16" Konig Countersteer Offroad & Tundra brakes?
Discussion in 'Wheels & Tires' started by TacoFL, May 11, 2013.
  1. May 11, 2013 at 6:55 PM
    TacoFL
    TacoFL [OP] Member
    Florida
    02 TRD Limited Double Cab
    Icon COs, Alcan rear springs + Bilsteins, AFE intake, Canton oil accumulator, Tundra front brakes, land Cruiser rear discs, full floating rear, 4.56s, true-trac up frnt, Manual Hub swap, All-Pro rear bumper and bed rack, Relentless Fab DIY plate front bumper w/Ramsey REP 8000, 285 Duratracs on SCS F5 wheels.
    Anyone out there running this combo on their 1st gen (or Tundra)?
    Have searched and read extensively of course...particularly the stickies in this forum...nothing stating a definitive answer...
    JdMeF9SiR2 you out there? from what I read you might be able to address this one?
    The FN wheels site does not seem to have this info.
    I am running the S13WE calipers and corresponding rotors on my 02 Taco with stock 1st gen Toyota alloys...16" 4.5" BS. These wheels clear the calipers fine. Just putting that out there as during my search for info I found numerous posts questioning or stating the contrary.
    Related - Anyone know of a list of alloy wheels compatible with these calipers? TTORA has a thread on this subject but it is pretty short. Add the SCS F5 wheels, stock Toy alloys and a few Pro-comp models I have been able to verify by search and this list is pretty limited...
    Anyway any help is appreciated!
  2. May 13, 2013 at 6:02 AM
    TacoFL
    TacoFL [OP] Member
    Florida
    Bumpin it...
  3. May 13, 2013 at 10:32 AM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
  4. May 13, 2013 at 11:19 AM
    TacoFL
    TacoFL [OP] Member
    Florida
    hey thanks for that...Have looked at the Level 8 wheels as well.
    Sure would like a definite "yes they fit" versus a "should" though
    I may very well be hitting you up for some of those...Since I have you on the subject of Level 8 MK6s; can you confirm these are hubcentric with a 106mm bore?
    back to Lurking and searching Tundra/Sequioa forums for more answers on these calipers and compatible wheels it appears.
    Regards
  5. May 13, 2013 at 11:24 AM
    Discount Tire
    Arizona, USA
    According to our fitment guide, the 16x8 MK6 (both offsets) clears the 1st Gen Tundra and Sequoia brakes.
    The MK6 in the 6-139.7 bolt pattern utilizes a 106mm hub bore :cool:
  6. May 13, 2013 at 11:27 AM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    Hey TacoFL, I am running 16" Countersteers and have the Tundra brake mod (using the larger 13WL 231mm calipers even). They clear no problem. No spacers needed.
  7. May 13, 2013 at 11:32 AM
    TacoFL
    TacoFL [OP] Member
    Florida
    My bad...found in your attached thread where it states Level 8 MK6s are 106mm hubcentric
    Man I thought I searched and read it, what I get for not saving that info.
    Thanks
  8. May 13, 2013 at 11:34 AM
    Discount Tire
    Arizona, USA
    Glad we could help, TacoFL.
  9. May 13, 2013 at 11:35 AM
    TacoFL
    TacoFL [OP] Member
    Florida
    Nice...Thanks Davidpick that is exactly what I was hoping for
    Really appreciate that reply. Lets me narrow down the choices.
  10. May 13, 2013 at 12:41 PM
    JdMeF9SiR2
    JdMeF9SiR2 FN Wheels
    Corona, CA
    05 Tundra 06 Tacoma 14 FJ Cruiser 19 Tundra
    The 16x8" Countersteer Offroads most definitely clear the S13WE and 13WL Tundra brakes. I have had a set of 16x8" Countersteer Offroads on my 2005 V8 Tundra for a few years now. :)
    I know you did not ask about the Level 8 wheels originally, but if you are considering the Level 8 wheels I would encourage you to compare the weights of the two wheels as well.
    The Konig Countersteer Offroad weighs approximately 18.5lbs.
    The Level 8 MK6 weighs approximately 23.5lbs (per Level 8).
    This is approximately a 27.5% difference in unsprung weight. You'll save a few bucks up front with the MK6, but in the long run you'll lose gas MPG, braking and suspension performance when comparing to the lighter-weight Konig Countersteer Offroad. Since you upgraded your brakes to Tundra calipers, I would imagine that braking performance (and performance in general) is important to you. :)
