15x8's on an 03 TRD
Discussion in '1st Gen. Tacomas (1995-2004)' started by haolerot, Dec 14, 2011.
  1. Dec 14, 2011 at 12:22 PM
    haolerot
    haolerot [OP] Well-Known Member
    03 Tacoma TRD
    Will they fit?
    4wheelparts is saying no (figured they would) because my stocks are 16".
    From what I've researched, only the 04 tacos with VSC have bigger brake rotors that require 16" +
    Correct me if I'm wrong? About to pull the trigger.
  2. Dec 14, 2011 at 12:24 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    Its not the rotors that matter with aftermarket rims, its the rim rubbing the caliper.
    You can run 15X8's as long as they dont rub the calipers up front.
    Forget about 4wheelparts. They dont know shit...terrible retailer.
    Wheelers offroad sells 15'' rims that fit our trucks.
  3. Dec 14, 2011 at 12:24 PM
    tc98tacoma
    tc98tacoma Well-Known Member
    Nik
    San Antonio, Texas
    98tacoma4x4
    3inch toytec coils 5100's, aal(soon to be replaced), 33/12.5 km2s, + a money hole...
    I think theyll fit as long as they have nough backspacing and offsetto clear the brake caliper, I have mickey thompson classic 2s and theyre 15x8
  4. Dec 14, 2011 at 12:26 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
  5. Dec 14, 2011 at 12:28 PM
    haolerot
    03 Tacoma TRD
  6. Dec 14, 2011 at 12:30 PM
    TacoMX
    Jonathan
    Deltona, Florida
    why not just rims w/ 3.5'' BS and skip the 1/4 spacer that will cause nothing but problems. 1/4 spacers take away from the amount of thread the lugs use, not safe.
    Dont take any suggestion from 4wps...
  7. Dec 14, 2011 at 12:32 PM
    Digiratus
    Roaming the PNW
    The RedHead
    It would be great if those 52s in the 15x8 size will work without a spacer. You'll have to let us know how they do. I would like to use them. :D
  8. Dec 14, 2011 at 12:33 PM
    haolerot
    03 Tacoma TRD
    Isn't the spacer just used to clear the caliper? I've done research around TW, and haven't heard of spacers causing anyone problems.
  9. Dec 14, 2011 at 12:35 PM
    TacoMX
    Jonathan
    Deltona, Florida
    1/4'' spacers will, because they just take up thread room that the lugs need. Larger spacers (like spidertrax) bolt onto the truck and have their own studs so that strength isn't sacrificed.
  10. Dec 14, 2011 at 12:41 PM
    haolerot
    03 Tacoma TRD
    But spidertrax would stick out an additional 1" right?
  11. Dec 14, 2011 at 12:44 PM
    haolerot
    03 Tacoma TRD
    I swear I've heard of people using them here just fine, but I dunno.
  12. Dec 14, 2011 at 12:49 PM
    Digiratus
    Roaming the PNW
    The RedHead
    It depends on wheel design. I hope you are right about the D windowed 52s. Of all the black steelies, I think they look the best as they don't have that silly pinstriping on them.
  13. Dec 14, 2011 at 1:01 PM
    haolerot
    03 Tacoma TRD
    Just pulled the trigger.
    I hope I'm right as well :)
  14. Dec 14, 2011 at 1:26 PM
    Digiratus
    Roaming the PNW
    The RedHead
    :thumbsup:
