15k miles...what maintenance other than oil change?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Newtacoma19, Feb 5, 2024.
  1. Feb 5, 2024 at 1:57 PM
    Newtacoma19
    Newtacoma19 [OP] Well-Known Member
    SSM utility 19
    My truck is 2019 SR 4 cyl auto utility has 15k miles.
    Brought it brand new. Only fluid I’ve needed changed thus far is the oil. I’m wondering being a 2019 and only having 15k miles, (oil sticker says change due couple weeks ago in December) anyone know what other than having oil changed again are items I definitely should have done instead of just pay to have them done as dealer recommended at these intervals?
  2. Feb 5, 2024 at 2:08 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Change oil rotate tires every 5,000 miles.
    If not already I'd put a new battery in it. NeverStart ( wmart Everstart ) 24F
    If anything like my 2021 at 15,000 miles the OEM Tires were shot already.
    New set of Wildpeaks may be in order.
    Barsoom likes this.
  3. Feb 5, 2024 at 2:15 PM
    MegaHurts777
    MegaHurts777 Well-Known Member
    Jacob
    ID
    2019 Tacoma TRD Off-Road (MT)
    These are my fluid change intervals based on the suggestions from the CarCareNut.
    I prefer to lean towards more frequent vs stretching out change intervals for things.
    Now the only thing that applies to you would be changing the diff oil I think, mine was pretty sparkly at about 8k miles new.
    It's normal for some of these parts to wear in, which is why the first few oil changes might be a tad more frequent then when it's all broken in/good to go.
    *Engine Oil
    5,000 miles or 6 months
    Engine Oil Drain Plug Gasket x10 (dealer) | 90430-12031
    Oil Drain Plug.....30 ft/lbs
    Oil Filter housing 18 ft/lbs
    Fill: 6.1 - 6.2quarts(if you have the towing package)
    *Front/Rear Diff Oil
    Every 2 years or 30k miles
    TAKES QTY 3 TWO FOR REAR DIFFERENTIAL AND 1 FOR FRONT DIFFERENTIAL (dealer) | 12157-10010
    TAKES QTY 1 FOR FRONT DIFFERENTIAL (dealer) | 90430-24017
    Rear diff drain plug - 36 lb-ft (24mm or 15/16")
    Rear diff fill plug - 36 lb-ft (24mm or 15/16")
    Front diff drain plug - 48 lb-ft (10mm hex)
    Front diff fill plug - 29 lb-ft (10mm hex)
    No. 2 engine under cover assembly - 22 lb-ft (12mm)
    Diff housing bolts - 28 ft-lbs (new spec vs old 18 ft-lbs)
    *T-Case
    Every 30,000 miles
    GASKET; RING (dealer) | 90430-A0003 or 90430-18008 = 2
    Transfer Case [2]
    Fill Plug 27 ft/lbs
    Drain Plug 27 ft/lbs
    1.1 quarts to full
    GL5 based fluid
    *Manual Transmission
    Every 60k miles or 6 years
    Transfer Case Shift Shaft Seal / Front, Rear (dealer) | 90430-A0003 or 90430-18008
    Manual Transmission RC62F [2]
    Fill Plug 27 ft/lbs
    *Coolant
    Every 50k or 5 years
    *Air filters
    Cabin Air Filter - Every 10,000 - 30,000 miles
    Engine Air Filter - Every 10,000 - 30,000 miles
    *Brake Fluid
    Every 3 - 5 years
    Toyota Dot3 Brake Fluid (dealer) | 004751BF03
    *Power steering fluid
    50,000 - 70,000 miles
    10 Years or staining
    Toyota Automatic Transmission Fluid (dealer) | 00718ATF00
    CarCareNut suggested? Idemitsu PSF Power Steering Fluid - 12 Oz (what originally comes with the truck)
    *Serpentine belt
    60,000k? (I need to pin down a change interval for this)
    *Spark plugs
    60,000 miles or 6 years
    Spark Plugs (dealer) | 90919-01263
    Engine Intake Manifold Gasket (dealer) | 171770P030
    Spark Plug.....13 ft/lbs (no Anti-Seize)
    Coil bolt.....7 ft/lbs
    Wiring harness bolt.....7 ft/lbs
    *Grease u-joints (if applicable)
    5,000 miles under special operation
    15,000 under normal operation
    VaToy, Teuton and Rednecktacoma22 like this.
  4. Feb 5, 2024 at 2:17 PM
    Cetacean Sensation
    Cetacean Sensation Never lost in a parking lot
    PNW
    6MT ELM Taco (slow) // N54 BMW 135 (fast)
    That's a solid list!
    Serpentine Belts don't really have an interval. You just inspect them once or twice a year while doing other services and change as necessary.
    MegaHurts777[QUOTED] likes this.
  5. Feb 5, 2024 at 2:31 PM
    Newtacoma19
    SSM utility 19
    My truck is 2WD completely stock including Steelies and tire size. Except for topper on back.
  6. Feb 5, 2024 at 2:40 PM
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    Don't forget to top off the blinker fluid.
  7. Feb 5, 2024 at 3:50 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    oil every 10k
    rotate every 5k
  8. Feb 5, 2024 at 4:00 PM
    Bishop84
    Bishop84 Well-Known Member
    While rotating a quick adjustment of drums.
    They do not self adjust, I'd say a small drum adjust every 10k at least.
    Thats about it besides oil changes in the first years.
  9. Feb 5, 2024 at 4:23 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Change cabin/engine air filters
    Flush brake fluid and clutch fluid if manual
    Just drive it
  10. Feb 5, 2024 at 4:38 PM
    wazepd
    wazepd Waze Map Editor
    NJ / NY
    2022 Tacoma TRD Off Road
    Commercial Pilot
    https://www.tacomaworld.com/threads/3rd-gen-maintenance-maps-get-300k-miles.789809/
    This is pinned in the 3rd gen forum
    Chew likes this.
