    Interested to see what I find now though, by running the truck on gas longer than what I have been. By that time, it should be my winter vacation from work, so if things don't change, then I'll have time to stop at the dealer. Again, thanks a lot guys!!
  14. Dec 10, 2011 at 8:20 AM
    BlueTaco07
    BlueTaco07 Super Mod!
    Cody
    Panama city, Florida
    Looking
    Is it a manual? try running it at the lowest rpms possible I stay at 1750 at 55 mph.
  15. Dec 10, 2011 at 8:25 AM
    TacoTabe
    TacoTabe Well-Known Member
    Kevin
    Northeast PA
    '93 pickup
    The guage reading is irrelevant.
    OP said that he is taking the amount of fuel put in the truck when he fills up and dividing it into the miles driven, and that is an accurate figure of gas mileage- regardless of the fuel gauge.
  16. Dec 10, 2011 at 8:28 AM
    raiderfan
    Western MA
    Automatic
  17. Dec 10, 2011 at 8:31 AM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    Don't panic , truck is brand new and it takes 3-4000 miles before you achieve full gas mileage. it needs to break in.
  18. Dec 10, 2011 at 8:36 AM
    JimmyBuckets
    JimmyBuckets Well-Known Member
    Access Cab 6 speed V-6 sr-5
    I have been seeing the same thing but I have a v6...I decided to take off my cap and have seen a pretty big improvement so far of about 2-3 mpg.
  19. Dec 10, 2011 at 8:38 AM
    raiderfan
    Western MA
    Holy smokes!! It will take me 1/2-3/4 of a year to get those miles!! :laughing:
  20. Dec 10, 2011 at 8:50 AM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    x2
    ??? I have never had to break in a car for mileage? Even if this were the case, he is getting about half of expected, you are not going to break in that much.
