13K/Other Prices for a 1st gen
Discussion in '1st Gen. Tacomas (1995-2004)' started by Falcon016, Mar 4, 2019.
  1. Apr 1, 2019 at 6:07 PM
    #201
    frenchee
    frenchee Favorite Member
    Oceanside CA Area
    2003 Tacoma TRD Double Cab 4x4
    Converted to 4WD DD VW MK6 TDI
    Lol timing belt is like 1 day's worth of work. I wouldn't call it a worry.
    or* everything is a worry on a vehicle with 100k+miles.
    The first gent Tacoma is:
    Timing belt
    Water Pump
    Lower Ball Joints
    Lower Control Arm Bushings
    Steering Rack
    Steering Rack bushings
    Valve Cover Gasket
    Front differential axle shaft seals
    Think I'm missing a few but you get the point. Good to be a DIYer
    Garwood, Gen1FTMFW and Falcon016[OP] like this.
  2. Apr 1, 2019 at 6:08 PM
    #202
    frenchee
    Oceanside CA Area
    Yes that's from the U-Joints.
    Not to be a douche but your first gen will have issues. They all will and it will be pricey if you don't fix em yourself.
    Falcon016[QUOTED][OP] likes this.
  3. Apr 1, 2019 at 8:57 PM
    #203
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Depends on what you call "issues". The ONLY "issues" these trucks are really known for is ball joints and frame rust, which are easily mitigated by buying a truck with no frame rust, and replacing the ball joints thru the factory recall and then at regular intervals (it takes 20 minutes to replace them).
    Everything else people have brought up here and in other threads are simply regular maintenance items that any truck this old would need. Far fewer, really, than your typical domestic vehicles, which is one reason these trucks demand a high price.
    GQ7227 and Gen1FTMFW like this.
  4. Apr 1, 2019 at 9:58 PM
    #204
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    ^This...
    All of the items listed above are easy to do for most people with basic hand tools and simple mechanical aptitude. The biggest issue is to make sure you start with a good frame, everything else is pretty easily interchangeable.
    If you are unsure, you might be able to find a fellow 1st gen owner in the area to go look with you. From the photos you posted, it looks like it has been used, but relatively clean. At the bare minimum, I would plan on doing timing belt etc and LBJ's in the next 20k-30k if you are unsure of the history.
    GQ7227 likes this.
  5. Apr 1, 2019 at 10:26 PM
    #205
    frenchee
    Oceanside CA Area
    Most people don't realize what maintenance is and consider it an issue. Especially when a 3rd gen owner goes from owning a brand new vehicle to a 17+ year old vehicle.
  6. Apr 2, 2019 at 12:43 AM
    #206
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    Good luck. I hope everything will turn out fine for you.
  7. Apr 2, 2019 at 4:16 AM
    #207
    Falcon016
    Falcon016 [OP] Well-Known Member
    2017 Magnetic Gray Metallic TRD Off-Road
    I’m expecting to do any maintenance that I can do by myself. I do have several friends who will help me work on it as well.
  8. Apr 2, 2019 at 4:33 AM
    #208
    tony2018
    tony2018 Well-Known Member
    There's really no way to answer this kind of question,
    GQ7227 likes this.
  9. Apr 2, 2019 at 5:22 AM
    #209
    BeardedTacoma
    BeardedTacoma Well-Known Member
    Justin
    Hotlando
    2000 Tacoma x-cab 4x4 (SOLD)
    :popcorn:
    Take your time OP.
    GQ7227 likes this.
  10. Apr 2, 2019 at 5:23 AM
    #210
    BeardedTacoma
    Justin
    Hotlando
  11. Apr 2, 2019 at 8:32 AM
    #211
    frenchee
    Oceanside CA Area
    Thats great. The last truck you posted looks nice
    beikokupilot likes this.
  12. Apr 2, 2019 at 9:06 AM
    #212
    jbrandt
    Justin
    Even new cars require maintenance, it's just usually included in the price for the first year or 15k miles or whatever.
    If that's an "issue", then you should lease a car instead of own one, and certainly shouldn't be considering owning a car 17+ year old car.
    GQ7227 likes this.
  13. Apr 2, 2019 at 9:26 AM
    #213
    GQ7227
    GQ7227 mw survivor
    J A Y
    back when my local Toyota dealer had the all-inclusive routine maintenance packages, 5k,15k,30k,etc it was always something I looked forward to doing :)
    now its do this now do this later don't know if it needs it or not lol
    i have not really liked this adhoc maintenance they switched too
  14. Apr 2, 2019 at 9:29 AM
    #214
    RysiuM
    Rysiu
    My 2012 4Runner from the very beginning had the same issues as 95.5 Tacoma: I had to do oil change, I need to grease U-joints, change tires, and fluid film the whole frame every spring. Not mentioning the worst problem both cars have: I have to fill the fuel tank every so - somehow that liquid I put in there disappears over time.:angrygirl::annoyed:
    frenchee[QUOTED] and GQ7227 like this.
  15. Apr 2, 2019 at 9:40 AM
    #215
    frenchee
    Oceanside CA Area
    I'm not sure what point you're trying to make.
  16. Apr 2, 2019 at 10:02 AM
    #216
    jbrandt
    Justin
    You're the one who brought up 1st gens having "issues". I'm just having a conversation about how if you consider regular maintenance an "issue" you probably shouldn't own an older car. For most of us it is a non-issue, being that we own best gens and most of us do our own tinkering and maintenance.
    It's not like old Toyotas start wearing out faster as they age which seems to be the case with some older domestics. You still do a timing belt every 90k, ball joints at 50k or whatever it is, and replace all the rubber stuff that gets hard and cracks whether it has 50k or 600k miles on it.
    People might consider that an issue if they've never owned a car long enough for some of those parts to start wearing out. I'm sure some people consider changing their oil an "issue", and those people should be driving one of those Gig car things and not actually own anything, lol.
    GQ7227 and RysiuM like this.
  17. Apr 2, 2019 at 10:18 AM
    #217
    GQ7227
    GQ7227 mw survivor
    J A Y
    what issues :notsure: my A/C needed a recharge, new catback exhaust and new rubber on the wheels ... only issues I have had in 22yrs ... my dear sister goes through 'detroit' cars like butter ...
    i am waiting for the day i have to overhaul and rebuild my engine :D is that routine maintenance, it might be to get it to one million miles!?
    jackn7 likes this.
  18. Apr 2, 2019 at 10:18 AM
    #218
    frenchee
    Oceanside CA Area
    Is it a conversation though ? Sounds like you're trying to prove exactly what I said. First gens have issues because they've reached a certain mileage. You can try and define "issues" all you want but for most people that don't DIY and have only owned new cars, all the maintenance due after a vehicles 100k mark could be too much for them to deal with.
    That's why I posted that list right after a picture of a greasy a U-joint was posted... If you're considering leaks or any non critical "issue" as a reason to not buy the Tacoma then you shouldn't own one. This is someone with a 3rd gen that might be turned away by the maintenance an older vehicle requires. That's exactly my point.
    My 2011 VW TDI has 0 maintenance "issues" because it hasn't reached 100k, and guess what? It'll be sold right then and there. All vehicles need regular maintenance such as tires and oil changes. That's very different than steering rack or cooling system replacement because those components have reached the end of their lifetime.
    GQ7227 likes this.
  19. Apr 2, 2019 at 10:20 AM
    #219
    frenchee
    Oceanside CA Area
    In addition to that^ It will be sold exactly when the warranty has ended.
  20. Apr 2, 2019 at 10:36 AM
    #220
    GQ7227
    GQ7227 mw survivor
    J A Y
    i have never heard of any ball joints issues :notsure: my local Toyota certified mechanic gave my truck a good looking over for an hour and did not mention any issues in that area (I am not all that mechanically inclined so don't hate me! be easy!)
