'16 TRD Off-Road: bigger tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Coaltown992, May 25, 2017.
  1. May 25, 2017 at 7:47 AM
    Coaltown992
    Coaltown992 [OP] Active Member
    16 tacoma TRD
    Thinking about getting some bigger tires on my truck. I've got a stock 3rd gen TRD off-road and I'm wondering how big I can go without it them rubbing anywhere. Any advice?
  2. May 25, 2017 at 7:49 AM
    ericd
    ericd Stuff
    Eric
    las vegas
    2013 DCSB 4x4 OR
    Pretty sure you can fit 35's.
    CemenTRDgen, trabo, Jack0928 and 6 others like this.
  3. May 25, 2017 at 8:10 AM
    Braves95
    Braves95 Go Clemson Tigers
    David
    Central PA
    17 MGM TRD Off Road DCSB P&T 6MT
    Fab Fours Bumper Block Heater Dual Exhaust Flow Master Smittybilt 12k Winch Synthetic Rope Bed Mat Roof Rack Puddle Lights 17" Rockstar Wheels NittoTerra Grapplers Power TailGate Lock Tonneau Cover w/lights Mobtown sliders MT Remote Start Tinted Windows Front And Rear Camera BRC Competition Diff Breather Bed Step Weather tech Floor Mats TRD Pro Tail lights TRD MT Shift Knob ARB dual compressor URD short shifter Kings 2.5 OEM W/remote resi. Click adjuster.
    I think 33''s. Higher I believe cab mount cut? @Blackout14 @Sub-Zero
  4. May 25, 2017 at 8:13 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Unless there was a change from 2nd Gen Off Roads, the truck comes with 265/70-16 tires (~31").
    You can (as many of us have) up it to 265/75-16 (~32") and no lift is needed for no rub.
    taco2010trd likes this.
  5. May 25, 2017 at 8:14 AM
    Braves95
    David
    Central PA
    I think u will get slight rub with 285.
  6. May 25, 2017 at 8:14 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    See the links in my signature below. It will answer your questions.
    RyanL, hiPSI, bilplat and 1 other person like this.
  7. May 25, 2017 at 8:18 AM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    265/75/16 or 265/70/17 if willing to get some 17s
    /thread
  8. May 25, 2017 at 8:19 AM
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    33's will require CMC and some minor plastic trimming if you will be doing any type of off roading. Any tire larger than 33' will require fender trimming and some hammering. I'm currently in the process of upgrading to 35's from 33's on a 2.5" lift.
  9. May 25, 2017 at 8:20 AM
    smitty99
    Scottsdale
  10. May 25, 2017 at 9:43 AM
    trdsupreme
    trdsupreme Well-Known Member
    2017 TRD OR DCLB Silver Sky
    255/85r16 for the pizza cutters (33 inch)!
    Nedrolls likes this.
  11. May 25, 2017 at 10:17 AM
    Long Time Toy Fan
    Long Time Toy Fan Well-Known Member
    17 DCOR
    Cookie cutter Tacoma, 888/Dakars/LR/ECGS/Sliders
  12. May 25, 2017 at 10:23 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    People fit those 255s on stock second gens too.
    It just isn't mentioned since the question is always the "biggest" tire and not the "tallest," and most ask biggest because they want a taller, wider tire.
    Sandytaco14 likes this.
  13. May 25, 2017 at 10:52 AM
    Long Time Toy Fan
    17 DCOR
    Another note if you're shopping is that not all 255/85R16 tires are the same size. If you look here you can see the different 255/85r16 dimensions. T4RFTMFW, from what I see the ones that measure 10.2 wide look pretty close width wise to the 265. I sure wish Goodyear would offer the Duratrac in 33x10.5 for those of us who live in snow country.
    smitty99 likes this.
  14. May 25, 2017 at 10:53 AM
    smitty99
    Scottsdale
    It's hit or miss there are no promised fits as every truck is slightly different. Even with 255/85
  15. May 25, 2017 at 10:55 AM
    amxguy1970
    amxguy1970 Well-Known Member
    Tyler
    Texas
    Have you tried searching? I guess no, that is the number 1 asked question on here or any truck forum. Smitty has some excellent links, go through those.
    Tyler
    RyanL likes this.
  16. May 25, 2017 at 10:57 AM
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    Search much? I'm sure there's only 20+ threads on this. 265/75r16 and 265/70r17 also depends on wheel offset/backspacing may rub a bit in certain instances.
  17. May 25, 2017 at 11:35 AM
    yarberrymt
    yarberrymt Well-Known Member
    Make sure you put some thought into the weight and construction of the tire.
    I'm struggling with finding a tire that strikes a balance between adding a ridiculous amount of unsprung weight and going up a size in tire, without having to re-gear.
    265/75/16 Duratrac seems to fit the bill, but hear they are noisey.
    WISH someone made a Load C, 275/75/16 that weighed in around 50lbs. It would be the perfect tire for me.
  18. May 25, 2017 at 11:39 AM
    smitty99
    Scottsdale
    Pretty much anything is going to be noisier if it has more aggressive tread compared to the "road tread" all terrains they come with... aggressive looking tire and road noise go hand in hand. If you don't want road noise and want a solid all terrain tire look into the yokohama Geolanders. If you want a tire that will perform decent in mud snow and pavement but looks cool get Duratracs. If you want a tire that doesn't perform well in mud but looks cool get a BFG KO2
    SR510 likes this.
  19. May 25, 2017 at 11:41 AM
    Trident904
    Brian
    17 4Runner TRD OR
    Dick Cepek Extreme Country in 285/75R16 weighs just around 55 pounds. I have them and have put almost 15k on them. Road noise is there but not much louder than a set of KO2's.
  20. May 25, 2017 at 11:50 AM
    T4RFTMFW
