13K/Other Prices for a 1st gen
Discussion in '1st Gen. Tacomas (1995-2004)' started by Falcon016, Mar 4, 2019.
  1. Apr 2, 2019 at 10:40 AM
    #221
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    You need to do some research then. LBJ failure can be catastrophic on these 1st gens. Check regularly and often. If remotely questionable, replace. It has been pretty well covered on TW, but OEM balljoints are the wise decision vs aftermarket. That is a different discussion entirely though.
    GQ7227[QUOTED] likes this.
  2. Apr 2, 2019 at 10:51 AM
    #222
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I'm not trying to prove anything. I just have a different definition of the word "issue" that you seem to, and enjoy discussing these types of things.
    I guess my standards for what constitutes a car having "issues" changes based on its age, and the things that are expected to wear out on it. Like if I had to replace the steering rack bushings or body mounts on my '17 4Runner, I'd consider that an "issue." But those same things on a 20 year old truck are pretty normal and I certainly wouldn't replace the entire truck because certain items on it have reached their design lifetime.
    We definitely agree that if that's too much, be it regular maintenance"issues" or whatever, you probably shouldn't own one.
    GQ7227 and frenchee[QUOTED] like this.
  3. Apr 2, 2019 at 11:06 AM
    #223
    jbrandt
    Justin
    It's a known design flaw. The ball/cup are under pressure (being pulled apart by the coil spring) and when(if) they fail, they can fail catastrophically.
    Not to spook you, but just google "tacoma ball joint failure", and you'll find plenty of pics of failures. There was a recall on them, too, which was a quality control issue, that made a failure more likely due to premature wear.
    More than likely the technician didn't mention it because either the truck wasn't included in any recall notice, or the recall had already been done.
    It's a 20 minute job to replace them if you have the right tool ($15), so it's something to look into.
  4. Apr 2, 2019 at 11:08 AM
    #224
    GQ7227
    GQ7227 mw survivor
    J A Y
    would I feel some abnormal steering before they go?
    I don't recall getting any recall notice in mail
    maybe run my VIN somewhere and deal with all the bs at the dealer again?
    I just found out yesterday that the dealer mechanic at some point had stripped and rounded my front diff drain plug!
    thanks for the info
  5. Apr 2, 2019 at 11:12 AM
    #225
    frenchee
    frenchee Favorite Member
    Oceanside CA Area
    2003 Tacoma TRD Double Cab 4x4
    Converted to 4WD DD VW MK6 TDI
    Makes sense. The majority of people don't realize older vehicles need maintenance and classify it as "issues". That's why a lot of people drive newer vehicles.
    I see red flags when you have someone with a 3rd gen buying a first gen to keep the miles off the 3rd gen. Both vehicles will need maintenance and if grease on the u-joint is something they aren'
    t familiar with, then owning a first gen might be way too much of a headache. All it takes is less than 2 grand and a couple weekends to have a completely refreshed first gen. But you need to know what you're doing. Also I'm very pro preventative maintenance.
    GQ7227 likes this.
  6. Apr 2, 2019 at 11:13 AM
    #226
    frenchee
    Oceanside CA Area
    Sudden failure, crash into a ditch unfortunately.
    Preventative maintenance item you should 100% do. I know there's one guy on here that swears against replacing them preventatively before 200k or so but I rather not play Russian roulette.
    kakwvu and GQ7227[QUOTED] like this.
  7. Apr 2, 2019 at 11:16 AM
    #227
    jbrandt
    Justin
    For sure. When I did my front end bushings (suspension/steering), BJs, TREs, it drove like a dream after that. The Kings probably didn't hurt, lol.
  8. Apr 2, 2019 at 11:20 AM
    #228
    GQ7227
    GQ7227 mw survivor
    J A Y
    thanks for the info, I will discuss that with mechanic on service due next month
  9. Apr 2, 2019 at 11:22 AM
    #229
    jbrandt
    Justin
    Hard to say if you'd really "feel" anything. If you look up the design specifications, you need a special factory service tool to even test to see of there is enough slop in the ball to be "out of spec." The tolerance for "slop" is so small, that if you can feel ANY slop in them, they are way out of spec and need to be replaced asap.
