15 psi turbo on stock manifold?
Discussion in 'Performance and Tuning' started by GoHigher, Jul 17, 2014.
  1. Jul 17, 2014 at 1:14 PM
    GoHigher
    GoHigher [OP] Well-Known Member
    Jake
    Colorado
    06 Doublecab
    Just curious if anyone has put a turbo to a stock manifold on the 1grfe. If so did you upgrade gaskets or anything? Thanks.
  2. Jul 17, 2014 at 7:34 PM
    Eggbert
    Eggbert Well-Known Member
    PA
    '14 dcsb TRD OR Supercharged
    TRD Supercharger, MBRP DualCatback, DT Shortie Headers, Regeared with 4.56 ECGS 3rd and Clamshell, URD 2.55" Stealth pulley, AEM Methanol 5 gallon kit, URD Perf Thermostat, NST Lightweight crank pulley, URD 61lb injectors, Mishimoto Oil Catch Can, URD Fuel Pump upgrade, AEM Boost and Wideband gauges, OEM FPR Mod, RBP Black Exhaust Tips, Icon Stage 6, Fuel Octane wheels, Nitto Terra Grapplers 285/70/r17, Color match rear bumper, Color match hood with skewp, Color match grill, Color match valance, Derped grill emblem, Derped Tuffbar bullbar, OEM Skidplate, AVS Ventvisors, Bodyside Moldings, RBP RX3 nerf bars, Color Match Bushwacker Pocket Flares/Rivets, Undercover LE Tonneau, Katzkin heated leather, Bel Stir-Plus Radar, Sprint Booster, Dynamat/Hushpad, Polk dxi691 - front, Polk dx1651 - rear, Alpine KTP-445U Power Pack, Front tint 35 percent, Weathertech front mats, Smoked tail lights, LED DRLs, Coupe TRD Battery tie-down, Coupe TRD CAI Cover
    Might want to check out the xr-underground forum. They run all sorts of cool boosted shit over there. Some awesome builds.
  3. Jul 18, 2014 at 10:00 PM
    J0HN_R1
    J0HN_R1 Well-Known Member
    Calgary, Alberta
    2014 Tacoma TRD Sport DCSB
    Bilstein 5100's @ 2.75" FR, Deaver 1.5" TSB leafs RR, SpiderTrax 1" spacers, custom LED interior & bed lights, 2005 4Runner Sport 17" wheels powder coated satin black
    WHICH manifold...? Intake or exhaust ?
    Short answer is yes... And yes.
    * no one mass-produces an aftermarket intake manifold for the 4.0L V6...
  4. Jul 19, 2014 at 8:37 AM
    GoHigher
    Jake
    Colorado
    06 Doublecab
    Intake obviously... you don't put boost to exhaust. I figured I can just flip my exhaust manifolds side to side and cross pipe on top. Thanks for the info.
  5. Jul 19, 2014 at 8:39 AM
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
  6. Jul 21, 2014 at 10:55 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Thanks Gaunt. :thumbsup:
    GoHigher, I am sure you are already doing your homework, but I will reiterate anyway. Aftermarket components depending, the stock block won't handle the power that associated with the psi which could pop the OEM upper plenum. It will handle 1 BAR all day long, the upper plenum.
    How much power are you planning on making, which turbo are you planning on running, and are you planning on doing internals?
  7. Jul 21, 2014 at 3:58 PM
    GoHigher
    Jake
    Colorado
    06 Doublecab
    I'm really just looking for 350 max. Being as that's how much this motor should put out with the size of the truck. I have a turbo laying around my shop from an 02 Volvo c70. I believe it is a Garrett. Unstamped. I've actually been entertaining the idea of mating a "dremel" style motor (geared up of course) to the compressor side of a smaller turbo and eliminating the turbine side. Use a primary/secondary type coil system to step voltage up to around 48 and use a potentiometer on my pedal... probably a pipe dream lol. As far as internals I hadn't planned on doing any. Injectors if I have to. As soon as this motor goes I will probably just put a 4bt in it.
  8. Jul 21, 2014 at 4:00 PM
    GoHigher
    Jake
    Colorado
    06 Doublecab
    And by the way. Huge admiration from a master tech to you tor. Not many people have the balls to dive into their vehicles much less to the extent you have. Props.
  9. Jul 21, 2014 at 7:32 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    From one innovator to another. Not content with idle. Thank you sir. :thumbsup:
