16x8 +0 without flares
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dgirgis, Oct 9, 2017.
  1. Oct 9, 2017 at 6:39 PM
    dgirgis
    dgirgis [OP] Active Member
    2017 White SR5 Tacoma
    From what I found online its 16x7 +25, if thats true then it will poke 37mm..
  2. Oct 9, 2017 at 6:40 PM
    chrisrocks300
    chrisrocks300 War Eagle
    Brandon, MS
    2016 4x4 Tacoma DCSB Trd Off-road Superwhite
    Total Chaos UCA's, Raceline Raptor wheels (16x8) 4.5 BS, 285/75/16 Cooper S/T Maxx tires, Icon Stage 2 Lift Kit, Sos sliders w/ fill plates, exhaust reroute, mobtown offroad skid plates (ifs, transmission, transfer case), and diff breather mod
    Hopefully this helps? I took this the other day
  3. Oct 9, 2017 at 6:41 PM
    dgirgis
    it appears nearly flush and you have wide tires.. convincing
  4. Oct 9, 2017 at 6:42 PM
    chrisrocks300
    Brandon, MS
    They still tuck well too
  5. Oct 9, 2017 at 6:47 PM
    MeFryRice
    MeFryRice Well-Known Member
    Marietta, Ga
    '16 QS Tacoma DCOR4x4
    Here you go. 16x8 et0. 285/75 tire. No spacers.
    Clay7160 and 1bad2k like this.
  6. Oct 9, 2017 at 6:49 PM
    dgirgis
    ok perfect. so i believe with the 245 it should def be right around flush
  7. Oct 9, 2017 at 6:51 PM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    Headlight specs? :D
  8. Oct 9, 2017 at 6:54 PM
    chrisrocks300
    Brandon, MS
    Won’t be flush, you’ll still have a decent bit inside the well
  9. Oct 9, 2017 at 6:55 PM
    dgirgis
    even better, because i even like how the steel wheel sits..
    chrisrocks300[QUOTED] likes this.
  10. Oct 9, 2017 at 6:57 PM
    dgirgis
    my main concern was not having excessive poke it looks bad, as long as i'm flush or tucking a little i'm good. but considering they stick out +37mm more than my steel wheels is the reason for all my concern
  11. Oct 9, 2017 at 7:01 PM
    chrisrocks300
    Brandon, MS
    You’re fine
  12. Oct 9, 2017 at 7:01 PM
    Clay7160
    Clay7160 Well-Known Member
    2018 MGM TRDOR DCLB 4x4
    GYEON ceramic coating
  13. Oct 9, 2017 at 7:09 PM
    pkang0915
    pkang0915 Well-Known Member
    Bay Area, California
    2017 Tacoma DCLB OR (first time Taco owner)
    TOYTEC 2.5 kit, SPC UCA, N-fab side steps, TRD pro grille, FN FX PRO Wheels, BFG KO2S (265/70/17 C Rated), TRD Skid plate, Tyger Tonnue Cover, OVtune, Borla S type exhaust
    I have the flares, front wheel is turned a little but you can see poke from the back wheel this is the FN FX PROS 0mm offset
    Taco Slinger 4000 likes this.
  14. Oct 9, 2017 at 7:11 PM
    dgirgis
    hm see on your truck it seems like it pokes a lot and you have flares :(
  15. Oct 9, 2017 at 7:13 PM
    #35
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    Just curious, why are you against installing flares? I've seen some used ones pop up lately for cheap, and I saw someone did a detailed write up for installation on a truck that came from the factory without.
  16. Oct 9, 2017 at 7:14 PM
    #36
    dgirgis
    I'm not against it but it seems like a ton of work to put the oem on, if there's an easy aftermarket one that also looks as good i'm open too it
  17. Oct 9, 2017 at 7:27 PM
    #37
    MeFryRice
    Marietta, Ga
    BLHM. RX350 bi-xenon projectors. STI-R clear lens with the TRD logo etched. 5k Morimoto bulbs and ballasts. This is one of the best upgrades imo. Not cheap (especially if you break a housing and are required to buy a new one from the dealer) but well worth it.
    1bad2k[QUOTED] likes this.
  18. Oct 9, 2017 at 7:31 PM
    #38
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    Pretty much exactly my build, except osram CBI bulbs, red painted shields for the "passive demon eye" look, and dk mould light smoke side reflectors. Couldn't agree more on it being the best mod!
    MeFryRice[QUOTED] likes this.
  19. Oct 9, 2017 at 7:35 PM
    #39
    MeFryRice
    Marietta, Ga
    I’m looking to upgrade my bulbs soon. I have the factory optional LED fogs and considering swapping to the Morimoto XB LED fogs. I need a comparison to show the beam pattern between spending the money. Thankfully, TRS is not far from my house so I just need to stop by to make this happen.
    /sorry to get off track in this thread. Please carry on with the normal broadcast.
  20. Oct 9, 2017 at 7:36 PM
    #40
    dgirgis
    its ok feel free to talk i dont mind
    1bad2k and MeFryRice[QUOTED] like this.
