13 mpg
Discussion in 'Wheels & Tires' started by tacotac, Apr 23, 2013.
  1. Apr 23, 2013 at 2:47 PM
    tacotac
    tacotac [OP] Member
    Tobie
    Quebec, canada
    09 dlb cab trd
    i bought 4 tires Toyo Open Country AT2 size 265/70/17 about a month ago and realised i could only travel 400 km with a full tank, thats about 17.5 L/100km.
    is it just the tire size that's f*(*?ing things up ?
    if it is, how can you calculate the exact mpg ?
  2. Apr 23, 2013 at 2:50 PM
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    Check my fuelly stats for comparison. I usually get 15-16mpg city in winter. I did get 13.5 once with lots of idling and -30C.
    In winter, I won't go far past 400km until the light comes on.
    What load range are your tires? PSI? etc.
    Also, when you calculate mpg, you have to account for the size difference. About 3.6% if I'm not mistaken in your case. In reality, you are actually getting a bit better mileage if you did not take that into account. Maybe mid 14's I'm guessing and that is not too much off considering winter gas blend and cold temps still outside.
  3. Apr 23, 2013 at 3:07 PM
    Mikehole
    Mikehole Well-Known Member
    SF Bay Area
    '12 4x4 Short Bed TRD Off Road
    TRD Supercharger, Toytec 3" Ultimate Lift w/ 285/75/16s and planning on OBA for sometime in the future. Also thinking about the HWMS and a Warn 8000 for it.
    The tire size f*&ks everything up. I upsized from 265/75/16 to 285/75/16 and that increased the tire size from about 31 to 33 and the weight per tire from in the 30s to in the 50s.
    The increased tire weight isn't like adding 80lbs in the bed. Its much worse. It eats up rotational force to get those fatties moving, so it takes more power to get going and more brake to stop.
    With regards to mpgs, you need to take the new diameter and divide it by the old diameter, and then you will get the percent increase per tire rotation. I normally multiply my total tank miles by that number to calculate true mileage.
    i.e. 33"/31" = 1.06 => 6% increase in circumference (pi x diamter) => 6% further traveled than the gauges think. My tripometer says I went 237 miles on 17.8 gallons (237/17.8=13.3mpg) then I multiply that by 1.06 for the increased distance per tire rotation and get a true mileage of 14.1.
    My mileage is so bad because I've added a s&^t-ton of weight and screwed up my aerodynamics by adding an aftermarket bumper/winch/supercharger and skids. I also frequently carry heavy and bulky loads for work, which doesn't help mpgs.
  4. Apr 23, 2013 at 3:15 PM
    kryten
    Canada
  5. Apr 23, 2013 at 3:19 PM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    Seriously?...
    Well you take your mileage and divide it by how much has you use...:confused:
  6. Apr 23, 2013 at 3:19 PM
    tacotac
    tacotac [OP] Member
    Tobie
    Quebec, canada
    09 dlb cab trd
    30 psi now
    this winter i had the same mpg but with standard tire size (265/65/17)
    with -20 i think it's normal. But now summer is long gone, 12 degree c at the moment.
    i didn't take the difference of size in my calculation, didn't know how
  7. Apr 23, 2013 at 3:22 PM
    tacotac
    tacotac [OP] Member
    Tobie
    Quebec, canada
    09 dlb cab trd
    seriously?
  8. Apr 23, 2013 at 3:27 PM
    Bobbb
    Bobbb "Rumors of Bob, but never Bob. It is Bob, right?"
    Bob
    Bob
    Bob
    Tundra TRD/OR
    I'm running Toyos in 265/70/17 as well, but the MTs rather than ATs. According to my GPS, when my speedo is reading 65 mph, I'm actually doing 67.5. As I'm primarily highway driving, that 2-1/2 mph difference is what I figure in when doing my usage calcs. Depending on wx, I average between 16-17 mpg normally. Less if I go to town obviously.
    Edit: Also, I'm running 35 psi.
  9. Apr 23, 2013 at 3:30 PM
    teneighty
    Maybe I'm missing something...
  10. Apr 23, 2013 at 4:00 PM
    tacotac
    tacotac [OP] Member
    Tobie
    Quebec, canada
    09 dlb cab trd
    thanks man
    if i calculate the way you did it, it only gives me 13 km more on a full tank.
    giving that my tire size is incrased by 3,4%.
  11. Apr 23, 2013 at 4:01 PM
    tacotac
    tacotac [OP] Member
    Tobie
    Quebec, canada
    09 dlb cab trd
    that's pretty good mpg
  12. Apr 23, 2013 at 4:05 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    That's when a junior gets to take advantage of a senior and tell him to read the entire thread before commenting. :stirthepot:
  13. Apr 24, 2013 at 5:19 AM
    teneighty
    There is no way this can be accurate... There are to many factors to take into account. And if your getting bad mpg with 265/70 it's your driving habits.
  14. Apr 24, 2013 at 5:47 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    it is accurate. i'd usually add the 6% to the mileage, then divide by the gallons used, but it works to the same number. if you read, he's not running 265/70's and also states he has aftermarket bumpers, winch, supercharger, skids, etc that all attribute to the lower mpgs.
  15. Apr 24, 2013 at 8:03 AM
    SickNaban
    SickNaban Well-Known Member
    Huntsville, AL
    10 PreRunner SR5 Double
    i just upgraded to the toyo open country at 2 LT265/75/16 from the stock duflops P245/75/16.....i was getting 21 mpg (mostly highway driving)....i'm now getting between 18-19...not too bad
  16. Apr 24, 2013 at 1:38 PM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    stock duncraps are like one of the worst mpg tire I have ever used for that size
  17. Apr 24, 2013 at 2:08 PM
    tacotac
    tacotac [OP] Member
    Tobie
    Quebec, canada
    09 dlb cab trd
    i drive within the speed limits ,which is pretty slow, and i'm pretty damn smooth with the pedal. So i can't explain it, but i'm at 14 mpg with 265/70.
  18. Apr 24, 2013 at 2:31 PM
    Desert Drifter
    Desert Drifter Well-Known Member
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Icon MT suspension, Pelfreybuilt front bumper, Relentless skids, Avid sliders, Avid custom rack. Pelfreybilt HC Rear bumper.
    My truck came new with 245-75R16 Dunlop Grand Trek tires which were fair on the pavement but I had a rock poke through the tread the first time I went off-road. I wanted to get something more agressive anyway as the stockers had poor traction in rocks, but had hoped to go at least 10k on the stock wheels and tires.
    So at 3k miles I bought a set of Konig 16x8 wheels because I like the style AND they are light. I put 265/75R16 Dura-Trac tires and my fuel mileage is as good as stock when highway driving. Around town I really dont know as I use my triuck for off-road and getting to off-road stuff only. (Not a daily driver). I think tire/wheel weight is more important that most folks realize. PLUS you may be better with 4.10 or 4.56 gears once you step up the 33" tires (285/75R16 or 285/70R17).
    As for my results I attribute it to keeping the cruise set to 70 mph and the light wheels. Also pump those tires up to 40 PSI to lower the rolling resistance. Max pressure is on the sidewall, don't exceed it even when the tires get hot.
