16x8" and 17x9" - New Wheel Design Previews
Discussion in 'Wheels & Tires' started by JdMeF9SiR2, Jun 25, 2012.
  1. Jun 25, 2012 at 5:27 PM
    JdMeF9SiR2
    JdMeF9SiR2 [OP] FN Wheels
    Corona, CA
    05 Tundra 06 Tacoma 14 FJ Cruiser 19 Tundra
    08/01/2012 UPDATE: Page 2 has been updated with specs and pics of one of the new wheels.
    I just wanted to share with everyone a few new styles I found out about from FN Wheels, Advanti Racing, and Konig Wheels. I saw the wheels while I was visiting with my friends from FN Wheels. They tell me everything should be out over the course of this summer and early fall.
    1) Yet to be named wheel
    Specs:
    16x8"
    6x139.7mm
    -25mm offset (3.52" back spacing)
    106.1mm hub centric application available for Toyotas.
    Center caps will be included with every set
    Colors:
    -Matte bronze
    -Matte black
    -Anthracite gunmetal
    2) Yet to be named wheel
    Specs:
    17x9"
    6x139.7mm
    0mm offset (5" back spacing)
    Center caps will be included with every set.
    Colors:
    -Matte bronze
    -Matte black
    -Graphite dark gunmetal
    (The original sample photo of a white wheel has been removed and an updated photo is now shown below.)
    3) Advanti Roccia - Special Edition
    Specs:
    16x8"
    6x139.7mm
    -6mm offset (4.26" back spacing)
    This wheel can also be ordered in 17x9", 18x9" or 20x9" with either 0mm offset (5" BS) or +12mm offset (5.47" BS), as well as different bolt patterns (such as 5x114.3 for the 5-lug Tacomas, 5x150 for new Tundras, etc).
    The changes to this wheel vs. the regular edition are:
    -No additional machining / no raised accents. The whole wheel is smooth, and the wheel is entirely matte black.
    -Matte black rivets have been used to keep the look even cleaner.
    These changes came directly from Tacoma World member feedback that was relayed to Advanti and FN Wheels.
  2. Jun 25, 2012 at 5:29 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    What's the weight of the Hase clone?
  3. Jun 25, 2012 at 5:36 PM
    JdMeF9SiR2
    Corona, CA
    They tell me the exact weight is TBD, but it is expected to be under 20lbs once all is said and done. This is with a 955KG load rating (2,100lbs +) and support for at least 35" tires.
    FYI, this makes the wheel lighter and just as strong as a 16x8
    -25mm offset Weds Hase Spec.
  4. Jun 25, 2012 at 5:41 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    If this was made in 17in or 18in I would be all over it! Why the small size? I understand for the offroad guys but could ya'll expand the market?
  5. Jun 25, 2012 at 5:43 PM
    BenJammn5
    BenJammn5 RN
    San Jose
    09 TRD-Off Road PreRunner
    TRD cat-back with Spintech prostreet muffler, AFE Pro dry S intake, 16" SCS F-5, 3.5 BS, 305/70 GT Radial MT, King extended travel front/rear, 2" add-a-leaf, Maxtrack Spindles, Sway bar delete, DSM UCA, All Pro IFS skid, Cab mount chop, bed cab locks, Black badges, cali raised amber LED fogs, 6K FX-R Morimoto projectors with 55watt ballast, fog mod, cheap rear dust lamp from autozone, Hellas 500 behind grill, Color match Satoshi Grill, Hood scoop, rear bumper by BTF, color matched Glassworks bed caps, Wet Okole seat covers
    Specs:
    16x8"
    6x139.7mm
    ^ That is some back spacing, love the dimensions for a 8" rim.
    #2 is what I would put on an Xrunner
    #3 looks traditional to a lot of procomps, AR etc. but it's a clean design.
    Really like #1 as you cannot find a lot of hubcentric wheels with that backspacing.
  6. Jun 25, 2012 at 7:33 PM
    JdMeF9SiR2
    Corona, CA
    They felt that they had the most demand for a wheel of these specs / design in a 16x8". I will definitely pass on your input that you'd like a 17" version as well, and if there are enough guys that feel the same way you do I am sure they will be able to add a 17" version as well. In fact, this 16" version is coming out because of a group of people (myself included) asking them to make it.
    Wheel #2 is coming out as a 17x9", and they already offer a few similar designs in 17" and 18", such as these:
    1) I agree! That backspacing gives a really aggressive stance. Perfect for long travel setups.
    2) I will pass on the word about the XRunner. I think it'd look good on an XRunner too. The idea behind this wheel is to create a 17" version of this 18" wheel (below):
    3) Also agreed, and I was glad to see Advanti change the design up a little to be more simple and refined. The black rivets are nice touch too, in my opinion.
