17 " to 16"
Discussion in 'Wheels & Tires' started by Strykerbase, Nov 25, 2011.
  1. Nov 25, 2011 at 7:47 AM
    Strykerbase
    Strykerbase [OP] Member
    JR
    Blairsville, Ga
    Tacoma TRD Sport
    2" front spacers 2" rear
    Any one know if I can run 16" aftermarket wheels on a 11 tacoma Dc. I,m looking at some Vision Warrior 375, in 16x8 with a 4.5" back spacing. Don,t like the 17" factory wheels and the price difference 17,s compared to 16,s.
  2. Nov 25, 2011 at 8:06 AM
    Underdog777
    Underdog777 Well-Known Member
    Gilberz
    '06 Stuckrunner
    Camburg LT.
  3. Nov 25, 2011 at 8:26 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    ^^^^^what he said
  4. Nov 25, 2011 at 8:27 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    A lot of 16" wheels don't clear the brake calipers on 2nd gens. I would ask for a test fit before buying.
  5. Nov 25, 2011 at 8:27 AM
    Dirty5Thirty
    Dirty5Thirty TW's BAD MF'er Squad
    Dean
    Auburn, CA
    2003 4Runner SR5
    Dog hair
    Uhmmm...
    x3 :anonymous:
  6. Nov 26, 2011 at 10:04 AM
    CrisDe
    CrisDe Member
    Saratoga Springs, Utah
    4x4 TRD Off-Road
    Old Man Emu 2.5" Suspension Lift,V-Tec Wheels, BF Goodrich A/T KO 285/75/16, Demello Offroad Sliders,Line-X,Nokya HyperYellow Fog Lights, Anytime Fog Mod,Interior LEDs,K&N Airfilter, WeatherTech All-Weather Floor Mats
    are you sure your factory wheels are 17"? my 2011 trd off-road came stock with 16" wheels. KPT is absolutely right about the brake caliper issue. the simple answer is yes you can run 16" wheels but most will have clearance issues with the brake calipers. some wheels will only clear the outside of the caliper by a 1/16" or less so there is no tolerance if anything were to flex. the other clearance issue arises when you balance the wheels with stick on tape weights. you are limited to where you can apply the weights on the inside of the wheel because the caliper will rip them off as they rotate. i am running 16x8 V-Tec Raptors on my truck but i tried 3 other sets of wheels that, according to the fitment guide should have fit, but didn't. you can't judge the fitment solely on the backspace and offset - it's more a function of the design of the wheel: the the depth of the mounting pad in relation of the angle created with the center line of the wheel. i called Pro-Comp and they said their wheels wouldn't fit my application - yet - i saw a late model taco with 17" Pro-Comps and they fit ( i actually looked at them and examined the clearance).
    here's a link to some technical drawings.
    https://www.rsracing.com/tech-wheel.html
    if i had to do it over again, i might opt for the 17" wheels because there are fewer headaches.
    test fit the wheels befor you mount tires on them. good luck...
  7. Nov 26, 2011 at 10:08 AM
    TacomaChris
    TacomaChris Well-Known Member
    I just went from the 17" TRD Sport wheels to 16" KMC Enduros. The wheels were a tad close to the calipers but never rubbed. However, I shaved about 1-2mm off of each caliper just for peace of mind
