Is there a trick to the 2.7 oil filter? Its messy!
Discussion in '4 Cylinder' started by snoozeworm, Mar 7, 2011.
  1. Mar 7, 2011 at 11:04 AM
    snoozeworm
    snoozeworm [OP] taco king
    wheeling,wv
    2004 regular cab 4x4 5 speed
    Extra leaf springs in rear Pioneer head unit fj cruiser wheels 1in coil spacers siren
    I always change my own oils, my s10 and ranger (past vehicles) and mustang + motorcycle (current) are all a breeze to change the oil/filter in. My 2004 2.7 tacoma is a pain! I drain the oil from the motor first, then i go to unskrew the filter and me and my truck get drenched in oil!
    is there a trick to getting the filter off in a cleaner manner?
  2. Mar 7, 2011 at 11:06 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I would always use a bunch of rags under the filter.
  3. Mar 7, 2011 at 11:25 AM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    I had a 98' for 9 years and after the filter was a bit loose, I would stand on the passenger side (using a plastic box or cooler) and I would remove the filter with my left and as soon as it was off, I would bring it up through the engine compartment only spilling just a bit. It was an 'art form' to say the least. I got really good at it doing oil changes for 112K miles...
    I bought an 08' 4.0L and when I found out when the filter was I smiled all the way home (on the new ones it's on top of the enguine) :)
    Be patient , stick with it and after a few changes it will get easier..
    AZbackcountry
  4. Mar 7, 2011 at 1:00 PM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    A few threads on this one, but the general consensus is to just cut a 2 liter bottle in half place it under filter and unscrew it. I did this a few times already and it works pretty well with no mess. You also have a nice screw cap on the half bottle which makes pouring the rest of the oil from the filter easy. Also a funnel as well for pouring oil out of the basin back into jug.
    3 X win!
  5. Mar 7, 2011 at 1:08 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    after draining the oil, I put a plastic walmart bag under the filter when removing it. make sure it doesnt have any holes first though.
  6. Mar 7, 2011 at 1:16 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    I just did my first change last month and this is the exact technique that I used, then just lifted it up and out of the engine compartment, didn't spill a drop.
  7. Mar 7, 2011 at 1:17 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I just unscrew the filter enough to let the oil leak out from around the seal, and I keep the container to catch the oil situated directly below. Once its done leaking, I just unscrew it the rest of the way off. Never really spilled a drop...except the one time that I dropped the filter into the oil container and splashed hot oil all over myself.
  8. Mar 7, 2011 at 7:43 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    ^^This is what I do too, and strangely enough I've dropped the filter into a hot pan of oil as well.
    Several years ago I had a rubber cup that was made to fit on an oil filter when removing the filter. It was just large enough so that when the oil ran out of the top of the filter the cup would hold all of it. Pretty useful. I wish I could find one again.
  9. Mar 8, 2011 at 3:59 AM
    snoozeworm
    wheeling,wv
    I like this alot, i think i will try it next time
  10. Mar 8, 2011 at 4:15 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    And here I thought I was the only one who didn't mess with that little drain tube thingy up by the filter to drain what's up there. Cool. I just put the big ole thirsty oil pan underneath and let it drip into pan then dump the filter out in the pan. Yes, i have dropped it in the pan a time or 2 also while dumping the filter. Still never feel the need to mess with that drain tube thing tho.
  11. Mar 8, 2011 at 4:31 AM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Spin it off, new one on, hit it with brake cleaner.
    Most of you guys are at home though.
  12. Mar 8, 2011 at 7:39 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I drain the pan first, then break the filter just barely loose but don't unscrew it. I get a piece of cardboard about 8" x 14", fold one edge over the short end and wedge it beween the filter base and the block. This creates a sort of ramp or shield protecting the block. Then I unscrew the filter enough to leak and the used oil drips down the cardboard into the pan. Once the filter has drained enough, I wiggle it to get some more out, then unscrew it the rest of the way and remove, and discard the cardboard. This technique keeps things pretty clean although next time I might try the plastic shopping bag without holes. And while I like that the filter is mounted vertically with the hole straight up, it could be more accessible.
  13. Mar 8, 2011 at 10:53 PM
    MidnightSun
    MidnightSun Active Member
    Tim
    San Francisco, CA
    2002 PreRunner Double Cab
    I'll try this next time. Sounds pretty good. Thanks for the tip.
  14. Mar 8, 2011 at 10:56 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Anybody punch a hole in the bottom of the filter first to drain it before removing it?
  15. Mar 9, 2011 at 9:06 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I just got done changing my oil about 5 minutes ago, and I used the same method as I mentioned above. Unscrewing the filter just enough to allow oil to leak around the seal works very well...I don't see any reason to try and put a hole in it to do the same thing...
  16. Mar 9, 2011 at 10:50 AM
    Sheepshead45
    Sheepshead45 Well-Known Member
    NC
    PreRunner SR5
    I tried the plastic grocery bag thing too but realized too late that the thing leaked like a freakin seive, what a PIA.
    Now I use a gallon size zip lock bag, no leakage.
  17. Mar 9, 2011 at 3:18 PM
    frog13
    frog13 Well-Known Member
    Oh joy....have been considering a 2.7L 4x4 for awhile now.You folks are saying the filter is a PIA,as in the positioning,or,it's just alittle messy? any photo's to show this "issue".
  18. Mar 9, 2011 at 3:27 PM
    jassco
    NH
    2023 TRD Offroad
    This thread is discussing the oil which flows out on top of filter when unscrewing it. Like most cars old and some new have upside-down filter. If you are basing purchase decision off filter location, though commendable thought process, I cannot help you.
  19. Mar 12, 2011 at 4:05 PM
    The Shape
    The Shape Well-Known Member
    Forrest City, AR
    '09 Access Cab A/T 4banger
    I just changed the oil in my wifes yaris this morning. It has the same design upside down filter like the 2.7 Tacoma, I was thinking about this thread while under the car. I really don't find it to be that messy, just break the filter loose let it drain a bit and then screw it off and replace :notsure::notsure:
  20. Mar 12, 2011 at 6:59 PM
    frog13
    Mess is normal(try changing oil on a Honda xr650L DS bike)PIA oil filter location is not acceptable though....I get it(mess...no big deal).
