16" rims with a 6" lift?
Discussion in 'Suspension' started by taco@you123, Aug 14, 2008.
  1. Aug 14, 2008 at 6:56 PM
    taco@you123
    taco@you123 [OP] Well-Known Member
    mesa, arizona
    07 toyota tacoma prerunner sr5 with
    6" pro comp lift, moto metal rims, front grill
    hey guys does anyone know if it's possible to put 16" rims with a 6" lift, i know u can't do it with pro comp 6". but is there any other lift that u can keep 16" with? :confused:
  2. Aug 14, 2008 at 6:58 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    why cant you run 16 inch rims with a specific lift?
    rim size usually isnt the issue...its tire size
  3. Aug 14, 2008 at 7:10 PM
    kristopherl
    kristopherl AKA: Jake the Wolf
    Cincinnati, Ohio
    08 Tacoma DC 4x4 Sport LB. Foglight
    Cup holder LEDs, Black Max Tonau, BHL Mod, N-Fab side steps
    you can run 16" rims on anything.. it's the tire size and offset you have to look at
  4. Aug 14, 2008 at 7:12 PM
    JimBeam
    JB
    2015 Tundra
    not all 16 inch rims fit the 2nd gen trucks though...you have to be sure they clear the brake calipers
  5. Aug 14, 2008 at 7:14 PM
    kristopherl
    Cincinnati, Ohio
    right but a lift has nothing to do with a rim size
  6. Aug 14, 2008 at 7:20 PM
    taco@you123
    mesa, arizona
    i have the 6" lift and they showed me that the 16" rims hitting, so i had to go with 17"
  7. Aug 14, 2008 at 7:22 PM
    JimBeam
    JB
    2015 Tundra
    hitting what?
    that could be because of the backspacing or tire size...
  8. Aug 14, 2008 at 7:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2
  9. Aug 14, 2008 at 7:29 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    x3
    What was it hitting?
  10. Aug 14, 2008 at 7:37 PM
    mudslingin44
    mudslingin44 Well-Known Member
    west palm beach, fl
    07 tacoma double cab trd 4x4
    6 in pro comp coilover-35 in pro comp extreme mudders
    it hits the brake caliber,i seen a taco with 16in rims with the mickey thompson simmulated beed locks and they had to grind the calibers to make the rims fit.the only difference that you need to worry about is the backspaceing bacause my stock taco came with 16in rims.
  11. Aug 14, 2008 at 7:45 PM
    JimBeam
    JB
    2015 Tundra
    thats what i figured...it has nothing to do with the lift
  12. Aug 16, 2008 at 2:57 AM
    ellsworth
    ellsworth Well-Known Member
    Buffalo
    08' off rd 6 speed
    6 inch Fabtech, st stabilizers, 18x9 DC -1s 305/65/18 bfg at's
    Fabtech relocates tie rod on top of knuckle and apparently a 16 won't clear tie rod.