  7. Jun 25, 2012 at 7:36 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Holy crap I would buy these. Is there a regular edition I can buy now??
    ETA: I see the regulars have silver inserts and look like motos. No interest there, but the black ones are sweet.
  8. Jun 25, 2012 at 8:06 PM
    JdMeF9SiR2
    Corona, CA
    I had been hearing from everyone that they'd like to see the wheel more refined with the raised parts smoothed out, and no contrast / polished machining. Advanti made this sample to show off to Tacoma World to see if this is what you guys wanted. I take it this is more along the lines of what everyone hoping for.
  9. Jun 27, 2012 at 12:19 AM
    HI TACO 66
    HI TACO 66 Well-Known Member
    Jerome
    Ewa Beach, Hawaii
    2018 Cement Tacoma TRD OFF ROAD 4x4
    sick wheels
  10. Jun 27, 2012 at 4:38 PM
    JdMeF9SiR2
    Corona, CA
    Thanks! I agree too. I will pass on your thoughts to the manufacturers.
  11. Jun 27, 2012 at 4:44 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    interested in price of the 3.5" backspacing wheel but in 17" diameter if possible.
  12. Jun 27, 2012 at 6:19 PM
    Mescalero
    Mescalero Beretta Taco
    Anderson, SC
    '15 DCSB TRD PRO Mag Gray
    yeah those Advanti Roccia - Special Edition look interesting.
    cool find.
  13. Jun 28, 2012 at 1:05 PM
    slcnbldr
    slcnbldr Well-Known Member
    Anthony
    Northern California
    DCLB TRD Sport
    20% tint on the front windows. 8-15-13 Installed Icons front and rear with Dakars. 2012 4Runner wheels with 275/70/17 BFG T/A KO2's. Weather Tech mats front and back. Leer shell with Leer Locker and roof racks.
    The Advanti Roccia is perfect as is...I'll take a set!
  14. Jun 28, 2012 at 1:09 PM
    subwayaz
    subwayaz Well-Known Member
    Tucson,Az
    2012 Accesscab; TRD
    Super Charger, Catback Exhaust,Side Wind Shades, & Carbon Fiber Dash Kit
    I like those first FN rims. Sweet!
    Dang aren't they pricey though.....
    Thanks for sharing
  15. Jun 28, 2012 at 2:04 PM
    JdMeF9SiR2
    Corona, CA
    The 3.5" back spacing 5-spoke wheel will only be offered in a 16" from what they tell me. However, they did mention that if there is enough demand (20 or so customers), a 17" version can be made. It would require a new mould to be manufactured, so that is why they need at least 20 customers.
    I will definitely pass on your screen name as someone who is interested in a 17" version.
    Thanks guys! I will pass on all of your thoughts, and I'll post more photos and specs as I get them.
  16. Jun 29, 2012 at 10:54 AM
    PAKraig
    PAKraig Well-Known Member
    Kraig
    Central Pennsylvania
    2017 DCSB 4x4 in Silver Sky
    OME suspension and 285/70R17 BFG KO2s
    How about a 17x8 Countersteer Type X in Silver?
    Hate to have to rattle can an 800 dollar set of wheels......:notsure:
  17. Jun 29, 2012 at 11:02 AM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    At it again! Looks good, I'm still waiting to see the type x in 16 rather than 17" :D
    picky, dbag, customers :rolleyes: haha
  18. Jun 29, 2012 at 2:59 PM
    JdMeF9SiR2
    Corona, CA
    There actually is a new color coming out for the 17x8" Konig Countersteer Type X. It's not silver, but it's pretty close. The color will be anthracite light gunmetal, which is a light metallic grey. As soon as I'm able to get some photos I will post it up. If you're looking for silver, I think you'll like it.
    :) That would be cool too, but I don't know that it will be coming out anytime soon. These new 16x8" wheels look pretty similar to the Countersteer Type X (just one less spoke). :thumbsup: I think the 5-spoke design would look really good on the badass, low-mileage pickup that you just got.
  19. Jun 29, 2012 at 3:18 PM
    Polymerhead
    Missouri
    I'm surprised at the lack of 16" aftermarket wheels. There are a lot of us who like a little style and still want a nice meaty tire.
  20. Jun 29, 2012 at 10:41 PM
    JdMeF9SiR2
    Corona, CA
    I agree, and I believe that's why 2 of the 3 wheels I saw / posted here are 16". They are trying to fill that void in the market right now.
    To play devil's advocate: I believe a lot of the newer vehicles require 17" / 18" + wheels for brake clearance, so wheel manufacturers are finding the market for 16" wheels more limited.