    You can run your VIN at a dealer or most other shops, too, and they can tell you if your truck needed the recall. Newer trucks I believe don't have that recall since the issue was fixed early on.
    I have written a whole manifesto on balljoints (as has everyone else, lol), just search my name and ball joints and you'll probably find it, if you care. But basically don't go super cheap on BJs (the store brand), but if you can't afford OEM, cheaper ones like 555's are a good alternative and your truck won't blow up.
    GQ7227[QUOTED] and frenchee like this.
  10. Apr 2, 2019 at 11:23 AM
    #230
    frenchee
    Oceanside CA Area
    Yeah I'm half sarcastic ass so listen to Jbrandt for valuable info.
    But def look into them.
  11. Apr 2, 2019 at 11:24 AM
    #231
    jbrandt
    Justin
    That's the 17 year old who claims he doesn't need to do it because his truck still has the originals, right?
    This is the same kid who thinks balljoint spacers are ok. So take his opinions on Bjs with a grain of salt, lol.
  12. Apr 2, 2019 at 11:25 AM
    #232
    jbrandt
    Justin
    Oh god, I'm at least as much of a sarcastic ass as you...
    frenchee[QUOTED] likes this.
  13. Apr 2, 2019 at 11:35 AM
    #233
    GQ7227
    GQ7227 mw survivor
    J A Y
    what the heck you all scare me now :oops:
  14. Apr 2, 2019 at 11:36 AM
    #234
    GQ7227
    GQ7227 mw survivor
    J A Y
    my toyotech mechanic will most certainly not use non-OEM parts unless they have been discontinued
  15. Apr 2, 2019 at 11:56 AM
    #235
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    I never considered Toyota with 100k miles to start having "issues" :der:. "Issues" had my 96k miles (5 years old) Mercury Sable (my first and last ever "Detroit" car).
    LBJ design is not really a flaw - I'd consider it as not having built in "redundancy-security", so when they fail they fail with not nice consequences (but you can tell the same about brakes). I replaced my factory LBJ after 23 years and 319k miles just because you guys told me. Both LBJ were still very close to the new ones (took a little bit less force to move them, than the new, bot not leaks and no lose). You can't blame Toyota for failure after driving with teared up boots, or not having a long run on "Napa-branded" parts.:jerkoff:
    1st gen Tacoma is long enough to actually prove the reliability. Some other brands of that age are already done (in general), or turned into collector's toys. 1st gen Tacoma is still a "working truck", good enough to keep it because the cost of owning it for next 10 years is way less than the cost of replacing it. If not including "maintenance" items from the book and normal tear and wear items (tires, battery, brakes) My truck cost me less than 2k during my ownership since 1998.
    In 2015 my neighbor donated his 2005 320ML for tax write off because the cost of repairs needed was over 10k (even with aftermarket parts). There were issues not only with the engine but almost in every other system in that Mercedes: California Emission, brakes, cooling, AC, power steering, suspension - almost anything I could point at, needed repairs besides body and glass. I have yet to see any 1st gen Tacoma donated for tax or "gas guzzler program".
    GQ7227 and jbrandt like this.
  16. Apr 2, 2019 at 12:02 PM
    #236
    JKO1998
    JKO1998 Well-Known Member
    Utah
    You’ll definitely feel a difference when your LBJ’s fail
    I lost some bolts and sheared the rest here but some idea
    kakwvu, beikokupilot and frenchee like this.
  17. Apr 2, 2019 at 12:04 PM
    #237
    frenchee
    Oceanside CA Area
    LOL
  18. Apr 2, 2019 at 12:05 PM
    #238
    frenchee
    Oceanside CA Area
    LOL, yeah I think that's him. Too funny.
  19. Apr 2, 2019 at 12:39 PM
    #239
    GQ7227
    GQ7227 mw survivor
    J A Y
    HFS :eek: hope I am not going 80mph down I-80 when that happens
  20. Apr 2, 2019 at 12:43 PM
    #240
    jbrandt
    Justin
    That appears to be more an issue with a failure of the bolts that hold it to the spindle (not torqued properly, defective bolts, etc.). The BJ itself appears more or less intact.
    The "problem" failures are when the cup separates from the ball.
    frenchee likes this.
